Using two Calendars in ActiveSync/Outlook2007
Discussion in 'Microsoft Mail (Outlook / OE / Windows Mail)' started by imei, 2007/11/04.
  1. 2007/11/04
    imei
    imei Inactive Thread Starter
    Hello there.
    I'm gonna tell you my problem in full description but bolded texts are main texts.
    I'm using Outlook 2007, ActiveSync 4.5 WindowsMobile 2003se (smartphone device sp3 imate)
    I'm using two or some times more calendar, i.e. Year re occurrence events and my university classes & exams and finally my normal appointments and reminders.
    While I'm using my PC or laptop its great, I set my calendars on "view in overlay mode" and I can see all of my events and appointments.
    But problem is here: I want to use exactly this view that has all of my dates' data on my smartphone. How can I synchronize more than one calendar?
    If this is not possible or you can't answer it, please help me providing a better solution for categorizing entries of calendar in really different places not just with "category feature" that just color it, not on a folder or category or...
    I some times use my calendars for publishing, and also give other ppl's calendar and import them so I should be able to separate this in my PC not publishing my personal data instead!!!
    As you probly noticed I use multiple calendars for this reasons:
    1- I can publish them or give them others without concern about data that is not related to others will disclose
    2- I can import others' calendar, manage them in separate folders, without concern about any conflict between my events and others.{when ever it happens I delete them/finding easy hah?}
    3-Finding is easy.
    But main problem is half of benefit of using calendar for me is on the mobile. and in mobile , It sounds that there's no way for syncing more than one calendar.
    Thanks for your help.
    Best wishes.
    imei A.
    imei,
  2. 2007/11/06
    imei
    Guys... I'm not gonna bump this thread but wondered if any body read my post or have any idea about that?
    Sincerely/
    imei,
    Well you have bumped it by posting again :)
    So far 27 people have viewed your thread - sadly no one so far has an answer for you.
    If you go to the forum list http://www.windowsbbs.com/forumdisplay.php?f=58 you can see how many views there have been.
