Using System Restore on Boot Up
Discussion in 'Windows XP' started by PeteC, 2004/09/03.
  1. 2004/09/03
    PeteC SuperGeek Staff Thread Starter
    I seem to recall a thread not so long ago which outlined the procedure for using System Restore before Windows loads, but I cannot find it :(
    Nearly 4 million hits on Google - I'm not going through all of those :)
    Can any one help me out on this, please?
  2. 2004/09/03
    charlesvar
    charlesvar Inactive Alumni
    Hi Pete,
    Other than going thru safe mode, I don't know of any; is the safe mode procedure what you mean?
    Regards - Charles
    Hi Charles,
    No - I had a feeling that there had been a thread on using System Restore on a computer which would not boot into Windows.
    It would not be the first time I have been mistaken :)
  5. 2004/09/03
    noahdfear
    noahdfear Inactive
    As far as I know, Pete, if Last Known Good or safe mode command line, %systemroot%\system32\restore\rstrui.exe., doesn't work/isn't an option, ASR (Pro) may be the only other option, short of using RC to fix whatever is keeping the PC from booting.
  6. 2004/09/03
    Jim - you can do it, sorta, kinda, sometimes.
    The closest I can think of is the process described Here where you boot to a safe mode command prompt and type in
    You can often get to a command prompt safe mode when you can't start the GUI at all.
    #5
  7. 2004/09/04
    Thanks - that's exactly what I was looking for - was just too tired to search in depth last night!
    Dave
    And thank you - unfortunately I don't remember setting up ASR on this particular m/c (not mine, although I built it). I have used it with success on mine on a couple of occasions.
