using PowerPoint to create interactive cd
Discussion in 'Other PC Software' started by heynow, 2003/02/17.
  1. 2003/02/17
    heynow
    heynow Inactive Thread Starter
    Hi All--
    I am attempting to use PowerPoint to create a small interactive CD. Mostly it seems to be working. I created a main page and put hyperlinks to the various video and other files I want folks to look at. So far so good.
    Here are my main problems: after the video runs in an intro segment, as an introduction to a certain group of slides for example, I'd like it to automatically go to those slides. As it is now you have to click on an additional hyperlink: so can I set it so that when the video intro ends the next slides will start automatically? (But I don't want the entire show to run one slide after another...)
    The other problem is that if I click on a link and a video introduction begins and then I click out of that video (before it ends) and go back to the main menu and then click back to that video it won't start again. I set it to loop, by the way.
    OR maybe this is all wrong and there's a better way to do this. Any ideas??
    Thanks.
    Ed
  2. 2003/02/22
    Daizy
    Daizy Inactive
    Hi Ed
    Sorry, I don't have a solution for you...but thought maybe this link might help?
    Daizy
