Resolved Using FOR command to list filenames in order
Discussion in 'Windows 10' started by Ludwig, 2018/09/05.
  1. 2018/09/05
    Ludwig
    Ludwig Well-Known Member Thread Starter
    Using a simple batch file I am trying to keep my backup files for a system under control e.g. keep the most recent 5, then delete any more provided they are at least 10 days old.
    To achieve this, I am trying to use the FOR command to list files in a directory in reverse name order (which, by convention is the same as saying reverse order of when they were created).
    I can achieve a list of the matching files using the FOR syntax -
    set srch=pal *.xlsm
    for /R %%a in ("%srch%") do echo file %%~fa ..​
    and, in my case, I get all 18 matching filenames listed. Trouble is, the list of files is from oldest to youngest. I need it to be youngest to oldest. That way I can skip the first 5. With the resultant list I can then check if the file is older than say 10 days and if so delete it.
    Ignoring the wrong order for now, I tried to skip the first 5 files in the list, so I added the SKIP option into the command -
    for /R "SKIP=5" %%a in ("%srch%") do @echo %%~fa ..​
    but now I get absolutely no files listed!!
    What an I coding wrong?
    Ultimately, I thought something like the following would do it, but it obviously is flawed ;-{
    i.e. files are listed in the wrong order, and listing of files not working at all with SKIP coded.
    set myNum=5
    echo list with skip the first %myNum% ...
    for /R "SKIP=%myNum%" %%a in ("%srch%") do (
    echo encountered file %%~fa .. datetime %%~ta.
    forfiles /M "%%a" /D -10 /C "cmd /c echo issue a delete for file %%a ..
    Thanks for any help anyone has.
  2. 2018/09/06
    I am not a programmer so I cannot answer this. Until a programmer comes along, I have to ask, can't you tell your backup program to keep only the last 5 backups?
    Bill,
  5. 2018/09/07
    Ludwig
    I figured my code ... combination of FOR and FORFILES will do it. Posted here in case someone else wants to use it, or a variation of it.
    set keepcnt=5
    REM
    REM other code in here
    REM working directory is where the files are so no need for "path" option in FOR
    REM
    FOR /f "skip=%keepcnt% eol=: delims=" %%f in ('dir "* FNpattern *.xlsx" /b /o-n') do (
    echo Checking if file "%%f" is old enough to delete ..
    FORFILES /M "%%f" /D -10 /C "cmd /c echo ..time to delete file @file" 2>nul
    FORFILES /M "%%f" /D -10 /C "cmd /c del @file"2>nul​
    As with the "echo" immediately before it, the first FORFILES is optional. I'm using it to give me a 'report' on what will actually be done. It does result in two "ERROR.." lines if the files are not 10+ days old, but the "2>nul" on the end eliminates those msgs.
  6. 2018/09/07
    Ludwig
    My "backup pgm" is what I write. App is written in Excel (with VBA) so a batch file (in addition to any system level backup "pgm" - which is a drive cloning each night .. don't ask me why that's what they do) does the backups periodically during the day using Task Scheduler in case a user does the accidental "hit the DELETE key" on their keyboard when explore-ing files on the network drive.
