USB V2.0, compatible with USB V1.1
Discussion in 'PC Hardware' started by purplemtn, 2003/04/28.
  1. 2003/04/28
    purplemtn
    purplemtn Inactive Thread Starter
    Are most USB items backward compatible with USB 1.1 ??
    Before I order I would like to make sure that ...
    This " Coolmax 3.5 "/5.25" External enclosure [ Features:
    Compatible 5.25 CD-ROM, CD-RW, DVD Drive and 3.5" HDD ..
    Or a similar one ,going to use it as a portable 30 gig HD
    and 1 for a CDRW if my frind wants 1 for her laptop
    Interface: USB V2.0, compatible with USB V1.1
    Works with PC ] "
    http://www.directron.com/directron/cd509u2.html
    Will this work on my PC with only USB 1.1 ..and win XP [ are driver available for XP } ??
    Thank You......purplemtn.....
  2. 2003/04/28
    Yes it'll work at 1.1. Slow, but it will work.
    Bmoore1129
    Bmoore1129 Geek Member
    Also you might check your BIOS and see if USB 2.0 is turned on? That is if your confuser is 2.0 compatible. You might also buy a plug-in for making USB 2.0 available on it.
  5. 2003/04/28
    purplemtn
    Thanks for the help
    Steve R Jones thanks for the info.
    Bmoore1129 thanks for the ideas , however most of the PC's I would be using it on would only have USB 1
  6. 2003/04/28
    Bmoore1129
    Maybe I was unclear....You can buy a PCI card that will give you 4 USB 2.0 ports. These ports will work on 2.0 or 1.1.
  7. 2003/04/28
    purplemtn
    Bmoore1129
    thanks for idea of buying PCI card that will give me 4 USB 2.0 ports . , but I planed on carrying it around to other PC's that most likely would not have USB 2 ports.
