USB Mouse problems
Discussion in 'PC Hardware' started by johngarnold, 2003/06/03.
  1. 2003/06/03
    johngarnold
    johngarnold Inactive Thread Starter
    I have just recently upgraded my motherboard and CPU to P4 2.4Gh Gigabyte GA-8PE800 PRO which has an Intel chipset.
    When I plug my mouse into the PS2 port (using an adaptor) everything works ok. When I plug it into a USB port windows does not detect it unless I firstly change the bios settings (in Integrated Peripherals) to USB MOUSE SUPPORT ENABLED.
    The problem is when I set it then during boot the bios displays the following message -
    EMM386 not installed - unable to set page frame base address press any key to continue.
    The PC then continues to boot up and Windows starts and everythings appears to work ok.
    Why do I get the EMM386 not installed - unable to set page frame base address
    I cannot see any other settings in the bios to set but maybe one of the learned people who read these forums will know.
    John
  2. 2003/06/03
    BillyBob Inactive
    #1 did you install any required Motherboad Drivers ?
    I had the same problem when moving a mouse from USB to PS2 and back.
    Do yourself a hugh favor.
    Get an El Cheapo Mouse and plug it into PS2. Then it will be available when in DOS or re-installing the OS.
    Completely UN-INSTALL the USB Mouse.
    Follow the instructions for the USB and re-install it and leave it there.
    BillyBob
    markp62
    markp62 Geek Member Alumni
    I would agree with BillyBob.
    It strikes me odd a USB mouse needing Expanded Memory support.
    However if you want it loaded, edit C:\Config.Sys to be like this, assuming this is a Win9x OS.
    Device=C:\Windows\Himem.Sys
    Device=C:\Windows\Emm386.Exe Ram
    Dos=High,Umb
  5. 2003/06/04
    BillyBob Inactive
    That error is from a DOS program.
    It you have anything other than ME or XP follow the suggestions provided by markp62.
    I am getting the same error witn XP. But I very seldom run that that DOS program ( I do not like it anyway ) so I will just get rid of the program.
    BillyBob
