USB Flash Drives problem
Discussion in 'PC Hardware' started by visee, 2007/09/14.
  1. 2007/09/14
    visee
    visee Inactive Thread Starter
    Hello, would you mind to tell me that "USB Flash Drives "
    http://www.kingston.com/flash/DataTravelers_consumer.asp
    is very small size, as same as finger ? but that Capacities is very large (1GB,2GB,4GB,8GB...16GB?)...
    what is that substance ?
    If around 1 year no used. no insert computer...mean no any extra power,
    that "USB Flash Drives" that DATA will Total Loss ?
    And If buy USB2.0 (4GB) Flash Drive , insert only support USB1.1 computer, is SURE no problem to run or Not Detect my device?
    And If computer is PII computer, maybe error: can't over 2GB problem,
    I remeber some Harddisk can't over 2GB. but USB Flash Same ?
    And That "USB Flash Drive" need Defrag ? As same as Harddisk?
    Any suggest!
    Thanks!
  2. 2007/09/14
