USB Flash Drive Problem (Revisited)
Discussion in 'PC Hardware' started by James Martin, 2005/02/17.
  1. 2005/02/17
    James Martin
    James Martin Geek Member Thread Starter
    Hi All,
    A while back, I posted a problem with my USB flash drive......
    http://www.windowsbbs.com/showthread.php?t=34283
    I would like to add another note to this problem.....I don't have 2 listings for the same removable drive until I reboot the PC....Is there something in the BIOS that could be causing this?
    Thanks,
  2. 2005/02/24
    James Martin
    I finally switched my OS to XP.........Problem solved. :D
    My newer board must be more geared for the XP system than for W98.
    Thanks for the update - welcome to the wonderful world of XP :)
  5. 2005/02/24
    James Martin
    XP seems to be a better OS so far.....Going to take me a while to get used to it....Thanks for the followup. :cool:
