USB Card reader Power supply
Discussion in 'PC Hardware' started by stitch, 2004/11/02.
  1. 2004/11/02
    stitch
    stitch Inactive Thread Starter
    Hi Al
    Can anyone help me please
    I am in the middle of putting a basic system together for my sister and am having a small problem with the internal card reader. It says to connect it to the usb connectors but they are all taken.
    The mother board is Asus A7N8X-X.
    This has usb 1-2 and usb 3-4 at the back then has provision for usb 5-6 at the front. Now 5-6 are connected to the case front usb and so where would i fit the USB2 cardt reader to. :confused: The card reader is a Shuttle pc12.
    Any ideas more than welcome
    Stitch :)
  2. 2004/11/02
    Hi Stitch,
    I guess you will have to forego either one of the rear USB's (could always use a hub out of the other if more USB ports are required) or the front ports. I can't see another solution :)
    Glad to see you are still building :D
