Usb Cables
Discussion in 'PC Hardware' started by jerryhillman, 2003/09/07.
  1. 2003/09/07
    jerryhillman
    jerryhillman Inactive Thread Starter
    I understand an old USB hub will work on USB 2.0
    put will not run fast so I must replace my old
    Hub with a newer 2.0 USB Hub. Does the same
    thing go with the cables. I have a dozen USB
    cable bought over the years. Do the cables
    also have to be updated or will the old cables
    work well on USB 2.0.
    Thanks, Jerry
  2. 2003/09/08
    Rockster2U
    Rockster2U Geek Member
    Cables should be just fine, they are inter-changeable even though you'll see lots of new cables labeled as 2.0 in retail outlets.
