USB Adapter Intallation Problems
Discussion in 'Networking (Hardware & Software)' started by eltomoni1, 2005/02/04.
  1. 2005/02/04
    eltomoni1
    eltomoni1 Inactive Thread Starter
    I have tried to install a Motorola USB Wireless(WU830G) adapter on my computer (Windows XP),it goes thru the installations steps,until I get the following message" Installer error, Failed to install signed IM Driver "
    It is possible that I have a corrupt Windows installer?Then it will finished the installation,but the adapter will not work.
    Your cooperation and assistance are greatly appreciated.
  2. 2005/02/04
    It is possible that the adapter is USB 2.0 and your computer does not have USB 2.0 ports and only supports USB 1.1. You would have to go out and get a USB 2.0 pci card and load the drivers that come with it, then install the adapter.
    eltomoni1
    USB Adapter Installation Problems
    I think you are correct.Because I installed the adapter on another computer with USB 2.2 and no problems.The firs computer has only USB 1.1. I will get a PCI card USB 2.2 for that computer and that should solve the problem.
    Thank you very much for your asssistance.
    Take care and "the force be with you ".
