USB 3.0 Hub
Discussion in 'PC Hardware' started by joe645, 2014/06/13.
  1. 2014/06/13
    joe645
    joe645 Well-Known Member Thread Starter
    I have a 4 port USB 3.0 hub connected to a 3.0 USB port on my MB. Whenever I use this hub for data transfer, I get a message that says "this device will run faster if I use a 3.0 port instead of a 2.0 ". I don't quite understand why I am getting that message. Can my 3.0 port on the MB gone bad?
  2. 2014/06/13
    Hi joe645, This is from the Asus specs:
    It's obvious - but you have connected BLUE to BLUE?
    And if your hub is not connected - do you get any messages? Neil.
    joe645
    Neil,
    The Hub has a 3.0 identification. The error message does not appear when the device is directly connected to the 3.0 (Blue) port on MB.
  5. 2014/06/17
    Was the hub tested on another comp to confirm it's working correctly?
    It may be a faulty hub incorrectly marked? Neil.
  6. 2014/07/05
    joe645
    The hub must have gone bad. Replaced it . . . no problems
  7. 2014/07/06
    Please mark your thread as Resolved
    Marking a thread as 'Resolved'
