upgrading USB 1-1 to 2.0 with pci card
Discussion in 'PC Hardware' started by aruark6029, 2008/04/13.
  1. 2008/04/13
    aruark6029
    aruark6029 Inactive Thread Starter
    Hi, if you have an older dell motherboard ( model 4400 ) that only has 1.0 USB, can you install a 2.0 USB pci card to upgrade the data rate
    thanks for your help
    aruark6029
  2. 2008/04/14
    aruark6029 - Welcome to the Board :)
    So long as you have a spare PCI slot - yes. Only the USB ports on the card will be USB 2 - your existing USB ports will stay at USB 1.
