Update Problems
Discussion in 'Windows XP' started by Kotare, 2003/04/03.
  1. 2003/04/03
    Kotare
    Kotare Well-Known Member Thread Starter
    Hi,
    I've been trying to download updates 814033 and 331953. I have never had the slightest problem doing all previous updates, they've gone like clockwork, but these two!!@@!!@
    Although they both are small files, they seem to take some time to download and when I hit install, within seconds I get the 'failed' message. The files are on my hard drive, but won't install. Anybody else have a problem with them? Any ideas? I haven't changed anything that I'm aware of.
  2. 2003/04/03
    BruceKrymow
    BruceKrymow Inactive
    Hi, Kotare ~
    Please see my posts here and here and you will have this resolved.
    Kotare
    Hi Bruce,
    Worked a treat thank you very much.
    cheers
    Rick
  5. 2003/04/04
    BruceKrymow
    Hi, Rick ~
    Right on! That fix will hold for other updates whereby the download fails or upon install you receive a message stating update already installed.
  6. 2003/04/05
    Kotare
    How on earth do you figure these things out Bruce? I did do a hunt on the MS site but nothing they came up with seemed to exactly fit my problem. As for hunting around in catroot files - I don't have enough life left to have figured that one out. Anyway thanks again, I've printed it off and stuck it in the rescue folder.
