Unable to perform System Restore
Discussion in 'Windows XP' started by beebop, 2007/05/26.
  1. 2007/05/26
    beebop
    beebop Inactive Thread Starter
    Hey guys. Im having a problem doing System Restore. Anytime i try it, when it loads back up, all it says is "No changes were made. Unable to perform system restore "
    Im trying to do it because out of nowhere, a handful of websites wont open for me, that my friends can access. So im thinking maybe some settings got changed, and i just cant find what they are.
    Has someone got any ideas?
    Thanx
  2. 2007/05/26
    charlesvar
    charlesvar Inactive Alumni
    Hello beebop,
    To test whether SR is working or not:
    Go into the Program Folders and look into one of the progam's folder and copy any file with an extension of .exe
    to the C drive. Make sure you COPY and not move.
    For instance, I have a search program called AgentRansack.exe. I would copy that to the C drive "naked" - no need to put it into a folder.
    Then:
    Create a manual System Restore point.
    Delete the copied .exe file.
    Then try a System Restore to that manual restore point you created.
    First, SR should not tell you no changes made, and second, the deleted copied .exe file should be back.
    Regards - Charles
