"unable to create a dial-up Networking entry
Discussion in 'Legacy Windows' started by eddwads, 2004/02/08.
  1. 2004/02/08
    eddwads
    eddwads Inactive Thread Starter
    I'm running Win2k. Trying to install Juno 5.0 thru modem. Modem works fine. I try to install Juno and it logs on to server to get local numbers. I select local number and continue - it logs on to the account also, but wants to download the email that is there. I don't want the email so I cancel it. Then try to logon to WWW which requires I start over. I then get the message "Juno was unable to create a dial-up netowrking entry ". I've tried it on 2 different computers and get the same result. I then try to build my own networking entry for Juno which it does, but for some reason Juno is unable to connect as it rejects the login name or password - both of which are correct. Any idea?
  2. 2004/02/10
    Have you tried setting all your email accounts to not be included in a general send/receive?
