UDMA Mode for Harddisk - How to set?
Discussion in 'PC Hardware' started by savagcl, 2005/05/09.
  1. 2005/05/09
    savagcl Lifetime Subscription
    WinXP Home (SP2).
    I just found a PC Wizard 2005 (Free utility). Located at:
    http://www.cpuid.org/cpuz.php
    Its like everest but i thing it gives more information.
    Having a problem with SATA HD's speed slowing down (old thread). I have 2 SATA disk
    installed. The characteristics are:
    SMART : Version 1.1
    IDE Controller : Intel Corporation 82801EB/ER (ICH5/ICH5R) EIDE Controller
    IDE Controller : Intel Corporation 82801EB (ICH5) SATA Controller
    >> Informations Hard Disk ST3200822AS
    IDE Controller : Gammagraphx Inc
    IDE Connector : #0 - Master Drive
    Model : ST3200822AS
    Serial Number : 5LJ05V2Y
    Revision : 3.01
    Support : ATA/ATAPI-6
    Serial-ATA : Yes
    Serial-ATA version : 1.0
    Cache : 8 192 KB
    ECC Size : 4
    Multiple Sector : 16
    IORDY : Yes
    LBA Mode : Yes
    DMA Mode : Yes
    Multiword DMA Mode : 2
    PIO Mode : PIO 4
    UDMA Mode max. : 6 (ATA-133)
    UDMA Mode Enabled : 5 (ATA-100)
    S.M.A.R.T. : Yes
    Power Management : Yes
    Acoustic Management : No
    Security Mode : Yes
    Write Cache : Yes
    48-bit Address : Yes
    And
    Hard Disk ST3160023AS
    Model : ST3160023AS
    Serial Number : 3JS0EFPE
    Revision : 3.05
    Serial-ATA : Yes
    Cache : 8 192 KB
    ECC Size : 4
    IORDY : Yes
    LBA Mode : Yes
    DMA Mode : Yes
    PIO Mode : PIO 4
    S.M.A.R.T. : Yes
    Security Mode : Yes
    Write Cache : Yes
    The first HD shown is the bootable disk (200GB).
    One confusing thing is that both disk are being shown as IDE Connector : #0 - Master Drive. Is this correct?
    This wizard is showing UDMA Mode Enabled : 5 (ATA-100) but it also shows
    UDMA Mode max. : 6 (ATA-133). How do i change the UDMA mode to ATA-133?
    thanks,
    savagcl
  2. 2005/05/10
    Hi Clif,
    Those drives must be "driving" you CRAZY :) .
    To change UDMA mode you usually need to use a utility from the HDD manufacturer. So check at Seagate website. (I'm not certain if SATA drives might be "special "??). You should also make sure that your motherboard ALSO supports the higher ATA.
    I doubt if you will find a lot of speed gain. ATA 133s have not proven much faster than ATA 100s. :(
    Only a "try ". Disable SMART in the BIOS. I have had problems with it. You can read it from Everest even though it is disabled or re-enable it if you think there may be something suspicious about your drive.
    Another maybe. Have you looked around the Seagate website. Their FAQs may be general, but see if you can find something in their Knowledgebase.
  5. 2005/05/10
    Christer
    Christer Geek Member Staff
    I doubt that those utilities read SATA drives correctly. The mode for a SATA should be "ATA-150" and for SATA II the mode should be "ATA-300 ".
    What does it say for the respective controller (in Device Manager)? That's where Windows reduces the transfer rates if it deems that action necessary.
    Christer
  6. 2005/05/10
    Hi Mattman, Christer,
    :) Its not a drive anymore, its a short walk to crazy.
    Checked the intel site and they dont mention ATA-133 at all, just up to 100.
    I looked for a "Smart" in my BIOS, but theres nothing about it to be found.
    I pulled everything from Seagate (again) and will run it through my system.
    Maybe this time it will show something.
    Take a look at what EVEREST shows about my HD's.
    ATA Device Physical Info:
    Manufacturer Seagate
    Hard Disk Name Barracuda 7200.7 SATA 200822
    Form Factor 3.5 "
    Formatted Capacity 200 GB
    Disks 2
    Recording Surfaces 4
    Physical Dimensions 146.56 x 101.85 x 26.1 mm
    Max. Weight 635 g
    Average Rotational Latency 4.16 ms
    Rotational Speed 7200 RPM
    Max. Internal Data Rate 683 Mbit/s
    Average Seek 8.5 ms
    Interface Serial-ATA/150
    Buffer-to-Host Data Rate 150 MB/s
    Buffer Size 8 MB
    Spin-Up Time 10 sec
    Max. PIO Transfer Mode PIO 4
    Max. UDMA Transfer Mode UDMA 6 (ATA-133)
    Active UDMA Transfer Mode UDMA 5 (ATA-100)
    Hard Disk Name Barracuda 7200.7 SATA 160023
    Form Factor 3.5 "
    Formatted Capacity 160 GB
    Disks 2
    Max. Weight 635 g
    Average Seek 8.5 ms
    Buffer Size 8 MB
    Spin-Up Time 10 sec
    Since EVEREST shows a Interface of Serial-ATA/150 and a Buffer-to-Host
    Data Rate of 150 MB/s, maybe i should be looking at other components of
    the system??? What would be the next thing to check along the path of HD
    to screen?
    My controller in device manager shows:
    IDE ATA/ATAPI controllers
    Intel(R) 82801EB Ultra ATA Storage Controllers
    pci bus 0, device 31, function 1
    From EVEREST:
    Processor
    Bus 0, Device 30, Function 0 Intel 82801EB I/O Controller Hub 5 (ICH5)
    Bus 0, Device 31, Function 1 Intel 82801EB ICH5 - ATA-100 IDE Controller
    Bus 0, Device 31, Function 0 Intel 82801EB ICH5 - LPC Bridge
    Bus 0, Device 31, Function 2 Intel 82801EB ICH5 - Serial-ATA/150 IDE
    Thanks, Guys,
    savagcl
    (Clif)
  7. 2005/05/10
    Christer
    I don't know what this means. Some SATA drives have a PATA to SATA bridge which means that they are no better than the PATA counterpart. They really are PATA with a SATA connector but I don't know if this applies to Seagate 7200.7.
    I don't have a SATA compatible motherboard myself so I don't know exactly what to ask for. Under IDE ATA/ATAPI controllers, is there any information on the separate channels (Primary IDE, Secondary IDE and anything for the SATA interface)?
    It seems like Your motherboard has a maximum of ATA-100 but that shouldn't limit the SATA performance but in my first quote, it is indicated that it runs in ATA-100 mode.
    :confused: ...... Christer ...... :confused:
  8. 2005/05/10
    Christer,
    I have 2 primary and 2 secondary channels listed under the IDE ATA/ATAPI
    controllers in addition to the 2 listed for Intel(R) 82801EB Ultra ATA Storage Controllers.
    I'm using the Primary Master for a DVD and the Secondary Master
    for a CD-RW.
    From what i've seen about the SATA, i'm (not a hundred % sure) kinda
    satidfied that the HD's are working as they should now. So i need to look
    further down the chain of devices to see what else could be causing the
    problem.
    I have recently added a 30 inch monitor (HDTV-Ready), its great but the
    seagate tools wont run now ( i tested them a couple weeks ago on the
    old monitor and they half supported SATA). Their tools depend on a bootable
    floppy (or CD) but this monitor wont recognize the signal as being correct.
    Progress = The most important product and the least obtainable!! :)
    thanks,
    savagcl
  9. 2005/05/11
    Wow 30 ", do you have to sit on the other side of the room to see it all? :D
    You are freaking me out a little there Clif :eek: . I cannot think of a connection between a boot disk/CD and the monitor. The graphics card, maybe.
    The monitor is really only told what to do by the graphics card. Until Windows is loaded, a monitor is a monitor is a monitor, it just throws pictures onto the screen that the graphics card tells it to.
    If you are running the monitor at high resolutions it may be putting a big strain on the graphics card (the graphics card has to tell the monitor what to put on the screen, if you are running at high resolutions the graphics card has a lot of work to do).
    Actually this might well be the problem....everything has slowed down waiting for the graphics card to send signals to the monitor....a big IF :) . Anyway, it may be worth investigating the graphics card you have. (Also, I am wondering if the high resolutions may have partially "cooked" the graphics card.)
    Any thoughts?
  10. 2005/05/11
    Mattman,
    its a great monitor (westinghouse model LTV-30w2, cost about 1200.00). Great
    for HDTV too plus i can watch normal channels in pip then use full screen when
    something good is showing. All this with a click!
    The only drawback is the resolution - max of 1280x768x32 but very usable for
    games, etc. Works well with my nVidia 6600GT card. I dont suspect/see any
    problems with graphics card.
    I had the speed problem way before adding this monitor tho so i dont think its
    having any effect on speed drop.
    When booting up, i get asmall image on-screen saying "no signal detected" then
    the PC takes control and boots normally. For the seagate boot, i get the normal
    no signal detected msg then as it starts to read the boot (floppy), a different
    msg appears about insufficient /unknown signal. This happens during the
    readingof the floppy and when the floppy stops being read, a normal boot
    into XP follows.
    I will try getting the CD version of seagate tools and try it.
    - My eyes are getting as old as i am :) thats why the 30 inches.... (but it
    does look good).
    thanks,
    savagcl
    (clif)
  11. 2005/05/11
    The 6600GT should be OK at that resolution, although I would monitor the temperatures ocassionally (there should be temperature utility that came with the drivers).
    It is still somewhat strange that you cannot run the boot disk programs and I would not totally rule out something about the graphics card effecting the whole system.
  12. 2005/05/11
    Mattman,
    I'll run the system through PCPitStop and see if they spot anything.
    BTY, Seagate support says the disk is within spec! (But they do not explain
    why the slow down - the battle begins.... :)
    savagcl
  13. 2005/05/11
    Sorry for the long post, i cut it as much as possible.
    I got the cd version of seagate tools to run. Ran the full set of test.
    This is what it showed:
    SeaTools Desktop v3.00.07
    Copyright (c) 2004 Kroll Ontrack Inc.5/11/2005 @ 7:39 PM
    The following information has been generated by SeaTools Desktop. Use
    this information to help you recognize and resolve potential data access
    problems.
    System Information:
    BIOS Date 04/21/04
    Conventional Memory size 639 K
    Extended Memory size 1046436 K
    IO Channel type PCI
    Diagnostic Results:
    System Memory Test Result: Passed
    System Information:
    BIOS Date 04/21/04
    IO Channel type PCI
    Diagnostic Results:
    problems.
    System Information:
    BIOS Date 04/21/04
    IO Channel type PCI
    Diagnostic Results:
    Basic Controller Test Result: Unsupported
    problems.
    System Information:
    BIOS Date 04/21/04
    IO Channel type PCI
    Drive Information:
    SIZE MODEL
    160 GB ST3160023AS
    Serial Number = 3JS0EFPE
    Int13 Num = 81, PHYS CHS = 16383x16x63.
    ParmTable CHS, Rsvd = 19457x255x63
    PARTITION CYLINDER SIZE
    # Type Start End MB
    PRIMARY
    1 NTFS 0 5098 41943 EXTENDED
    2 NTFS 5099 10197 41943 EXTENDED
    3 NTFS 10198 14659 36703 EXTENDED
    4 NTFS 14660 19456 39459 Diagnostic Results:
    Seagate DiagATA Quick Test Result: Passed
    Recommendation:
    The "Quick Test" is adequate for most situations.
    Consider running the "Full Test" which
    verifies each sector on the drive if you need to run a more
    comprehensive diagnostic.
    Results from Seagate's DiagATA/SCSI:
    DIAGATA.EXE Version 3.07.40526ML
    Copyright (c) 2002 by Seagate Technology, LLC. All rights reserved.
    Timer Resolution: 0.000122
    Short Test Begin: 11-May-2005 18:23:50
    Cable Test - 0 Errors
    Buffer Test - 0 Errors
    Identify Data
    Model Number: ST3160023AS
    Serial Number: 3JS0EFPE
    Firmware Revision: 3.05
    Default CHS: 16383-16-63
    Current CHS: 16383-16-63
    Current Capacity: 16514064 Sectors
    Total Capacity: 312581808 Sectors
    ID Method: Unknown
    SMART Check: Passed
    DST - Passed
    PIO/DMA Data Compare
    Total Bytes = 7308288
    Estimated PIO Transfer Rates
    Min: 2.26MB/s Max: 2.34MB/s Avg: 2.30MB/s
    Estimated DMA Transfer Rates
    Min: 65.40MB/s Max: 109.00MB/s Avg: 80.87MB/s
    SMART Check: Passed
    Short Test Passed: 11-May-2005 18:24:28
    End results from Seagate's DiagATA/SCSI
    ATA Full Test Result: Passed
    Long Test Begin: 11-May-2005 18:24:29
    Identify Data
    ID Method: Unknown
    SMART Check: Passed
    Full Scan (0 to 312581808) - Passed
    Elapsed Time: 1.24 Hours
    Estimated Internal Transfer Rates
    Min: 3.96Mb/s Max: 475.41Mb/s Avg: 300.88Mb/s
    Total Bytes = 21826560
    Min: 2.35MB/s Max: 2.43MB/s Avg: 2.40MB/s
    Min: 73.41MB/s Max: 146.82MB/s Avg: 77.55MB/s
    Long Test Passed: 11-May-2005 19:38:49
    File Structure Test Result:
    Partition 1 (NTFS (41.9 GB) G) Result: Failed with critical Errors
    Partition 2 (NTFS (41.9 GB) H) Result: Failed with critical Errors
    Partition 3 (NTFS (36.7 GB) I) Result: Failed with critical Errors
    Partition 4 (NTFS (39.4 GB) J) Result: Failed with critical Errors
    Recommendation:
    All selected physical diagnostics passed.
    System Information:
    BIOS Date 04/21/04
    IO Channel type PCI
    Drive Information:
    SIZE MODEL
    200 GB ST3200822AS
    Serial Number = 5LJ05V2Y
    Int13 Num = 80, PHYS CHS = 16383x16x63.
    ParmTable CHS, Rsvd = 24321x255x63
    # Type Start End MB
    PRIMARY
    1 NTFS 0 3267 26881 EXTENDED
    2 NTFS 3268 8527 43275 EXTENDED
    3 NTFS 8529 14573 49733 EXTENDED
    4 NTFS 14575 24320 80168
    Diagnostic Results:
    Recommendation:
    Short Test Begin: 11-May-2005 17:07:23
    Identify Data
    Model Number: ST3200822AS
    Serial Number: 5LJ05V2Y
    Firmware Revision: 3.01
    Total Capacity: 390721968 Sectors
    ID Method: Unknown
    SMART Check: Passed
    DST - Passed
    Total Bytes = 8666112
    Min: 2.28MB/s Max: 2.35MB/s Avg: 2.31MB/s
    Min: 77.89MB/s Max: 97.37MB/s Avg: 93.02MB/s
    SMART Check: Passed
    Short Test Passed: 11-May-2005 17:08:01
    Long Test Begin: 11-May-2005 17:08:03
    Identify Data
    ID Method: Unknown
    SMART Check: Passed
    Full Scan (0 to 390721968) - Passed
    Elapsed Time: 1.23 Hours
    Min: 47.78Mb/s Max: 610.90Mb/s Avg: 377.72Mb/s
    Total Bytes = 22108160
    Min: 2.36MB/s Max: 2.42MB/s Avg: 2.40MB/s
    Min: 89.09MB/s Max: 118.79MB/s Avg: 92.84MB/s
    Long Test Passed: 11-May-2005 18:22:12
    Partition 1 (NTFS (26.8 GB) ) Result: Failed with critical Errors
    Partition 2 (NTFS (43.2 GB) No Name) Result: Failed with critical Errors
    Partition 3 (NTFS (49.7 GB) No Name) Result: Failed with critical Errors
    Partition 4 (NTFS (80.1 GB) F) Result: Failed with critical Errors
    NOTE: Any report of possible errors in the file system tests are for
    informational purposes only. We suggest you should consider testing with
    the official file system diagnostic utilities for your operating system.
    Seagate is not able to assist with troubleshooting or reviewing
    file system test results.
    Recommendation:
    My reply to Seagate:
    What i'm seeing:
    Basic Controller Test Results = Unsupported (?)
    All Partitions failed.
    I am not trying to find fault with the HD's but trying to
    determine 2 things (so i can fix it, whatever the problem).
    1. Are the HD's operating in SATA mode (vs some other mode)?
    2. The reason for the increase in seek timing for the drives:
    Original HD from Gateway: 160GB, Seek time was 8.5 - now 13.4
    Original "Average Read" 120MB/s - now 45.3
    New Seagate HD: 200GB, Seek time 13.4, Average Read = 54.4
    The figures (above) just seem to be getting slower and slower as
    time passes. Three months from now, i'll probably be near ATA-33
    speed.
    Hopefully their next response will have a few more details.
    savagcl
  14. 2005/05/11
    Mattman,
    Good advice about the video drivers!
    I reloaded them and got an increase. Still not where it was on Apr 24 but
    better than 77MB's
    PCPitStop results:
    Date.........CPU........RAM.........Video
    .......Speed.....Speed......Speed
    .......(MIPS)....(MB/s)......(MB/s)
    May 11......5293......7383........117 (After reloading video driver.)
    May 11......5149......7140........77 (before reloading video driver.)
    Apr 24.......5366......7415........127 ( 10 fps diff probably due to new drivers
    I hope).
    Date.......Drive......Disk Speed
    ...........................(MB/s)
    May 11.....C:...........53
    Apr 24......C:...........54
    May 11.....D:...........50
    Apr 24......D:...........51
    May 11.....E:...........52
    Apr 24......E:...........51
    May 11.....F:...........45
    Apr 24......F:...........44
    May 11.....G:...........54
    Apr 24......G:...........52
    May 11.....H:...........49
    Apr 24......H:...........49
    May 11.....I:............44
    Apr 24......I:............44
    May 11.....J:............35
    Apr 24......J:............33
    Thanks for the tip about the video!!!!!
    savagcl
  15. 2005/05/12
    PCpitstop was your idea Clif. I thought it was a beauty. Thank yourself! :D
    The Seagate tests passed, but did not like the file system. Have you run chkdisk?
    As you have heard me say in your other threads "I hope it's not a Gateway thing" :) . After becoming the world's formost expert on drive speed and your system still going slower (it is getting worse and worse which would say to me that it is software rather than hardware or maybe the way the software controls the hardware). Consider getting a new motherboard. Find out the "form factor" of the current one, eg. a micro ATX, and replace it. It might be the "Gateway Blues" we are singing.
    Edit: If you decide on a new motherboard, you will need to find out the details of your CPU, also the RAM if it is not the standard DDR.
  16. 2005/05/12
    Christer
    Did You use the same utility to test the seek time?
    The referenced seek time (e.g. 8.5 ms) doesn't include rotational latency which on average is approximately 4.2 ms.
    8.5 + 4.2 = 12.7 ms including latency.
    Christer
  17. 2005/05/12
    Mattman,
    A new MB is not on my (money) plate at this time (but i'll keep it in the front
    of my mind). Spent a lot already this year, my better half would scalp me.
    Christer,
    Yes, same HdTach program used throughout.
    Seagates reply (at least response was in good time):
    Results from the Seatools test appear correct and are repporting the drive
    to be correct.
    The error regarding the failure of the Files Structure test are valid
    (Failed) because on NTFS partitions that do no support the file structure
    test.
    Are they saying that they do not support NTFS?
    savagcl
