Two operating systems
Discussion in 'Windows XP' started by whr, 2008/03/26.
  1. 2008/03/26
    whr
    whr Inactive Thread Starter
    I have acquired a used computer with 40g of hard drive ,512 mb ram.
    The problem this computer came with windows 2000. I loaded XP home
    and every thing workes fine. However,I now have both of the systems
    and would like to eliminate windows 2000. What did I do, and can I chang it?
    whr,
  2. 2008/03/26
    surferdude2
    surferdude2 Inactive
    You have two obvious choices,
    1. You can boot to XP and manually delete all of the files associated with the 2K system and then edit the 2K loader line out of the boot.ini file so the dual boot option is no longer offered.
    2. You can reinstall XP but this time choose to delete the existing system partition and create a new one. That will wipe all files from the drive and install XP cleanly. You'll lose 2K in the process and all other files that you don't back up.
    whr
    Two operaring systems
    Suferdude, Thanks for the reply. I must re access my knowledge level.
    Your #1 idea ,if I go to xp how do I delete the files on 2000.
    Then edit the 2ooo out of the boot?
    This may be beyond my level but thanks anyway:confused:
    whr,
    surferdude2
    If you have any doubts, option #2 is the way to go. Option #1 is not for the faint of heart and may require some hot licks not normally familiar to the less experienced user. If your computer is recently acquired, as you intimated, I would recommend option #1.
  6. 2008/03/28
    muzic
    muzic Inactive
    backup files in somewhere other than hard drive.
    Format the drive the Windows that are running, normally are C: and D:
    Reinstall XP SP2(i recommend). And enjoy.
    my idea is similar to option #2
    since i m kind of new to pc. u should try the more experience people's idea. ^^
  7. 2008/03/28
    pawankumarsingh
    pawankumarsingh Inactive
    pls go for restor windows 2000 restore cd.
  8. 2008/03/28
    whr
    Muzic, I have just changed my profile to, experience beginner.
    So now I can ask some dumb questions:Back up files, how?
    I will format the disk,how?
    I hope you are a person of patience. I do need help. tks.
    whr,
    #7
