Tweak UI problems
Discussion in 'Other PC Software' started by DugE, 2003/10/07.
  1. 2003/10/07
    DugE
    DugE Well-Known Member Thread Starter
    What did I do now? I used TweakUI and checked to have documents cleared upon startup so I wouldn't have to manually do it. That works fine but now I get that darn password thingy before Windows loads. I click cancel but it keeps coming up every start. I use to know how to remedy this problem but forgot. (old age has its disadvantages also)
    Also, when I click on my ISP icon to connect to the internet I have to type the password in every time and the save password box is grayed out so I can't save it. I use to know how to fix this too. Old age again. (I'm gonna start a diary for my problems so by this time next year I'll have a book for e-bay.)
    All advise appreciated. Thanks.
    -John
    DugE,
  2. 2003/10/07
    rcerrato
    rcerrato Inactive
    dopey
    On the parinoia tab make sure clear last user is disabled, then on the network tab enter your information to login.
    Save your settings for the connection to your ISP, then go to dial up networking and remove the connection to your ISP, then choose make new connection and recreate the connection.
    :eek:
    DugE
    Thanks rcerrato. So far so good.
    -John
    DugE,
    DugE
    Ok more problems with this: The start up log on box is taken care of but now I'm having all sorts of problems with networking.
    Dial up networking and my ISP logon is trying to connect to the internet at the same time. I went to the internet options and the do not dial my connection is still checked as always, so why is it trying to connect? Another thing, everytime I open Outlook Express I immediately lose my internet connection. None of this has ever happened before. All I did was install TweakUI, check the box to delete documents on startup and all havoc breaks loose. Can someone please get me straightened out? Thanks.
    -John
    DugE,
    DugE
    Update: I scaned for viruses and such but come up clean. I just said heck with this and did a scanreg/restore to before I installed TweakUI. Lost some minor info but nothing I can't easily replace so everything is running ok now. I don't know what caused these problems but I'm ok now.
    -John
    DugE,
    #5
