Turning off sound in dial up connection???
Discussion in 'Windows XP' started by Lucy, 2002/09/04.
  1. 2002/09/04
    Lucy
    Lucy Inactive Thread Starter
    Is there somewhere I can turn off sound for dial up connection???
    Have gone into audio sound etc., but cannot find anything related to dial up.
    Would appreciate any help on this.
    Thanks,
    Lucy
    Lucy,
  2. 2002/09/04
    Daizy
    Daizy Inactive
    Hi Lucy
    Have you gone into your Modem properties and checked to see if you can turn off the sound there?
    If no go......try this:
    Double Click on MY COMPUTER
    Double Click on CONTROL PANEL
    Double Click on MODEM
    Click ONCE on your MODEM so it turns BLUE
    Click on PROPERTIES
    Click on the tab labelled CONNECTION
    Click on button labelled ADVANCED
    Point and Click ONCE on EXTRA SETTINGS field so you can type
    In the EXTRA SETTINGS type one of the following:
    MO (2 letters) if you want to turn your MODEM SOUND OFF
    L1 (One letter, One Number), L2 or L3 to have different sound levels (Try each to see which one you like) for the MODEM SOUND ON.
    Click OK
    Close out of everything- You're ready to go.
    Daizy
    Lucy
    Daizy:
    I just want to change or eliminate the sound for dial-up connection, won't this change all sounds?????
    Little nervous on this one daizy, your dealing with a newbie, & I don't want to mess anything up, regarding sounds elswhere!!
    Thanks for reply, will go over your instructions with ????????
    Lucy:confused: :confused: :confused:
    Lucy,
    Daizy
    Daizy Inactive
    Nope Lucy....you're in the Modem properties....not the Windows Media sounds.
  6. 2002/09/04
    Daizy
    Daizy Inactive
    Go this far:
    Click on PROPERTIES
    See if there's a box to turn off the modem sound or volume?
  7. 2002/09/04
    Lucy
    OK Daizy, will give it a try!!
    Thanks again, & will get back if any more problems
    Lucy:)
    Lucy,
    #6
  8. 2002/09/04
    Daizy
    Daizy Inactive
    Please do post back once you check Lucy. Never be afraid to ask questions if you're unsure. You'll find many others will be reading this thread and learn from reading. I certainly have. :)
    Daizy
  9. 2002/09/04
    Lucy
    Daizy:
    Got as far as typing MO, but then when I tried to go on line again, it wouldn't dial up----
    What's happening????
    Lucy:confused:
    Lucy,
    #8
  10. 2002/09/04
    Daizy
    Daizy Inactive
    Lucy? Once you opened up properties....did you look around for a check box to uncheck for modem sound?
    Daizy
  11. 2002/09/04
    Lucy
    Daizy:
    Got it, typing in M0, now I don't have any sound at all!!!
    Maybe , (if I can find it again????) I will put in low level.
    Thanks so much Daizy, much appreciated.
    Lucy:) :) :)
  12. 2002/09/04
    Lucy
    Footnote to last post!
    Daizy:
    I was typing capital O instead of the number 0, that is why is didn't work the first time.
    Again, many thanks,
    Lucy
  13. 2002/09/04
    Daizy
    Daizy Inactive
    Well, that's great news Lucy! Congratulations...and thanks so much for taking the time to post back and let us know. :)
    Daizy
