Trouble with links using Internet Explorer 6.0
Discussion in 'Security and Privacy' started by flounderman, 2004/09/16.
  1. 2004/09/16
    flounderman
    flounderman Inactive Thread Starter
    Hi all!
    Every time I click on a link leading off of the site I am currently on, it opens up the page in a new window(a little smaller) and the original page closes! Therefore I cannot use the back button to go back to the original page. This only happens on links that are pointed to a different website, if it is an internal link to a different page on the same site(no matter what site I am on) there is no problem what so ever. If it sounds confusing, I'll be glad to try to explain it better. I have scanned w/ up to date versions of Adaware, Spybot, CW Shredder, Spyware Blaster & Mcaffe VS, all to no avail.I have also scanned w/HJT but I am not comfortable enough with the results to use it effectively on my own. If you would like to see a log, I will gladly post one!
    I've posted my problem on a few boards and never got any response,not even "Sorry dude your ******* "....
    Has anyone ever heard of a problem like this???
    Maybe yall have some ideas?!!
    Anyone???
    Appreciate any and all help &
    Thanks in Advance
  2. 2004/09/16
    flounderman - Welcome to the Board :)
    I've not come across that problem before - one thought would be to Repair IE. How that is done depends on which OS you are using, so please come back on this.
    Feel free to post an HJT log - if you do so your thread will be moved to Security/Virus/Spyware (standard Board procedure)
    flounderman
    Thanks for replying Pete, my OS is Win XP, and I think I'll hold off on an HJT log unless someone thinks it may help. Thanks again and I await your instructions to repair IE.
  5. 2004/09/16
    Welshjim
    Welshjim Inactive
    flounderman --Just checking. Are left clicking on the link, or right clicking|Open in New Window?
    Long shot--IE Tools|Internet Options|Advanced tab|Browsing section. See if changing the setting "Reuse window for launching shortcuts" helps. In other words change it from whatever if now is to the opposite.
  6. 2004/09/16
    Repairing IE in XP is not as straightforward as in previous versions of Windows. The Method in XP is given in this MS KB article .
    First step as per the article is to run System File Checker ....
    Start > Run > type in sfc /scannow - note the space. You will need your XP installation CD. SFC runs and closes - to see which files, if any, were replaced refer to Event Viewer - not that the file details will necessarily make a lot of sense :)
    If this doesn't cure the problem you will have to proceed to the second step.
    IE 6 SP 1 here
    If that doesn't work - or if no other solution is forthcoming on the Board, post an HJT log.
  7. 2004/09/18
    flounderman
    Thanks for the suggestions...
    I did the sfc/ scannow with no luck, i guess i will have to try the reinstall when i get home tonight! Is this what i have to do to have ie reinstalled correctly....
    When you try to reinstall the same version of Internet Explorer, you may receive the following error message:
    Setup has detected a newer version of Internet Explorer already installed on this system.
    Setup cannot continue.
    To avoid this error message and reinstall the same version of Internet Explorer and Outlook Express, follow these steps:
    While you are logged on as an administrator, click Start, and then click Run.
    In the Open box, type regedit, and then click OK.
    Locate the appropriate registry subkey, right-click the IsInstalled (REG_DWORD) value, and then click Modify.
    To reinstall only the Internet Explorer 6 browser component on Windows XP, use the following registry key:
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Active Setup\Installed Components\{89820200-ECBD-11cf-8B85-00AA005B4383}
    Thanks again
  8. 2004/09/18
    Welshjim
    Welshjim Inactive
    flounderman--Did you try what I first suggested
    It is simpler than a reinstallation.
    As far as that Registry fix, yes that is the one to delete, if you are told you cannot reinstall because you already have that (or a newer) version. Then your PC no longer thinks you have the newer version installed.
    But what about System Restore to a date before the problem started? A lot simpler than reinstalling. And how many times have you done a reboot? That often cures many problems.
  9. 2004/09/19
    flounderman
    IE Tools|Internet Options|Advanced tab|Browsing section->Reuse...
    was one of the first things I have tried...
    I have restarted numerous times...
    no restore points before 9/4, which is after this started...
    so I'm at a complete loss, :confused:
    looks like I'm gonna have to do a reinstall.
    What I don't really get is do I just go about installing IE 6.0 straight out like it is not already on my pc ,and not edit the registry unless I get that error....
    or do I have to regedit before I reinstall to make it work at all?
    :cool:
  10. 2004/09/19
    Welshjim
    Welshjim Inactive
    flounderman--Before you take IE off your PC, if that is the route you take, be sure you have IE on a CD or a full version of install files already downloaded to your Hard Drive (but not installed).
    In all honesty I have no idea what will happen if you just try a reinstall without taking the IE now on your PC off first. If you are dead set on reinstalling, I would think you would have nothing to lose.
    Maybe PeteC can comment.
    P.S. Did you ever post your HiJackThis log?
  12. 2004/09/19
    I have done this without any ill effect by right clicking the ie.inf file C:\WINDOWS\inf\ie.inf
    and selecting install.
    The first URL I posted in #9 uses the copy of IE on the Win XP CD.
  13. 2004/09/20
    flounderman
    I figured I would go ahead and post a HJT log before I reinstalled.
    See anything?
    Logfile of HijackThis v1.98.0
    Scan saved at 12:47:34 AM, on 9/20/2004
    Platform: Windows XP SP1 (WinNT 5.01.2600)
    MSIE: Internet Explorer v6.00 SP1 (6.00.2800.1106)
    C:\WINDOWS\system32\LEXBCES.EXE
    C:\WINDOWS\system32\LEXPPS.EXE
    C:\Program Files\McAfee\McAfee Privacy Service\GUARDDOG.EXE
    C:\WINDOWS\system32\cisvc.exe
    c:\PROGRA~1\mcafee.com\vso\mcvsrte.exe
    C:\PROGRA~1\McAfee.com\PERSON~1\MPFSERVICE.exe
    C:\PROGRA~1\McAfee\SPAMKI~1\MSKSrvr.exe
    C:\WINDOWS\system32\cidaemon.exe
    C:\PROGRA~1\mcafee.com\agent\mcagent.exe
    C:\PROGRA~1\McAfee\SPAMKI~1\MskAgent.exe
    C:\PROGRA~1\mcafee.com\vso\mcvsshld.exe
    c:\progra~1\mcafee.com\vso\mcvsescn.exe
    C:\PROGRA~1\McAfee.com\PERSON~1\MpfTray.exe
    C:\Program Files\McAfee\McAfee Shared Components\Guardian\CMGrdian.exe
    C:\Program Files\Java\j2re1.4.2_05\bin\jusched.exe
    C:\Program Files\QuickTime\qttask.exe
    C:\Program Files\Spybot - Search & Destroy\TeaTimer.exe
    C:\Program Files\SpywareGuard\sgmain.exe
    C:\PROGRA~1\McAfee.com\PERSON~1\MpfAgent.exe
    C:\Program Files\SpywareGuard\sgbhp.exe
    c:\progra~1\mcafee.com\vso\mcvsftsn.exe
    C:\Program Files\Yahoo!\Messenger\ymsgr_tray.exe
    c:\PROGRA~1\mcafee.com\vso\mcshield.exe
    C:\Program Files\HijackThis.exe
    R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://www.dellnet.com
    R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Bar = res://C:\WINDOWS\System32\cjgbep.dll/sp.html (obfuscated)
    R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.rr.com/flash/index.cfm
    R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Bar = res://C:\WINDOWS\System32\cjgbep.dll/sp.html (obfuscated)
    R0 - HKLM\Software\Microsoft\Internet Explorer\Search,SearchAssistant = res://C:\WINDOWS\System32\cjgbep.dll/sp.html (obfuscated)
    R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page_bak = about:blank
    R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyOverride = http://localhost
    R3 - Default URLSearchHook is missing
    O2 - BHO: Yahoo! Companion BHO - {02478D38-C3F9-4efb-9B51-7695ECA05670} - C:\Program Files\Yahoo!\Companion\Installs\cpn0\ycomp5_3_16_0.dll
    O2 - BHO: (no name) - {318A6A50-CDC7-47E2-96BE-CEAD59D36296} - C:\WINDOWS\System32\cjgbep.dll (file missing)
    O2 - BHO: SpywareGuardDLBLOCK.CBrowserHelper - {4A368E80-174F-4872-96B5-0B27DDD11DB2} - C:\Program Files\SpywareGuard\dlprotect.dll
    O2 - BHO: McAfee Privacy Service Helper Object - {cc4b2ee5-4803-11d7-8a38-00b0d0c6b814} - C:\Program Files\McAfee\McAfee Privacy Service\GDIEHELP.DLL
    O3 - Toolbar: &Radio - {8E718888-423F-11D2-876E-00A0C9082467} - C:\WINDOWS\System32\msdxm.ocx
    O3 - Toolbar: McAfee VirusScan - {BA52B914-B692-46c4-B683-905236F6F655} - c:\progra~1\mcafee.com\vso\mcvsshl.dll
    O4 - HKLM\..\Run: [DwlClient] C:\Program Files\Common Files\Dell\EUSW\Support.exe
    O4 - HKLM\..\Run: [MCUpdateExe] C:\PROGRA~1\McAfee.com\Agent\mcupdate.exe
    O4 - HKLM\..\Run: [MCAgentExe] c:\PROGRA~1\mcafee.com\agent\mcagent.exe
    O4 - HKLM\..\Run: [MSKAGENTEXE] C:\PROGRA~1\McAfee\SPAMKI~1\MskAgent.exe
    O4 - HKLM\..\Run: [VSOCheckTask] "c:\PROGRA~1\mcafee.com\vso\mcmnhdlr.exe" /checktask
    O4 - HKLM\..\Run: [VirusScan Online] "c:\PROGRA~1\mcafee.com\vso\mcvsshld.exe "
    O4 - HKLM\..\Run: [MPFTray] C:\PROGRA~1\McAfee.com\PERSON~1\MpfTray.exe
    O4 - HKLM\..\Run: [McAfee Guardian] C:\Program Files\McAfee\McAfee Shared Components\Guardian\CMGrdian.exe /SU
    O4 - HKLM\..\Run: [MSKDetectorExe] C:\PROGRA~1\McAfee\SPAMKI~1\MSKDetct.exe /startup
    O4 - HKLM\..\Run: [MSConfig] C:\WINDOWS\PCHealth\HelpCtr\Binaries\MSConfig.exe /auto
    O4 - HKLM\..\Run: [SunJavaUpdateSched] C:\Program Files\Java\j2re1.4.2_05\bin\jusched.exe
    O4 - HKCU\..\Run: [SpybotSD TeaTimer] C:\Program Files\Spybot - Search & Destroy\TeaTimer.exe
    O4 - HKCU\..\Run: [Yahoo! Pager] C:\Program Files\Yahoo!\Messenger\ypager.exe -quiet
    O4 - Startup: SpywareGuard.lnk = C:\Program Files\SpywareGuard\sgmain.exe
    O9 - Extra button: Messenger - {4528BBE0-4E08-11D5-AD55-00010333D0AD} - C:\Program Files\Yahoo!\Messenger\yhexbmes0521.dll
    O9 - Extra 'Tools' menuitem: Yahoo! Messenger - {4528BBE0-4E08-11D5-AD55-00010333D0AD} - C:\Program Files\Yahoo!\Messenger\yhexbmes0521.dll
    O9 - Extra button: Instant Messenger (SM) - {AC9E2541-2814-11d5-BC6D-00B0D0A1DE45} - C:\PROGRA~1\RRIM\aim.exe
    O9 - Extra button: Privacy Bar - {cc4b2ee5-4803-11d7-8a38-00b0d0c6b814} - C:\Program Files\McAfee\McAfee Privacy Service\GDIEHELP.DLL
    O9 - Extra button: Real.com - {CD67F990-D8E9-11d2-98FE-00C0F0318AFE} - C:\WINDOWS\System32\Shdocvw.dll
    O16 - DPF: Yahoo! Blackjack - http://download.games.yahoo.com/games/clients/y/jt0_x.cab
    O16 - DPF: Yahoo! Chat - http://us.chat1.yimg.com/us.yimg.com/i/chat/applet/c381/chat.cab
    O16 - DPF: Yahoo! Dominoes - http://download.games.yahoo.com/games/clients/y/dot2_x.cab
    O16 - DPF: Yahoo! Fleet - http://download.games.yahoo.com/games/clients/y/fltt3_x.cab
    O16 - DPF: Yahoo! Go Fish - http://download.games.yahoo.com/games/clients/y/zt3_x.cab
    O16 - DPF: Yahoo! Klondike Solitaire - http://yog55.games.scd.yahoo.com/yog/y/ks12_x.cab
    O16 - DPF: Yahoo! Literati - http://download.games.yahoo.com/games/clients/y/tt0_x.cab
    O16 - DPF: Yahoo! Poker - http://download.games.yahoo.com/games/clients/y/pt0_x.cab
    O16 - DPF: Yahoo! Pool 2 - http://download.games.yahoo.com/games/clients/y/potb_x.cab
    O16 - DPF: {07637823-C894-4A52-B3F9-5D777FD8E36A} - http://www.mydailyhoroscope.net/mdh/install.cab
    O16 - DPF: {09C6CAC0-936E-40A0-BC26-707480103DC3} (shizmoo Class) - http://www.uproar.com/applets/activex/shizmoo/flipside_web18.cab
    O16 - DPF: {0C568603-D79D-11D2-87A7-00C04FF158BB} (BrowseFolderPopup Class) - http://download.mcafee.com/molbin/Shared/MGBrwFld.cab
    O16 - DPF: {0E5F0222-96B9-11D3-8997-00104BD12D94} (PCPitstop Utility) - http://pcpitstop.com/pcpitstop/PCPitStop.CAB
    O16 - DPF: {0FFFFFFF-0FFF-0FFF-0FFF-0FFFFFFFFFFF} - http://www.upp2ono41xi9rman2.com/ff/inst.exe
    O16 - DPF: {1239CC52-59EF-4DFA-8C61-90FFA846DF7E} (Musicnotes Viewer) - http://www.musicnotes.com/download/mnviewer.cab
    O16 - DPF: {2B323CD9-50E3-11D3-9466-00A0C9700498} (Yahoo! Audio Conferencing) - http://us.chat1.yimg.com/us.yimg.com/i/chat/applet/v45/yacscom.cab
    O16 - DPF: {4169B5A0-9048-11D6-BDFF-00C0F024AF20} (ActiveXTester.TesterControl) - http://www.jasons-toolbox.com/BrowserSecurity/ActiveXTester/ActiveXTester.ocx
    O16 - DPF: {4A3CF76B-EC7A-405D-A67D-8DC6B52AB35B} (QDiagAOLCCUpdateObj Class) - http://aolcc.aol.com/computercheckup/qdiagcc.cab
    O16 - DPF: {74D05D43-3236-11D4-BDCD-00C04F9A3B61} (HouseCall Control) - http://a840.g.akamai.net/7/840/537/7d90ae05585062/housecall.antivirus.com/housecall/xscan53.cab
    O16 - DPF: {7B297BFD-85E4-4092-B2AF-16A91B2EA103} (WScanCtl Class) - http://www3.ca.com/threatinfo/virusinfo/webscan.cab
    O16 - DPF: {7D1E9C49-BD6A-11D3-87A8-009027A35D73} (Yahoo! Audio UI1) - http://chat.yahoo.com/cab/yacsui.cab
    O16 - DPF: {80DD2229-B8E4-4C77-B72F-F22972D723EA} (AvxScanOnline Control) - http://www.bitdefender.com/scan/Msie/bitdefender.cab
    O16 - DPF: {8E28B3A9-FE83-45D1-B657-D5426B81A121} (CustomerCtrl Class) - https://cs8b.instantservice.com/jars/customerxsigned41.cab
    O16 - DPF: {9A9307A0-7DA4-4DAF-B042-5009F29E09E1} (ActiveScan Installer Class) - http://www.pandasoftware.com/activescan/as5/asinst.cab
    O16 - DPF: {B9191F79-5613-4C76-AA2A-398534BB8999} (YAddBook Class) - http://us.dl1.yimg.com/download.yahoo.com/dl/installs/suite/yautocomplete.cab
    O16 - DPF: {BCC0FF27-31D9-4614-A68E-C18E1ADA4389} (DwnldGroupMgr Class) - http://download.mcafee.com/molbin/shared/mcgdmgr/en-us/1,0,0,19/mcgdmgr.cab
    O16 - DPF: {E0CE16CB-741C-4B24-8D04-A817856E07F4} - http://cabs.media-motor.net/cabs/chedownzip.cab
    O16 - DPF: {EF99BD32-C1FB-11D2-892F-0090271D4F88} (Yahoo! Toolbar) - http://us.dl1.yimg.com/download.yahoo.com/dl/toolbar/ym/yiebio5_1_3_0.cab
    O16 - DPF: {F54C1137-5E34-4B95-95A5-BA56D4D8D743} (Secure Delivery) - http://www.gamespot.com/KDX22/download/kdx.cab
  14. 2004/09/20
    flounderman - hold off on any fix attempts for right now. You do have a couple of baddies showing up and they could easily be causing your problem.
    I'm moving this to security. One note - you should get the latest 1.98.2 version of Hijackthis before you are asked to post the next log file.
  15. 2004/09/22
    flounderman
    Here is a log from the newer version of HJT...
    I see a few of the obvious things but would like some advice
    before going to work on it.
    Can anyone help?
    Logfile of HijackThis v1.98.2
    Scan saved at 1:45:15 AM, on 9/22/2004
    c:\program files\mcafee.com\vso\mcvsshld.exe
    C:\Program Files\Real\RealPlayer\RealPlay.exe
    C:\Program Files\Mozilla Firefox\firefox.exe
    C:\Documents and Settings\Michael Landry\Desktop\HijackThis.exe
    O4 - HKLM\..\Run: [McRegWiz] C:\PROGRA~1\McAfee.com\Agent\McRegWiz.exe /autorun
    O9 - Extra button: Instant Messenger (SM) - {AC9E2541-2814-11d5-BC6D-00B0D0A1DE45} - C:\Program Files\RRIM\aim.exe
