trouble with gif images
Discussion in 'Windows XP' started by chikid68, 2006/05/04.
  1. 2006/05/04
    chikid68
    chikid68 Inactive Thread Starter
    I am asking this for a friend who has a compac pressario with win XP sp1.
    She recently had to put it in the shop after a virus related problem and they had to do a destructive recovery(reformat and reinstall os) but when she got it back she has discovered that she is having a problem saving animated gif images she can save them as gifs but they will not animate.
    she is really into gif animation so she wos wondering if this is some kind of setting problem or what. If it is a setting then how and where does she need to change the setting and allow her to save animations again? thanks in advance .
  2. 2006/05/04
    ReggieB
    ReggieB Inactive Alumni
    What program is she using to view the GIFs?
    chikid68
    I believe that she is just using Internet explorer since that is generally the default program for viewing images .
  5. 2006/05/05
    bluzkat
    bluzkat Inactive
    chikid68,
    Here's a *free* graphics program that will allow your friend to view animated .gifs
    Irfanview
    Download the extra plugins also. This is an amazing program. Hope you enjoy it.
    B :cool:
  6. 2006/05/05
    chikid68
    she is able to view them fine but her problem is that when she saves them they are no longer animated but rather static when she opens them again.
  7. 2006/05/06
    Welshjim
    Welshjim Inactive
    chikid68--She is sure she is Saving As .gif ? It is easy to overlook what is in the "Save as type" line.
    Just to test where the problem might be, if she is saving as .gif, suggest she use Irfanview.
  8. 2006/05/07
    chikid68
    she has it doinbg fine now it turns out that she was opening and saving using her photo program and it doesnt support animation now she uses IE to open and save gifs at least .
    thanks for all the help that was given :D :D
  9. 2006/05/08
    Welshjim
    Welshjim Inactive
    chikid68--Thanks for posting back with the outcome.
