Trouble opening explorer
Discussion in 'Windows XP' started by floyd, 2003/07/22.
  1. 2003/07/22
    floyd
    floyd Well-Known Member Thread Starter
    I had to reformat my laptop for a problem, but now whenever I try to open explorer it opens it in a search window. If I right click on drive C: for instance the "Search" function in in black and all the others including "Explore" are in lighter text. If I manually select "Explore" from this right click menu it will open properly. I've tried everything I can think of and it's driving me nuts. I've never seen this before. Can anyone help and save my sanity(what little is left).
    Floyd
  2. 2003/07/22
    Abraxas
    Abraxas Inactive
    floyd
    ABRAXAS,
    Thank you, thank you. You saved my sanity. It worked as slick as could be.
    Thank you again
    Floyd
