Trojan in System Volume Info
Discussion in 'Windows XP' started by Torquemada, 2004/08/08.
  1. 2004/08/08
    Torquemada
    Torquemada Inactive Thread Starter
    I have the free AVG virus scan because ezTrust antivirus would not respond to my repeated requests for support. So much for them.AVG is reporting I have a virus Trojan-Startpate.7.ac in a C:\System Volume Information\_restore{blah-blah-blah}\blah\A000659.exe file and I should run their software to delete it . I do. It doesn't.
    Question: how or can I FIND this darn exe file and delete it myself? I made the system files visible in Explorer options to no avail.
    THis is XP Pro, recently purchased. Merci beaucoup.
  2. 2004/08/08
    Zander
    Zander Geek Member Alumni
    The virus is in your system restore files. To get rid of it, turn off system restore. Right click on my computer>properties>system restore. Turning it off will delete all of your restore points. After you've turned it off, don't forget to turn it back on again.
