Transferred RegSeeker Wont Work
Discussion in 'Other PC Software' started by derfsch, 2007/02/05.
  1. 2007/02/05
    derfsch
    derfsch Well-Known Member Thread Starter
    Hi All,
    In trying to help a friend (no access to the internet) remove a corrupted program from his computer I ran into the following situation. When I copy RegSeeker to a floppy or a CD and attempt to remove registry items using either of these mediums, the program works up until the final removal (deletion) and then I get a message in French and English which denies the deletion. The same RegSeeker program works fine on my computer. Each computer uses WindowsXP Pro. Any suggestions as to what I might be doing wrong or a work around.
  2. 2007/02/05
    TeMerc
    TeMerc Inactive Alumni
    Which edition are you using? I beleive there was a bug with 1.51 which was fixed with 1.52. But to be honest I can't be sure, but there was a lengthy discussion over in this DSLR thread
    Is the friends computer running XP?
  5. 2007/02/06
    derfsch
    TeMerc and Steve,
    Thank you for the prompt responses. To answer your questions: I downloaded and installed version 1.52 to my computer and this is what I copied to the floppy and CD. Yes my friend's computer is running WindowsXP.
  6. 2007/02/06
    charlesvar
    charlesvar Inactive Alumni
    Are you running it from the floppy or CD? If you are, why not run it from the HD?
    Regards - Charles
  7. 2007/02/07
    derfsch
    Charles,
    Your suggestion worked. I brought my friend's computer to my house and hooked it up to my ISP. Then I downloaded Regseeker and left it on his hard drive. Regseeker performed great and I was able to remove the leftover bits from his bad program. He will give me a report on his computer operation but from what I see everything looks good.
    Thank you all for your interest and support.
