Toolbars keep reseting to seperate rows!!
Discussion in 'Internet Explorer & Microsoft Edge' started by baltman, 2002/07/17.
  1. 2002/07/17
    baltman
    baltman Inactive Thread Starter
    hi my IE 6.0 toolbars won't stay in the same row for very long. i like them all in the same row to keep maximal viewing space available, but every so often they reset and all 3 toolbars go to seperate lines. any idea how to stop this?!
    thanks!
  2. 2002/07/17
    Daizy
    Daizy Inactive
    Hi baltman
    Did you try right clicking on a blank spot of one of your toolbars and choosing to "Lock the toolbars "?
    Daizy
    brett
    brett Inactive Alumni
    Right-click IE's toolbar and select "Lock ".
  5. 2002/07/17
    Daizy
    Daizy Inactive
    :D :D :D
    Great idea Brett! :D
  6. 2002/07/17
    baltman
    It does this EVEN WITH the lock :'(
    It does this EVEN WITH the lock :'( any ideas?
  7. 2002/07/17
    Daizy
    Daizy Inactive
    It was Brett's idea! :D :rolleyes:
    Lame try but......
    What if you were to uncheck them all......reboot...and try again?
  8. 2002/07/17
    brett
    Install TweakUI and under the Explorer tab check "Save Explorer windows settings ". If you already have TweakUI and this option is checked, uncheck it, arrange your toolbars and then re-check it.
    If this does not work, blame Daizy :D
  9. 2002/07/17
    Daizy
    Daizy Inactive
    :rolleyes:
    Ohhhhh he's full of ummmmmmm advice tonight isn't he? :D
    Uncheck and re-check. How freaking original is THAT brett? :D
    Btw......if it works.....let's call me a genius......ok? :p
  10. 2002/07/17
    baltman
    I wish I could say that helped, but it didn't. I think I have an idea of how to fix it though! Here it is...
    Buy OSX and a shiney new Macintosh! Eh?
  11. 2002/07/18
    brett
    A slight variation on the previous suggestion - check that TweakUI is set to save windows settings. Close all of your Toolbars, leaving a bare Taskbar. Reboot. Set up your Toolbars again.
    If this doesn't work, I'm stumped :(
