Timbuktu Pro
Discussion in 'Networking (Hardware & Software)' started by SudoTech, 2003/05/02.
  1. 2003/05/02
    SudoTech
    SudoTech Inactive Thread Starter
    OK,
    Here's a kicker. I would like to access my work PC from my Apple laptop. I downloaded and tried Timbuktu Pro since it has full cross platform functionality. HOWEVER, due to the port usage requirements of TB2 it requires me to open my firewall (Linksys router) via port forwarding on a fairly broade range of ports (like 400 ports!). OK, no problem I say, so I set it up.
    Now, I discovered a few things. One is that it works pretty good on my LAN. Two is that it works good through the router and back again. (I ran a test on my LAN IP and on my WAN IP both). BUT, I also learned that the client connection, (like my home cable internet connection, which is on a router/firewall too), must also be open on those (400!) ports.
    I put it off for the night because I'm frustrated and tired of playing for a while.
    Now this morning when I get to work, my ZAPro software notifies me of several port access attempts in that range during the night. This alarms me since I've done a really good job so far keeping our little network locked down tight (despite the P.O.S. Linksys router which I will never buy again, but that's another story entirely).
    SO, gentlemen and ladies of True Geek status, what are my options? I know windows puts out a WRM client for the Mac which works on W2K and WXP but have read that it only barely works if it does at all.
    I have a pretty heavy regular job descrition as is and this network/computer tech stuff is pretty low on my list of priorities. I need practical solutions for a practical do-it-yourself guy.
    And so,
    Talk to me guys.
    Thanks!
    Nate
    P.S. - My other option, which I am very fond of, but do not yet have a budget for, is to have an SQL database developed with a web interface front end for remote access and management.
    If anybody is capable, experienced, interested and serious please feel free to e-mail me as I need estimates to submit to the HMFIC and already have a large amount of initial idea work done. It's for a small-medium size construction firm/cabinet shop.
  2. 2003/05/02
    I hope we have some Apple expertise looking in here but probably not. The extent of my knowledge (at least more recent than Apple-II) is how to spell it.
    You really might so better with this particular question on an Apple forum since they are usually forced to deal with M$ equipment and may be able to help you out.
    And Yup - if you had to open up 400+ ports and leave em open, not surprised you had problems. If both machines have static IP addresses, you should be able to tell the firewalls to bypass any protection from that specific address though.
