Thoughts reading in Windows XP sp2 :-) Problem with SunGlance.
Discussion in 'Other PC Software' started by Jack Roberts, 2005/02/23.
  1. 2005/02/23
    Jack Roberts
    Jack Roberts Inactive Thread Starter
    Yesterday I read an article on one if computer news site describing an interesting program - SunGlance. Well, this soft can't actually read thoughts but does almost the same. Here is the short description from their site:
    What do you do when you want to open a file or run a program you need? In most cases, you start on your journey through numerous folders and subfolders or wander about countless items in Start menu. Do you remember such situations when you have even forgotten what you need while searching for the necessary file in the thorny tree of your file system? Fancy another picture. Suppose you want to open some document. Of course, you know its name or some part of name. You click with middle mouse button or double-press CTRL key and quickly type the name of the file you need. You do not ever guess about where this file could be. Less than in a second you get exactly the very thing you need. Maybe there are thousands of files with similar names but you always see exactly what you need.
    It is very interesting idea so I downloaded this program from here: http://www.qwertystudios.com/sg/SunGlance.exe
    However, it shoes standard Windows error dialog and won't run. Do anybody use this proggy? Is it really like they write? How can I make it run properly?
  2. 2005/02/23
    JoeHobart
    JoeHobart Inactive Alumni
    i havent used it, but what error does it throw?
    Since the app costs you $30 it should have decent tech support. Have you tried them yet?
    Jack Roberts
    Solved!
    I addressed their support. They solved everythink. This is superb program! Hundred times better Google Desktop. Recommend to everybody.
