Teatimer Problem
Discussion in 'Security and Privacy' started by Husni, 2005/09/11.
  1. 2005/09/11
    Husni
    Husni Inactive Thread Starter
    Hi,
    Lately I can’t control Teatimer, a resident part of Spybot S&D. I’m using Spybot S&D version 1.4 on Windows 98 SE. Each time Teatimer running to allow or block any changes when installing new proggie, I can not choose any option because the option on the lower right part of Teatimer is unreadable or garble. I don’t know what is causing this problem or since when or after I installing what proggies.
    Any suggestion how to fix this problem?
    TIA,
    Hushni
  2. 2005/09/12
    oshwyn5
    oshwyn5 Inactive
    Run Spybot, choose view/ advanced mode
    choose tools/ resident shield
    It will open a box you can uncheck the use teatimer
    NOw you close and do your thing.
