Resolved Taskbar-The Audio Service is not running..
Discussion in 'Windows 7' started by mhein, 2011/04/11.
  1. 2011/04/11
    mhein
    mhein Well-Known Member Thread Starter
    Hi Gang,
    I'm running Win7 Pro SP1, on an MSI P6NGM Motherboard, Intel Dual core E2180, 4GB Memory, and using NVidia on board sound card and the latest Vista/Win7 NVidia software (drivers).
    A good 1/2 the time the speaker icon in the taskbar shows a white x in a red circle. When passing the cursor over the icon I see the message "The Audio System is not running. ".
    The NVidia software includes both "Digital Audio-S/PDIF (Ready)" and "Speakers (Default Device)" options. I do not use the S/PDIF, but rather Default Device exclusively and am always getting sound from my speakers (and the quality always in line with my NVidia Equalizer software personal settings) , despite the warning.
    Any ideas on the cause of this situation will be (as always) greatly appreciated....
  2. 2011/04/11
    Hi mhein. Check to see if the Windows Audio service is running and is on Automatic. To do this click Start< Run and type services.msc and hit enter. When the Services window comes up scroll down and ensure that the Windows Audio service is set to Automatic and is started. If its not started right click the service and click properties. Under Startup Type set it to Automatic and when done click ok to close the window.
    You'll have to disable the device that you don't use. From the Sound applet in Control Panel, right-click the device you're not using and select disable.
    mhein
    Hi Guys,
    First, thanks for your speedy responses!
    I checked the Windows Audio Service and it's already set to Automatic. I just right clicked on the Taskbar icon and disabled the Digital Audio-S/PDIF.
    Nothing has changed yet, but I'm assuming they probably will on the next re-boot.
    On other thing... the NVidia/Windows software includes microphones(for 2 ports), line-in, and headphones displays.
    When installing my Motherboard and all the other physical goodies as well, I simply used the splitter I had for my former Soundblaster Sound card for my headphones.
    So it may be that I will continue to get this warning symbol unless I disable all the features I don't use.
    Many thanks again for your help!
