Task Manager Problem :(
Discussion in 'Legacy Windows' started by shadow558525, 2002/09/11.
  1. 2002/09/11
    shadow558525
    shadow558525 Inactive Thread Starter
    When I use the 3-Finger-Salute (Ctrl+Alt+Del) or Right-Click Taskbar + Task Manager, the Task Manager option is not enabled, greyed out ... I cant force close programs or check procedures or anything. and i use that feature extensively... How can I re-enable it. (BTW I am logged in as the Administrator when I have this problem my other accounts are fine... I use adminitrator frequently though so I need this option...)
    -Master Ian
    -master_ian@cox.net
  2. 2002/09/12
    Bursley
    sounds to me like you got a policy in place. check your local security policy.
    shadow558525
    Reply ... what?
    what are you talking about? I'm logged in as the admin but HOW DO I get the task manager function back. whats a policy?
  5. 2002/09/19
    shadow558525
    HEY
    ANSWER whats wrong???
  6. 2002/09/20
    whitesand
    whitesand Inactive
    Goto start, run then type taskmgr
    What happens?
  7. 2002/09/20
    shadow558525
    question reply
    says that The task manager has been disabled by the administrator ... but i didn't i'll check the settings..
  8. 2002/09/20
    shadow558525
    is anyone gonna help or not! i've waited for awhile!
  9. 2002/10/08
    o_XuXa
    o_XuXa Inactive
    Try this
    You can find good tips about Rwindows in www.ntfaq.com;
    Try to do this:
    Open the REGEDIT
    Go to key HKEY_CURRENT_USER\Software\Microsoft\windows\currentversion\Policies\System
    And verify if exist a DWORD Value called DisableTaskMgr, if exist set to 0 or delete this.
    Exit REGEDIT and try to open Taskmanager
    Regards,
    __________________________________________________
    Not certified in anything, only work with this Operating System
  10. 2002/10/08
    o_XuXa - good idea. And welcome to you.
    The original poster said (in another thread) that he has fixed the problem (wasn't too specific as to how though) using policy manager I think.
    #9
