Task manager and regedit won't stay open
Discussion in 'Windows XP' started by marks910, 2003/08/06.
  1. 2003/08/06
    marks910
    marks910 Inactive Thread Starter
    they close up a split second after i open them. i got a program manager and pretty much narrowed it down to the msconfig32.exe file. when i shut that down, my regedit and task manager stay up. i've tried norton, housecall, pc cillin, avg, and they haven't picked up anything. can anyone offer some help short of formatting?
  2. 2003/08/06
    Paul
    Paul Inactive
    Mark,
    Welcome to the forum!
    If you know the approximate time this problem started, I'd suggest you roll your system back using system restore if you have restore points going back far enough?
    Remember though that any programme installs and updates (windows updates etc) after that restore point will need reinstalling. Failing this you may have to look at doing a repair install of XP. Post back for details on this if you decide to go down this path.
    Paul,
    Abraxas
    Abraxas Inactive
    dkline
    dkline Inactive
    Also do a virus check. I had that problem and tried everything -- extracting a new version of msconfig, etc. It finally turned out to be a virus (specifically, the w32.spybot.worm and backdoor.sdbot viruses).
  6. 2003/08/10
    marks910
    turned out to be w32.spybot.worm and w32.tzet.worm. any good free antivirus programs out there. the norton i d/l couldn't detect it. but nortons online scanner found it.
  7. 2003/08/10
    Abraxas
    Abraxas Inactive
    marks910
    found this through norton online scanner, housecall didn't pick it up.
    C:\WINDOWS\system32\mm\explorer.sys is infected with W32.Tzet.Worm
    any ideas how to get rid/clean it?
  9. 2003/08/10
    Abraxas
    Abraxas Inactive
    Explorer.sys is not a Windows file so you can delete it.
  10. 2003/08/10
    dkline
    dkline Inactive
    You need an anti-virus program that will automatically quarantine and then delete all infected files. What's the cost compared to the labor time you're spending trying to deal with the problem on your own?
  11. 2003/08/10
    Dennis L Inactive Alumni
    Hi marks910
    Have you read Symantic Security response for this virus. About 2/3rd's down the page is "removal instructions ". Does not appear be be a downloadable "run and fix ".
    Added note to "Abraxas" 1st posting (23:22).....
    If on XP
    If you subscribe to "auto updates"
    You had the opportunity to apply 823980 Hotfix update about middle of July.
  12. 2003/08/12
    Hi marks10
    Don't know where you are in fixing your problem, but did notice
    W32.Blaster.Worm Removal Tool from Symantec is now available. Hope this helps if your still looking for a cure.
