System32\System file missing or corrupt
Discussion in 'Windows XP' started by MattRyan, 2005/04/07.
  1. 2005/04/07
    MattRyan
    MattRyan Inactive Thread Starter
    Has anyone else run into this error message at boot-up, which keeps Windows from starting/running?
    Any fixes?
  2. 2005/04/07
    NetDoc
    NetDoc Inactive
    What is the actual file that is missing?
    DRD
    MattRyan
    \Windows\System32\Config\System
  5. 2005/04/07
    surferdude2
    surferdude2 Inactive
    That's a Registry hive and usually requires a full clean install to fix.
    If you need to backup any data, you'll have to use 3rd party help such a drive imaging software. That assumes you have the NTFS file system. If you use FAT32, it's much easier.
    MS actually offers a sort of feeble attempt at your situation that might allow for data recovery but I have never heard anyone brag about it.
    Also, you should try System Restore just for laughs.
