System won't poweroff
Discussion in 'Windows XP' started by Jayman007, 2010/06/28.
  1. 2010/06/28
    Jayman007
    Jayman007 Inactive Thread Starter
    My computer always restarts when I shutdown/hibernate/standby. It completes the process without issue but laptop just doesn't poweroff. I have turned off the feature to restart on error but doesn't help. I don't have the roxio software installed which is known to cause such issues.
    I should add that this problem started several months ago when I switched out the motherboard on my laptop. I thought maybe it was a hardware issue up until I started another post about my recent woes with an svchost error. For some reason, the problem seemed to have gone away when I started having the svchost issue. But now that everything is fixed the poweroff issue is back. Now I know it can be fixed since I saw for several days it was working correctly.
    Any help or suggestions would be greatly appreciated.
    I have a Dell inspiron e1505 running Windows XP ME Sp3.
  2. 2010/06/28
    Hi, have you had a look in BIOS to see if ACPI is set correctly?
    Are you running XP & ME on the laptop together?
    It would help others if you entered your System Details in your User CP. Neil.
    markp62
    markp62 Geek Member Alumni
    "I should add that this problem started several months ago when I switched out the motherboard on my laptop. "
    Have you installed the motherboard drivers? If so, perhaps a trip to the manufacture's website for updated drivers?
  5. 2010/06/29
    Jayman007
    I'm running XP Media Edition SP3. I have checked the bios settings and all looks correct. I will have another look as well as add info to my user cp.
    Thanks.
  6. 2010/06/29
    Jayman007
    I have installed all the latest drivers from Dell for my machine. I have run driver genius and everything says it's updated.
