System will not boot, need to replace a file
Discussion in 'Windows XP' started by courious george, 2005/03/10.
  1. 2005/03/10
    courious george
    courious george Inactive Thread Starter
    When I try to boot i get the following message:
    WINDOWS COULD NOT START BECAUSE THE FOLLOWING FILE IS MISSING OR CORRUPT
    \windows\system32\config\system
    How can I replace this file without reinstalling windows and losing my orignal
    setup.
    I have tried to copy but i don't know where to get this file from on the installation CD.
    I have tried to run "SFC /scannow" but it will not run from the command prompt given
    in the repair mode. or from a batch file.
  2. 2005/03/10
    surferdude2
    surferdude2 Inactive
    That's not good George. You have your work cut out for you since it indicates that a Registry hive is corrupt or missing. A full functional repair is hardly ever likely and you will probably have to reinstall the system clean to get back fully. You can however do a procedure that may get you going well enough to copy some of your valued files to another media or partition.
    Here's the dirty details.
    courious george
    damage assessment
    This is a good start, Thanks for the info
    Is this issue isolated to this file alone or are there other hiden issues in the registery.
    Or is this the registery.
    If I make a back up of the drive could I go in and edit the old registery to collect any missing settings?
  5. 2005/03/11
    surferdude2
    The Registry in NT and XP is not a single file but rather several files called hives.
    The Registry hives are cache type files (soak up data like a sponge). Within them resides the various data bits and strings that allow the system to operate smoothly. The well known ones are:
    SYSTEM
    SOFTWARE
    SECURITY
    SAM
    You'll find them and others in the folder C:\WINDOWS\SYSTEM32\config
    They are not directly editable outside of the windows OS that they pertain to. You can make backups of them if you use a tool designed for the purpose. Normal copy methods will not work since they will produce an error that lets you know the file is in use.
    The Registry is so dynamic you would have to be careful about restoring it lest you end up crippling your system.
    I suggest partition images instead. Makes for better backups all the way around.
  6. 2005/03/11
    courious george
    continuing repair
    Ok I have a windows System up again.
    I am noticing registery issues.
    An idea:
    When I did the repair I renamed the old system file to system.bak.
    Would it be possible to swap names on these files and now use a repair utility such as "Registry First Aid" to correct the old register.
  7. 2005/03/11
    surferdude2
    I think Registry First aid has to run in Windows doesn't it? If that be true and your old Registry isn't bootable, you got yourself a catch 22, what?
  8. 2005/03/11
    courious george
    May be not, If I do as follows:
    1) in a working system get and load "Registry first aid "
    2) rename system to system.1
    3) rename system.bak to system
    4) WITHOUT rebooting run "registry first aid "
    5) reboot
    if the system fails to boot I can always rename system to system.bak
    and system.1 to system to recover.
    The trick here is to make the switch without using the system file????
  9. 2005/03/11
    surferdude2
    You can't do the switch while booted to Windows - you'll get the "File in use" error. :eek:
