system tray and screen size
Discussion in 'Legacy Windows' started by jhor9, 2003/07/09.
  1. 2003/07/09
    jhor9
    jhor9 Inactive Thread Starter
    I have 2 questions (I just found this website)
    1. How can I delete icons on the system tray at the bottom of my screen, without uninstalling the program?
    2, How can I expand my screen about 1" at the bottom (vertically) of my screen?
  2. 2003/07/09
    markp62
    markp62 Geek Member Alumni
    1. You mean that you do not want the program running at startup? Start\Run, type in Msconfig, press Enter, click on Startup tab, uncheck the ones you do not want.
    2. That would be adjusting the screen on the monitor, using it's buttons. As to which ones, depends on the monitor. These are sometimes hidden behind a door on the front, or may be right in front of you.
