system restore ...
Discussion in 'Windows XP' started by dinesh, 2006/09/13.
  1. 2006/09/13
    dinesh
    dinesh Inactive Thread Starter
    when i try to do system restore going to start>programs>accesaries>system tools>system restore the error given is :
    system is not able to protect your computer, restart your computer
    the i tried
    control panel > admin tools > services > and clicked start
    can't start system restore service on local computer
    i tried to search for sr.inf file to reinstall
    but, the file was not found
    i also tried starting "remote access connection manager "
    nothing worked
    can someone "help me"
    the root of the problem was crashing of my laptop few months back
    error was windows couldn't start as couldn't find the file system32/config/system was corrupt
    was totally confused
    then after doing online searching, i deleted the old files and copied them from the xp -cd
    but then i can't see anything from my good old days
  2. 2006/09/13
    Bill Castner
    Bill Castner Inactive
    I am not certain what was done. Whatever it was your orignal error indicates a corrupt registry hive. The repair is to restore the Hive using Recovery Console followed by the System Restore points in the System Volume Information folder. A Guided Walk-through of the process: http://support.microsoft.com/default.aspx?scid=kb;en-us;Q307545
    I recommend visiting MS-MVP Bert Kinney's site. Bert has studied System Restore and written quite a comprehensive site discussing its use, repair and foibles: http://bertk.mvps.org/
    Bert monitors the System Restore forum on AUMHA if you have further questions: http://aumha.net/
