System Restore won't create point
Discussion in 'Windows XP' started by janeil14, 2003/08/15.
  1. 2003/08/15
    janeil14
    janeil14 Inactive Thread Starter
    I recently reinstalled xp completely on my cpu now the system restore won't allow me to create a point in it. It hasn't even created one itself.what do I do???:mad: :confused:
  2. 2003/08/15
    charlesvar
    charlesvar Inactive Alumni
    werbra
    werbra Inactive
    Hi, janeil14,
    try the following link:
    http://www.dougknox.com/index.html
    and look for a small freeware proggy (20Kb) called "SystemRestorePoint ". running this little beauty creates a restore point and gives you the possibility to make comments;
    regards,
    werner
  5. 2003/08/20
    r.leale Lifetime Subscription
    r.leale Well-Known Member
    Hullo Janeil14,
    Are you sure that you have system restore enabled?
    Go to Control Panel>System>System Restore and check that System Restore has not been turned off and if it has, select the drives that you wish to be monitored.
    Good luck,
    Roger
