System restarts constantly when logging on
Discussion in 'Windows XP' started by rcknrbn, 2004/07/01.
  1. 2004/07/01
    rcknrbn
    rcknrbn Inactive Thread Starter
    My son's e-machine running Windows XP had a brief power failure last evening. The computer was running at the time. Ever since then, it will go to the log in screen like normal. After putting in his password, it states "loading personal settings" and then the screen freezes for about 10 seconds, it restarts and brings you right back to the login screen.
    He can't get into the operating system at all.
    Does anyone have any recommendations? Thanks for your input!
    Mark
  2. 2004/07/01
    shadowhawk
    shadowhawk Inactive
    Have him go in Safe Mode by hitting F8 while the computer's booting. There may be a corrupt program in his startup routine.
    rcknrbn
    Safe Mode
    Shadowhawk.....
    Thanks for the input.
    I'll tell him to try Safe Mode. If it does allow you to go into Safe Mode, what would you recommend at that point to try to correct any corrupt program in Startup?
    Thanks.....
    Mark
  5. 2004/07/01
    Johanna
    Johanna Inactive Alumni
    If Safe Mode is Available
    The first thing I would do is turn off the auto restart.
    Control Panel/System/Advanced/Startup and Recovery
    uncheck auto restart
    Then I would attempt a System Restore back to a known good working date.
    Start> Accessories> System Tools> System Restore
    Johanna
  6. 2004/07/02
    rcknrbn
    Safe Mode
    Shadowhawk.....
    Thanks.....
    Mark
  7. 2004/07/02
    rcknrbn - curious why you ignored the items/suggestions Johanna posted.
    The first one, setting the PC to not autoboot after an error will force a blue screen with lots of specific information about the exact cause of the crash that would help in diagnosing this or future problems.
    And if the cause is a fairly new problem with a system file, picking a system restore point from before the issue started is by far the easiest way to correct the problem.
    #6
