System Resourses
Discussion in 'Legacy Windows' started by Kimberlee, 2004/07/05.
  1. 2004/07/05
    Kimberlee
    Kimberlee Inactive Thread Starter
    Seems I just get one question answered and along comes another (what would I do without you guys :) ) Things seem to be a little lagging when I am in windows. Went to System>Performance and it tells me I have 54%.
    When I ctrl+alt+del this is what I have running:
    Explorer
    Z1Client
    Msnmsgr
    Qttask
    Enternet
    Avgcc.32
    USBmonit
    Systray
    Avgserv9
    If I am only running the above, shouldn't my resourses be higher?
  2. 2004/07/05
    brett
    brett Inactive Alumni
    Daizy
    Daizy Inactive
    :D Brett...is that kinda like saying "RTFM "? :rolleyes:
    Kimberlee What Brett's tring to say is that there's a difference beween resources and ram.
    If you like, you can go to start..then run...then type in msconfig
    Click ok
    Go to the start up tab.
    Use this list to show you what is safe to uncheck.
    Post here, the ones you can't find on that list...and we'll help.
    Click apply... then ok...and it will ask to reboot. Do so.
