System Properties/Performance Part 2
Discussion in 'Legacy Windows' started by Cindyz, 2003/09/23.
  1. 2003/09/23
    Cindyz
    Cindyz Inactive Thread Starter
    Part 2 of my problem, under system properties/performance I also see: Drive C is using MS DOS compatibility mode file system, I highlite it, click details, and I get this:
    Drive X is using an MS-DOS compatibility mode file system.
    This problem often occurs on more than one drive. Usually it is caused by a driver listed in the Config.sys file that Windows does not recognize and that is related to the message Compatibility mode paging reduces overall system performance. If you see both messages, see the Help for the Compatibility mode paging reduces overall system performance message first.
    If you only see the message Drive X is using an MS-DOS compatibility mode file system on one drive, that drive is using an MS-DOS compatibility (real-mode) driver, which may reduce that drive’s performance. Contact your hardware manufacturer to see if an updated driver is available for your drive. If not, the drive’s performance may be less than optimal, but you can still use it.
    Drive X??
    ANyhow, THANK YOU! THANK YOU! For ANY and ALL HELP!!
  2. 2003/09/23
    markp62
    markp62 Geek Member Alumni
    Go to Start\run, type in "regedit" and press Enter. When the Registy Editor opens, go to the toolbar at Edit\Find, type in "NoIde "and press Enter. When it is found, delete it. Then Reboot.
