System Keeps Rebooting after startup w/DUMP DATA
Discussion in 'Windows XP' started by cjcain, 2008/05/11.
  1. 2008/05/11
    cjcain
    cjcain Inactive Thread Starter
    I usually leave my pc on all the time. When I do reboot, it usually gets into a reboot loop... Boots all the way up into windows (start menu appears and some initial apps start), then reboots.
    1. Under System Failure "Automatic restart" is NOT checked.
    2. I also pressed F8 on reboot, and selected "Disable auto restart ", but it still keeps rebooting...
    3. I tried going into Safe Mode and disabling startup apps, but does not make any difference.
    Only way to get out of the loop is to use System Restore, to restore the last System Checkpoint. Usually the checkpoint is only a day or two before the reboot. (no new apps installed)
    I would really appreciate any help you can give me with this frustrating problem!
    Event Viewer - System - SaveDump info:
    Event Type: Information
    Event Source: Save Dump
    Event Category: None
    Event ID: 1001
    Date: 5/11/2008
    Time: 12:07:04 AM
    User: N/A
    Computer: DOWNSTAIRS
    Description:
    The computer has rebooted from a bugcheck. The bugcheck was: 0x1000007f (0x00000008, 0x80042000, 0x00000000, 0x00000000). A dump was saved in: C:\WINDOWS\Minidump\Mini051108-01.dmp.
    DUMP DATA:
    Opened log file 'c:\debuglog.txt'
    Microsoft (R) Windows Debugger Version 6.9.0003.113 X86
    Loading Dump File [C:\WINDOWS\Minidump\Mini051108-01.dmp]
    Executable search path is: C:\WINDOWS;C:\WINDOWS\system32;C:\WINDOWS\system32\drivers
    Windows XP Kernel Version 2600 (Service Pack 2) UP Free x86 compatible
    Product: WinNt, suite: TerminalServer SingleUserTS Personal
    Built by: 2600.xpsp_sp2_gdr.070227-2254
    Kernel base = 0x804d7000 PsLoadedModuleList = 0x8055a620
    Debug session time: Sun May 11 00:05:44.171 2008 (GMT-5)
    System Uptime: 0 days 0:03:18.736
    Loading Kernel Symbols
    Loading User Symbols
    Loading unloaded module list
    ERROR: FindPlugIns 8007007b
    * Bugcheck Analysis *
    BugCheck 1000007F, {8, 80042000, 0, 0}
    *** ERROR: Module load completed but symbols could not be loaded for symsnap.sys
    *** ERROR: Symbol file could not be found. Defaulted to export symbols for SYMEVENT.SYS -
    Probably caused by : symsnap.sys ( symsnap+82fb )
    Followup: MachineOwner
    kd> !analyze -v;r;kv;lmtn;.logclose;q
    UNEXPECTED_KERNEL_MODE_TRAP_M (1000007f)
    This means a trap occurred in kernel mode, and it's a trap of a kind
    that the kernel isn't allowed to have/catch (bound trap) or that
    is always instant death (double fault). The first number in the
    bugcheck params is the number of the trap (8 = double fault, etc)
    Consult an Intel x86 family manual to learn more about what these
    traps are. Here is a *portion* of those codes:
    If kv shows a taskGate
    use .tss on the part before the colon, then kv.
    Else if kv shows a trapframe
    use .trap on that value
    Else
    .trap on the appropriate frame will show where the trap was taken
    (on x86, this will be the ebp that goes with the procedure KiTrap)
    Endif
    kb will then show the corrected stack.
    Arguments:
    Arg1: 00000008, EXCEPTION_DOUBLE_FAULT
    Arg2: 80042000
    Arg3: 00000000
    Arg4: 00000000
    Debugging Details:
    BUGCHECK_STR: 0x7f_8
    CUSTOMER_CRASH_COUNT: 1
    PROCESS_NAME: System
    LAST_CONTROL_TRANSFER: from 804ec463 to 804ec51c
    STACK_TEXT:
    f78dc004 804ec463 8a4500e0 00000002 f78dc028 nt!FsRtlFindLargeIndex+0xa
    f78dc048 bada8a48 8a4500e0 00000002 00000000 nt!FsRtlLookupLargeMcbEntry+0x2c
    f78dc088 bada8b3b 8a4500a0 00000002 00000000 Ntfs!NtfsLookupNtfsMcbEntry+0x9b
    f78dc194 bada8ffc f78dc758 8a450008 00000002 Ntfs!NtfsLookupAllocation+0x5b
    f78dc364 bada8c76 f78dc758 8af5adb8 8a450008 Ntfs!NtfsPrepareBuffers+0x270
    f78dc54c bada9fc8 f78dc758 8af5adb8 8a450008 Ntfs!NtfsNonCachedIo+0x20e
    f78dc748 bada9c24 f78dc758 8af5adb8 0110070a Ntfs!NtfsCommonWrite+0x1824
    f78dc8bc 804e37f7 8a461020 8af5adb8 806ee2e8 Ntfs!NtfsFsdWrite+0xf3
    f78dc8cc 80669fc5 8af5adb8 8a4c2e20 8a4629f0 nt!IopfCallDriver+0x31
    f78dc8f0 bae6c3ca 8a462938 8af5af00 f78dc934 nt!IovCallDriver+0xa0
    f78dc900 804e37f7 8a462938 8af5adb8 806ee2e8 sr!SrWrite+0xaa
    f78dc910 80669fc5 8af5adb8 8a489b50 8af5afb4 nt!IopfCallDriver+0x31
    f78dc934 bae542fb 8af5adb8 8a489b50 00000000 nt!IovCallDriver+0xa0
    f78dc9fc bae54c08 8a489a98 8af5adb8 8a489a98 symsnap+0x82fb
    f78dca18 804e37f7 8a489a98 8af5adb8 806ee2e8 symsnap+0x8c08
    f78dca28 80669fc5 00000000 8af5adb8 89f138e0 nt!IopfCallDriver+0x31
    f78dca4c bae81e9b 8a344310 8af5adb8 8a2f9008 nt!IovCallDriver+0xa0
    f78dca70 bae8206b f78dca90 8a344310 00000000 fltmgr!FltpLegacyProcessingAfterPreCallbacksCompleted+0x20b
    f78dcaa8 804e37f7 8a344310 8af5adb8 806ee2e8 fltmgr!FltpDispatch+0x11f
    f78dcab8 80669fc5 8af5afd8 804e8a39 f78dcb2c nt!IopfCallDriver+0x31
    f78dcadc b39027b1 8af5afd8 8af5affc f78dcb2c nt!IovCallDriver+0xa0
    f78dcaf4 b390bd88 8a344310 89f8f020 f78dcb2c SYMEVENT!SYMEvent_AllocVMData+0x5c71
    f78dcb10 b390291b f78dcb2c 804e8a39 b39029e3 SYMEVENT!EventObjectCreate+0xba8
    f78dcb50 b3902acf 89f8f020 8af5adb8 89f8f000 SYMEVENT!SYMEvent_AllocVMData+0x5ddb
    f78dcb64 804e37f7 89f8f020 8af5adb8 806ee2e8 SYMEVENT!SYMEvent_AllocVMData+0x5f8f
    f78dcb74 80669fc5 8a4604d8 00002000 89f8f020 nt!IopfCallDriver+0x31
    f78dcb98 804ed6f5 e221f340 00001000 e1936a98 nt!IovCallDriver+0xa0
    f78dcbac badc9f3c 8a46040d 8a463248 f78dcc50 nt!IoSynchronousPageWrite+0xaf
    f78dcc78 badc9e89 e1936a98 e221f340 e1936a98 Ntfs!LfsFlushLfcb+0x429
    f78dcc9c badd41d9 e1936a98 e221f340 e18e20f8 Ntfs!LfsFlushLbcb+0x81
    f78dccc4 badc8a60 e1936a98 59346136 00000049 Ntfs!LfsFlushToLsnPriv+0xf3
    f78dcd04 badb475f e18e20f8 59346136 00000049 Ntfs!LfsFlushToLsn+0x8e
    f78dcef0 bada9c24 f78dcf00 8acaedb8 0110070a Ntfs!NtfsCommonWrite+0x18f7
    f78dd064 804e37f7 8a461020 8acaedb8 806ee2e8 Ntfs!NtfsFsdWrite+0xf3
    f78dd074 80669fc5 8acaedb8 8a4c2e20 8a4629f0 nt!IopfCallDriver+0x31
    f78dd098 bae6c3ca 8a462938 8acaef00 f78dd0dc nt!IovCallDriver+0xa0
    f78dd0a8 804e37f7 8a462938 8acaedb8 806ee2e8 sr!SrWrite+0xaa
    f78dd0b8 80669fc5 8acaedb8 8a489b50 8acaefb4 nt!IopfCallDriver+0x31
    f78dd0dc bae542fb 8acaedb8 8a489b50 00000000 nt!IovCallDriver+0xa0
    f78dd1a4 bae54c08 8a489a98 8acaedb8 8a489a98 symsnap+0x82fb
    f78dd1c0 804e37f7 8a489a98 8acaedb8 806ee2e8 symsnap+0x8c08
    f78dd1d0 80669fc5 00000000 8acaedb8 89eed4e8 nt!IopfCallDriver+0x31
    f78dd1f4 bae81e9b 8a344310 8acaedb8 8a2f9008 nt!IovCallDriver+0xa0
    f78dd218 bae8206b f78dd238 8a344310 00000000 fltmgr!FltpLegacyProcessingAfterPreCallbacksCompleted+0x20b
    f78dd250 804e37f7 8a344310 8acaedb8 806ee2e8 fltmgr!FltpDispatch+0x11f
    f78dd260 80669fc5 8acaefd8 804e8a39 f78dd2d4 nt!IopfCallDriver+0x31
    f78dd284 b39027b1 8acaefd8 8acaeffc f78dd2d4 nt!IovCallDriver+0xa0
    f78dd29c b390bd88 8a344310 89f8f020 f78dd2d4 SYMEVENT!SYMEvent_AllocVMData+0x5c71
    f78dd2b8 b390291b f78dd2d4 804e8a39 b39029e3 SYMEVENT!EventObjectCreate+0xba8
    f78dd2f8 b3902acf 89f8f020 8acaedb8 89f8f000 SYMEVENT!SYMEvent_AllocVMData+0x5ddb
    f78dd30c 804e37f7 89f8f020 8acaedb8 806ee2e8 SYMEVENT!SYMEvent_AllocVMData+0x5f8f
    f78dd31c 80669fc5 8a3eabf8 00000000 89f8f020 nt!IopfCallDriver+0x31
    f78dd340 804ed6f5 00001000 89e44d20 00001000 nt!IovCallDriver+0xa0
    f78dd354 805de38d 8a3eab0d 89e44d20 f78dd3fc nt!IoSynchronousPageWrite+0xaf
    f78dd420 bade2239 8a3eabf8 f78dd464 f78dd45c nt!CcZeroData+0x4af
    f78dd4a0 badaa0be f78dd6b0 e2b8b490 8a3eabf8 Ntfs!NtfsZeroData+0x29e
    f78dd6a0 bada9c24 f78dd6b0 8af4adb8 0110070a Ntfs!NtfsCommonWrite+0x16ab
    f78dd814 804e37f7 8a461020 8af4adb8 806ee2e8 Ntfs!NtfsFsdWrite+0xf3
    f78dd824 80669fc5 8af4adb8 8a4c2e20 8a4629f0 nt!IopfCallDriver+0x31
    f78dd848 bae6c3ca 8a462938 8af4af00 f78dd88c nt!IovCallDriver+0xa0
    f78dd858 804e37f7 8a462938 8af4adb8 806ee2e8 sr!SrWrite+0xaa
    f78dd868 80669fc5 8af4adb8 8a489b50 8af4afb4 nt!IopfCallDriver+0x31
    f78dd88c bae542fb 8af4adb8 8a489b50 00000000 nt!IovCallDriver+0xa0
    f78dd954 bae54c08 8a489a98 8af4adb8 8a489a98 symsnap+0x82fb
    f78dd970 804e37f7 8a489a98 8af4adb8 806ee2e8 symsnap+0x8c08
    f78dd980 80669fc5 00000000 8af4adb8 89eed4e8 nt!IopfCallDriver+0x31
    f78dd9a4 bae81e9b 8a344310 8af4adb8 8a2f9008 nt!IovCallDriver+0xa0
    f78dd9c8 bae8206b f78dd9e8 8a344310 00000000 fltmgr!FltpLegacyProcessingAfterPreCallbacksCompleted+0x20b
    f78dda00 804e37f7 8a344310 8af4adb8 806ee2e8 fltmgr!FltpDispatch+0x11f
    f78dda10 80669fc5 8af4afd8 804e8a39 f78dda84 nt!IopfCallDriver+0x31
    f78dda34 b39027b1 8af4afd8 8af4affc f78dda84 nt!IovCallDriver+0xa0
    f78dda4c b390bd88 8a344310 89f8f020 f78dda84 SYMEVENT!SYMEvent_AllocVMData+0x5c71
    f78dda68 b390291b f78dda84 804e8a39 b39029e3 SYMEVENT!EventObjectCreate+0xba8
    f78ddaa8 b3902acf 89f8f020 8af4adb8 89f8f000 SYMEVENT!SYMEvent_AllocVMData+0x5ddb
    f78ddabc 804e37f7 89f8f020 8af4adb8 806ee2e8 SYMEVENT!SYMEvent_AllocVMData+0x5f8f
    STACK_COMMAND: kb
    FOLLOWUP_IP:
    symsnap+82fb
    bae542fb e917080000 jmp symsnap+0x8b17 (bae54b17)
    SYMBOL_STACK_INDEX: d
    SYMBOL_NAME: symsnap+82fb
    FOLLOWUP_NAME: MachineOwner
    MODULE_NAME: symsnap
    IMAGE_NAME: symsnap.sys
    DEBUG_FLR_IMAGE_TIMESTAMP: 47855839
    FAILURE_BUCKET_ID: 0x7f_8_symsnap+82fb
    eax=f78dc028 ebx=00000000 ecx=8a466d08 edx=00000000 esi=8a4500e0 edi=00000000
    eip=804ec51c esp=f78dc000 ebp=f78dc004 iopl=0 nv up ei pl zr na pe nc
    cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010246
    nt!FsRtlFindLargeIndex+0xa:
    804ec51c 53 push ebx
    f78dc004 804ec463 8a4500e0 00000002 f78dc028 nt!FsRtlFindLargeIndex+0xa (FPO: [Non-Fpo])
    f78dc048 bada8a48 8a4500e0 00000002 00000000 nt!FsRtlLookupLargeMcbEntry+0x2c (FPO: [Non-Fpo])
    f78dc088 bada8b3b 8a4500a0 00000002 00000000 Ntfs!NtfsLookupNtfsMcbEntry+0x9b (FPO: [Non-Fpo])
    f78dc194 bada8ffc f78dc758 8a450008 00000002 Ntfs!NtfsLookupAllocation+0x5b (FPO: [Non-Fpo])
    f78dc364 bada8c76 f78dc758 8af5adb8 8a450008 Ntfs!NtfsPrepareBuffers+0x270 (FPO: [Non-Fpo])
    f78dc54c bada9fc8 f78dc758 8af5adb8 8a450008 Ntfs!NtfsNonCachedIo+0x20e (FPO: [Non-Fpo])
    f78dc748 bada9c24 f78dc758 8af5adb8 0110070a Ntfs!NtfsCommonWrite+0x1824 (FPO: [Non-Fpo])
    f78dc8bc 804e37f7 8a461020 8af5adb8 806ee2e8 Ntfs!NtfsFsdWrite+0xf3 (FPO: [Non-Fpo])
    f78dc8cc 80669fc5 8af5adb8 8a4c2e20 8a4629f0 nt!IopfCallDriver+0x31 (FPO: [0,0,0])
    f78dc8f0 bae6c3ca 8a462938 8af5af00 f78dc934 nt!IovCallDriver+0xa0 (FPO: [Non-Fpo])
    f78dc900 804e37f7 8a462938 8af5adb8 806ee2e8 sr!SrWrite+0xaa (FPO: [Non-Fpo])
    f78dc910 80669fc5 8af5adb8 8a489b50 8af5afb4 nt!IopfCallDriver+0x31 (FPO: [0,0,0])
    f78dc934 bae542fb 8af5adb8 8a489b50 00000000 nt!IovCallDriver+0xa0 (FPO: [Non-Fpo])
    f78dca28 80669fc5 00000000 8af5adb8 89f138e0 nt!IopfCallDriver+0x31 (FPO: [0,0,0])
    f78dca4c bae81e9b 8a344310 8af5adb8 8a2f9008 nt!IovCallDriver+0xa0 (FPO: [Non-Fpo])
    f78dca70 bae8206b f78dca90 8a344310 00000000 fltmgr!FltpLegacyProcessingAfterPreCallbacksCompleted+0x20b (FPO: [Non-Fpo])
    f78dcaa8 804e37f7 8a344310 8af5adb8 806ee2e8 fltmgr!FltpDispatch+0x11f (FPO: [Non-Fpo])
    f78dcab8 80669fc5 8af5afd8 804e8a39 f78dcb2c nt!IopfCallDriver+0x31 (FPO: [0,0,0])
    start end module name
    804d7000 806eb500 nt ntoskrnl.exe Wed Feb 28 03:10:41 2007 (45E54711)
    806ec000 8070c380 hal halaacpi.dll Wed Aug 04 00:59:05 2004 (41107B29)
    b38ba000 b38fa280 HTTP HTTP.sys Thu Mar 16 19:33:09 2006 (441A03C5)
    b38fb000 b3920000 SYMEVENT SYMEVENT.SYS Mon Sep 24 19:39:57 2007 (46F858DD)
    b39b0000 b39b88a0 NPDRIVER NPDRIVER.SYS Mon Aug 30 23:38:34 2004 (413400CA)
    b4150000 b41a1480 srv srv.sys Mon Aug 14 05:34:39 2006 (44E051BF)
    b4202000 b420fa80 nwlnkspx nwlnkspx.sys Fri Aug 17 15:54:16 2001 (3B7D8478)
    b427e000 b42a9d80 mrxdav mrxdav.sys Tue Dec 18 03:51:33 2007 (47679825)
    b4490000 b44a4400 wdmaud wdmaud.sys Wed Jun 14 04:00:44 2006 (448FD03C)
    b4579000 b457ce40 ASPI32 ASPI32.SYS Fri Sep 10 18:46:10 1999 (37D99842)
    b4625000 b4633d80 sysaudio sysaudio.sys Wed Aug 04 01:15:54 2004 (41107F1A)
    b46fd000 b4712980 nwlnkipx nwlnkipx.sys Wed Aug 04 01:03:29 2004 (41107C31)
    b471f000 b47225e0 mrtRate mrtRate.SYS Sat Sep 18 00:54:44 1999 (37E32924)
    b473b000 b4752f80 nbf nbf.sys Fri Aug 17 15:53:59 2001 (3B7D8467)
    b47a7000 b47aa280 ndisuio ndisuio.sys Wed Aug 04 01:03:10 2004 (41107C1E)
    b48bb000 b48de000 Fastfat Fastfat.SYS Wed Aug 04 01:14:15 2004 (41107EB7)
    b721b000 b7232480 dump_atapi dump_atapi.sys Wed Aug 04 00:59:41 2004 (41107B4D)
    b7243000 b7252700 nwlnknb nwlnknb.sys Fri Aug 17 15:54:16 2001 (3B7D8478)
    b72d3000 b7305a00 Dot4 Dot4.sys Wed Aug 04 00:58:28 2004 (41107B04)
    b732e000 b739ca00 mrxsmb mrxsmb.sys Fri May 05 04:41:42 2006 (445B1DD6)
    b739d000 b73c7a00 rdbss rdbss.sys Fri May 05 04:47:55 2006 (445B1F4B)
    b73c8000 b73f4340 truecrypt truecrypt.sys Thu May 03 14:21:33 2007 (463A363D)
    b73ff000 b7420d00 afd afd.sys Wed Aug 04 01:14:13 2004 (41107EB5)
    b7421000 b74800e0 vsdatant vsdatant.sys Fri Mar 14 00:43:30 2008 (47DA1082)
    b74a9000 b74c9f00 ipnat ipnat.sys Wed Sep 29 17:28:36 2004 (415B3714)
    b74ca000 b74f1c00 netbt netbt.sys Wed Aug 04 01:14:36 2004 (41107ECC)
    b74f2000 b7549e80 tcpip tcpip.sys Tue Oct 30 12:20:52 2007 (472767F4)
    b754a000 b7550000 symlcbrd symlcbrd.sys Tue Feb 01 00:13:32 2005 (41FF1E0C)
    b755a000 b7561d80 v2imount v2imount.sys Mon Jan 15 11:02:33 2007 (45ABB3A9)
    b759a000 b75ac400 ipsec ipsec.sys Wed Aug 04 01:14:27 2004 (41107EC3)
    b75cd000 b75f0000 klif klif.sys Tue May 15 03:40:47 2007 (4649720F)
    b76f7000 b76f9900 Dxapi Dxapi.sys Fri Aug 17 15:53:19 2001 (3B7D843F)
    b771b000 b771e280 Dot4Prt Dot4Prt.sys Fri Aug 17 15:47:25 2001 (3B7D82DD)
    ba79f000 ba7a1200 Dot4Scan Dot4Scan.sys Fri Aug 17 15:47:25 2001 (3B7D82DD)
    ba7ab000 ba7ad580 hidusb hidusb.sys Fri Aug 17 16:02:16 2001 (3B7D8658)
    ba7cd000 ba825e80 update update.sys Mon Apr 23 05:32:54 2007 (462C8B56)
    ba826000 ba83d800 mcdbus mcdbus.sys Mon Feb 18 03:29:14 2008 (47B94FEA)
    ba83e000 ba844180 HIDPARSE HIDPARSE.SYS Wed Aug 04 01:08:15 2004 (41107D4F)
    ba84e000 ba853d00 dot4usb dot4usb.sys Fri Aug 17 15:47:24 2001 (3B7D82DC)
    ba87e000 ba884780 USBSTOR USBSTOR.SYS Wed Aug 04 01:08:44 2004 (41107D6C)
    ba88e000 ba8a4680 ndiswan ndiswan.sys Wed Aug 04 01:14:30 2004 (41107EC6)
    ba8a5000 ba8c8980 portcls portcls.sys Wed Aug 04 01:15:47 2004 (41107F13)
    ba8c9000 ba94c980 smwdm smwdm.sys Thu Dec 19 16:48:46 2002 (3E024CCE)
    ba96d000 ba975d80 HIDCLASS HIDCLASS.SYS Wed Aug 04 01:08:18 2004 (41107D52)
    ba9ad000 ba9bc900 Cdfs Cdfs.SYS Wed Aug 04 01:14:09 2004 (41107EB1)
    ba9cd000 ba9d5880 Fips Fips.SYS Fri Aug 17 20:31:49 2001 (3B7DC585)
    ba9ed000 baa00900 parport parport.sys Wed Aug 04 00:59:04 2004 (41107B28)
    baa01000 baa23200 e100b325 e100b325.sys Thu Sep 19 16:59:48 2002 (3D8A48D4)
    baa4c000 baa6e680 ks ks.sys Wed Aug 04 01:15:20 2004 (41107EF8)
    baa6f000 bab7bf80 BCMSM BCMSM.sys Wed Aug 27 22:05:02 2003 (3F4D715E)
    bab7c000 bab9ee80 USBPORT USBPORT.SYS Wed Aug 04 01:08:34 2004 (41107D62)
    bab9f000 babb2780 VIDEOPRT VIDEOPRT.SYS Wed Aug 04 01:07:04 2004 (41107D08)
    babb3000 babfb100 ati2mtaa ati2mtaa.sys Fri Jan 11 01:22:07 2002 (3C3E929F)
    bac54000 bac57c80 mssmbios mssmbios.sys Wed Aug 04 01:07:47 2004 (41107D33)
    bac68000 bac6a580 ndistapi ndistapi.sys Fri Aug 17 15:55:29 2001 (3B7D84C1)
    bac84000 bac86680 pfc pfc.sys Fri Sep 27 17:53:07 2002 (3D94E153)
    bacfc000 bad04700 netbios netbios.sys Wed Aug 04 01:03:19 2004 (41107C27)
    bad0c000 bad14700 wanarp wanarp.sys Wed Aug 04 01:04:57 2004 (41107C89)
    bad1c000 bad24900 msgpc msgpc.sys Wed Aug 04 01:04:11 2004 (41107C5B)
    bad4c000 bad66580 Mup Mup.sys Wed Aug 04 01:15:20 2004 (41107EF8)
    bad67000 bad7b000 srescan srescan.sys Tue Dec 04 16:30:06 2007 (4755D4EE)
    bad7b000 bada7a80 NDIS NDIS.sys Wed Aug 04 01:14:27 2004 (41107EC3)
    bada8000 bae34400 Ntfs Ntfs.sys Fri Feb 09 05:10:31 2007 (45CC56A7)
    bae35000 bae4b780 KSecDD KSecDD.sys Wed Aug 04 00:59:45 2004 (41107B51)
    bae4c000 bae6b300 symsnap symsnap.sys Wed Jan 09 17:26:49 2008 (47855839)
    bae6c000 bae7df00 sr sr.sys Wed Aug 04 01:06:22 2004 (41107CDE)
    bae7e000 bae9d780 fltmgr fltmgr.sys Mon Aug 21 04:14:57 2006 (44E97991)
    bae9e000 baeb5480 atapi atapi.sys Wed Aug 04 00:59:41 2004 (41107B4D)
    baeb6000 baecd800 SCSIPORT SCSIPORT.SYS Wed Aug 04 00:59:39 2004 (41107B4B)
    baece000 baee0080 pnp680r pnp680r.sys Tue May 07 13:10:42 2002 (3CD818A2)
    baee1000 baeff880 ftdisk ftdisk.sys Fri Aug 17 15:52:41 2001 (3B7D8419)
    baf10000 baf1e100 usbhub usbhub.sys Wed Aug 04 01:08:40 2004 (41107D68)
    baf20000 baf29480 NDProxy NDProxy.SYS Fri Aug 17 15:55:30 2001 (3B7D84C2)
    baf30000 baf39f00 termdd termdd.sys Wed Aug 04 00:58:52 2004 (41107B1C)
    baf40000 baf4bd00 raspptp raspptp.sys Wed Aug 04 01:14:26 2004 (41107EC2)
    baf50000 baf5a200 raspppoe raspppoe.sys Wed Aug 04 01:05:06 2004 (41107C92)
    baf60000 baf6c880 rasl2tp rasl2tp.sys Wed Aug 04 01:14:21 2004 (41107EBD)
    baf70000 baf7c000 dfmirage dfmirage.sys Fri Nov 25 05:43:46 2005 (4386F8F2)
    baf80000 baf8eb80 drmk drmk.sys Wed Aug 04 01:07:54 2004 (41107D3A)
    baf90000 baf9e080 redbook redbook.sys Wed Aug 04 00:59:34 2004 (41107B46)
    bafa0000 bafb0a80 pci pci.sys Wed Aug 04 01:07:45 2004 (41107D31)
    bafb1000 bafded80 ACPI ACPI.sys Wed Aug 04 01:07:35 2004 (41107D27)
    bf800000 bf9c2800 win32k win32k.sys Wed Mar 19 04:46:46 2008 (47E0E106)
    bf9c3000 bf9d4580 dxg dxg.sys Wed Aug 04 01:00:51 2004 (41107B93)
    bf9d5000 bfa22a80 ati2dvaa ati2dvaa.dll Fri Jan 11 01:23:04 2002 (3C3E92D8)
    f75f7000 f75ffc00 isapnp isapnp.sys Fri Aug 17 15:58:01 2001 (3B7D8559)
    f7607000 f7611500 MountMgr MountMgr.sys Wed Aug 04 00:58:29 2004 (41107B05)
    f7617000 f7623c80 VolSnap VolSnap.sys Wed Aug 04 01:00:14 2004 (41107B6E)
    f7627000 f762fe00 disk disk.sys Wed Aug 04 00:59:53 2004 (41107B59)
    f7637000 f7643200 CLASSPNP CLASSPNP.SYS Wed Aug 04 01:14:26 2004 (41107EC2)
    f7647000 f7655e80 ohci1394 ohci1394.sys Wed Aug 04 01:10:05 2004 (41107DBD)
    f7657000 f7664000 1394BUS 1394BUS.SYS Wed Aug 04 01:10:03 2004 (41107DBB)
    f7667000 f7671580 agp440 agp440.sys Wed Aug 04 01:07:40 2004 (41107D2C)
    f7677000 f7682ea0 iomdisk iomdisk.sys Fri Dec 03 11:52:50 2004 (41B0A7F2)
    f7697000 f76a6180 nic1394 nic1394.sys Wed Aug 04 00:58:28 2004 (41107B04)
    f76a7000 f76afd00 intelppm intelppm.sys Wed Aug 04 00:59:19 2004 (41107B37)
    f76b7000 f76c3e00 i8042prt i8042prt.sys Wed Aug 04 01:14:36 2004 (41107ECC)
    f76c7000 f76d6d80 serial serial.sys Wed Aug 04 01:15:51 2004 (41107F17)
    f76d7000 f76e1380 Imapi Imapi.sys Wed Aug 04 01:00:12 2004 (41107B6C)
    f76e7000 f76efc00 AFS2K AFS2K.SYS Thu Oct 07 20:16:03 2004 (4165EA53)
    f76f7000 f7703180 cdrom cdrom.sys Wed Aug 04 00:59:52 2004 (41107B58)
    f7707000 f770d200 PCIIDEX PCIIDEX.SYS Wed Aug 04 00:59:40 2004 (41107B4C)
    f770f000 f7713900 PartMgr PartMgr.sys Fri Aug 17 20:32:23 2001 (3B7DC5A7)
    f7717000 f771be20 PxHelp20 PxHelp20.sys Mon Apr 25 14:48:02 2005 (426D4972)
    f771f000 f7723500 ppa3 ppa3.sys Wed Aug 04 01:00:14 2004 (41107B6E)
    f774f000 f7754000 usbuhci usbuhci.sys Wed Aug 04 01:08:34 2004 (41107D62)
    f7757000 f775d800 usbehci usbehci.sys Wed Aug 04 01:08:34 2004 (41107D62)
    f776f000 f7776580 Modem Modem.SYS Wed Aug 04 01:08:04 2004 (41107D44)
    f7777000 f777c000 flpydisk flpydisk.sys Wed Aug 04 00:59:24 2004 (41107B3C)
    f777f000 f7780000 fdc fdc.sys unavailable (00000000)
    f7787000 f778d000 kbdclass kbdclass.sys Wed Aug 04 00:58:32 2004 (41107B08)
    f778f000 f7793500 watchdog watchdog.sys Wed Aug 04 01:07:32 2004 (41107D24)
    f7797000 f779bf80 point32 point32.sys Thu Jun 03 03:45:18 2004 (40BEE51E)
    f779f000 f77a4a00 mouclass mouclass.sys Wed Aug 04 00:58:32 2004 (41107B08)
    f77b7000 f77bc200 vga vga.sys Wed Aug 04 01:07:06 2004 (41107D0A)
    f77bf000 f77c6000 GEARAspiWDM GEARAspiWDM.sys Mon Aug 07 12:11:27 2006 (44D7743F)
    f77cf000 f77d3a80 Msfs Msfs.SYS Wed Aug 04 01:00:37 2004 (41107B85)
    f77df000 f77e6880 Npfs Npfs.SYS Wed Aug 04 01:00:38 2004 (41107B86)
    f77ef000 f77f3880 TDI TDI.SYS Wed Aug 04 01:07:47 2004 (41107D33)
    f77ff000 f7803580 ptilink ptilink.sys Fri Aug 17 15:49:53 2001 (3B7D8371)
    f7807000 f780bb00 HidBatt HidBatt.sys Fri Aug 17 15:57:58 2001 (3B7D8556)
    f780f000 f7813080 raspti raspti.sys Fri Aug 17 15:55:32 2001 (3B7D84C4)
    f781f000 f78232c0 omci omci.sys Fri Jul 19 10:22:06 2002 (3D382E9E)
    f7897000 f789a000 BOOTVID BOOTVID.dll Fri Aug 17 15:49:09 2001 (3B7D8345)
    f789b000 f789d480 compbatt compbatt.sys Fri Aug 17 15:57:58 2001 (3B7D8556)
    f789f000 f78a2700 BATTC BATTC.SYS Fri Aug 17 15:57:52 2001 (3B7D8550)
    f793b000 f793ec80 serenum serenum.sys Wed Aug 04 00:59:06 2004 (41107B2A)
    f793f000 f7941280 rasacd rasacd.sys Fri Aug 17 15:55:39 2001 (3B7D84CB)
    f794b000 f794e1c0 cdrbsdrv cdrbsdrv.SYS Sun Mar 07 21:55:49 2004 (404BEEC5)
    f7987000 f7988b80 kdcom kdcom.dll Fri Aug 17 15:49:10 2001 (3B7D8346)
    f7989000 f798a100 WMILIB WMILIB.SYS Fri Aug 17 16:07:23 2001 (3B7D878B)
    f798d000 f798e120 aeaudio aeaudio.sys Mon Apr 01 09:39:14 2002 (3CA87112)
    f7993000 f7994100 swenum swenum.sys Wed Aug 04 00:58:41 2004 (41107B11)
    f799d000 f799e280 USBD USBD.SYS Fri Aug 17 16:02:58 2001 (3B7D8682)
    f799f000 f79a1000 i2omgmt i2omgmt.SYS Wed Aug 04 01:00:50 2004 (41107B92)
    f79a3000 f79a4f00 Fs_Rec Fs_Rec.SYS Fri Aug 17 15:49:37 2001 (3B7D8361)
    f79a7000 f79a8080 Beep Beep.SYS Fri Aug 17 15:47:33 2001 (3B7D82E5)
    f79ab000 f79ac080 mnmdd mnmdd.SYS Fri Aug 17 15:57:28 2001 (3B7D8538)
    f79af000 f79b0080 RDPCDD RDPCDD.sys Fri Aug 17 15:46:56 2001 (3B7D82C0)
    f79e7000 f79e8a80 ParVdm ParVdm.SYS Fri Aug 17 15:49:49 2001 (3B7D836D)
    f79e9000 f79ea100 dump_WMILIB dump_WMILIB.SYS Fri Aug 17 16:07:23 2001 (3B7D878B)
    f7a4f000 f7a4fd00 pciide pciide.sys Fri Aug 17 15:51:49 2001 (3B7D83E5)
    f7a50000 f7a50c80 zmNTMon zmNTMon.sys Thu Apr 09 14:18:33 1998 (352D1F09)
    f7a58000 f7a58860 BANTExt BANTExt.sys Wed May 27 21:43:29 1998 (356CCF51)
    f7a97000 f7a97b80 Null Null.SYS Fri Aug 17 15:47:39 2001 (3B7D82EB)
    f7abe000 f7abed00 dxgthk dxgthk.sys Fri Aug 17 15:53:12 2001 (3B7D8438)
    f7abf000 f7abfc00 audstub audstub.sys Fri Aug 17 15:59:40 2001 (3B7D85BC)
    Unloaded modules:
    b43a2000 b43cd000 kmixer.sys
    Checksum: 00000000
    b73fa000 b73fb000 drmkaud.sys
    Checksum: 00000000
    b4605000 b4612000 DMusic.sys
    Checksum: 00000000
    b446d000 b4490000 aec.sys
    Checksum: 00000000
    b4615000 b4623000 swmidi.sys
    Checksum: 00000000
    f79cd000 f79cf000 splitter.sys
    Checksum: 00000000
    baccc000 bacd5000 processr.sys
    Checksum: 00000000
    bacec000 bacf7000 p3.sys
    Checksum: 00000000
    f77af000 f77b4000 Cdaudio.SYS
    Checksum: 00000000
    baa28000 baa2b000 Sfloppy.SYS
    Checksum: 00000000
    Closing open log file c:\debuglog.txt
  2. 2008/05/11
    cjcain - Welcome to the Board :)
    This may or may not be straightforward, but please note ....
    That said your log references ....
    This would appear to be associated with some backup software - Symantec - Storage Craft?? ....
    http://www.google.com/search?sourceid=navclient&aq=t&ie=UTF-8&rlz=1T4GGLG_en___GB227&q=symsnap.sys
    A similar problem here - scroll to the bottom of the page for solution ....
    http://www.experts-exchange.com/OS/Microsoft_Operating_Systems/Windows/XP/Q_21568581.html
    More here ....
    http://www.google.com/search?source...lz=1T4GGLG_en___GB227&q=0x1000007F+++Symantec
    http://www.windowsbbs.com/showthread.php?t=38035
    http://www.google.com/search?sourceid=navclient&ie=UTF-8&rlz=1T4GGLG_en___GB227&q=0x1000007F
    bdesmond
    bdesmond Inactive
    This is the second one of this crash I've seen today actually. It's a stack overflow perpetrated by Symantec. I'm not certain which driver in particular in their array of them is causing this as the dumps I have on my machine don't have enough info.
    Try updating your symevent.sys, this is updated out of band (e.g. a/v updates or other stuff won't update this module) - get it at http://service1.symantec.com/SUPPORT/ent-security.nsf/docid/1998092408260848.
