system hang ups
Discussion in 'Windows XP' started by booger6977, 2003/09/27.
  1. 2003/09/27
    booger6977
    booger6977 Inactive Thread Starter
    some where there was a post on a windows update that was causing hang ups in system does any one know the update # it was ? because i had this same problem before removed it and it was fine wife did updates and it's back slow as a snail.....................................thanks
  2. 2003/09/27
    The update you probably have in mind is 811493 - the April release slowed many PC's to a crawl, but the May re-release was OK.
    Did your better half update via Windows Update? Should not be a problem with that patch if installed since end May.
    booger6977
    thank you pete that is the one. l removed it an now its fine i'll re-update thank you again
