Solved System crashes
Discussion in 'Malware and Virus Removal Archive' started by SVEN, 2012/01/14.
  1. 2012/01/14
    SVEN
    SVEN Well-Known Member Thread Starter
    [Resolved] System crashes
    Hi Broni
    A week ago I had a few BSOD’s and did a bug check and posted it here:
    http://www.windowsbbs.com/windows-xp/101540-windows-crashing-3-times.html
    Arie suggested I run malwarebytes. It found 300 objects. So I downloaded the rest of the checking tools and ran GMER, but it tock more than 2 hours to run and before it was done I had a BSOD again. So I decided to evict the 200 dust bunnies that took up residence in my system. The heat sink was so clogged; there is no way it was getting cooled. After cleaning it this morning, it booted up without a problem and I ran all the tools. Let me know what to do next. Thanks.
    Here are the results:
    Malwarebytes Anti-Malware 1.60.0.1800
    www.malwarebytes.org
    Database version: v2012.01.12.05
    Windows XP Service Pack 3 x86 NTFS
    Internet Explorer 8.0.6001.18702
    Sven Albrecht :: SVEN-ALBRECHT [administrator]
    1/12/2012 6:25:00 PM
    mbam-log-2012-01-12 (18-25-00).txt
    Scan type: Quick scan
    Scan options enabled: Memory | Startup | Registry | File System | Heuristics/Extra | Heuristics/Shuriken | PUP | PUM
    Scan options disabled: P2P
    Objects scanned: 174787
    Time elapsed: 12 minute(s), 44 second(s)
    Memory Processes Detected: 0
    (No malicious items detected)
    Memory Modules Detected: 0
    Registry Keys Detected: 137
    HKLM\SYSTEM\CurrentControlSet\Services\MyWebSearchService (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\CLSID\{00A6FAF1-072E-44cf-8957-5838F569A31D} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{00A6FAF1-072E-44CF-8957-5838F569A31D} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Settings\{00A6FAF1-072E-44CF-8957-5838F569A31D} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{00A6FAF1-072E-44CF-8957-5838F569A31D} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\CLSID\{07B18EA1-A523-4961-B6BB-170DE4475CCA} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{07B18EA1-A523-4961-B6BB-170DE4475CCA} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Settings\{07B18EA1-A523-4961-B6BB-170DE4475CCA} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{07B18EA1-A523-4961-B6BB-170DE4475CCA} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\TypeLib\{07B18EA0-A523-4961-B6BB-170DE4475CCA} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\Interface\{07B18EAA-A523-4961-B6BB-170DE4475CCA} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MyWebSearch bar Uninstall (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\CLSID\{00A6FAF6-072E-44cf-8957-5838F569A31D} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\CLSID\{07B18EA9-A523-4961-B6BB-170DE4475CCA} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Settings\{07B18EA9-A523-4961-B6BB-170DE4475CCA} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{07B18EA9-A523-4961-B6BB-170DE4475CCA} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\CLSID\{07B18EAB-A523-4961-B6BB-170DE4475CCA} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\MyWebSearchToolBar.SettingsPlugin.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\MyWebSearchToolBar.SettingsPlugin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{07B18EAB-A523-4961-B6BB-170DE4475CCA} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{07B18EAB-A523-4961-B6BB-170DE4475CCA} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\CLSID\{0F8ECF4F-3646-4C3A-8881-8E138FFCAF70} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\TypeLib\{8CA01F0E-987C-49C3-B852-2F1AC4A7094C} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\Interface\{1093995A-BA37-41D2-836E-091067C4AD17} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\FunWebProducts.IECookiesManager.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\FunWebProducts.IECookiesManager (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\CLSID\{147A976F-EEE1-4377-8EA7-4716E4CDD239} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\CLSID\{1E0DE227-5CE4-4ea3-AB0C-8B03E1AA76BC} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\CLSID\{25560540-9571-4D7B-9389-0F166788785A} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\TypeLib\{C8CECDE3-1AE1-4C4A-AD82-6D5B00212144} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\Interface\{17DE5E5E-BFE3-4E83-8E1F-8755795359EC} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\FunWebProducts.DataControl.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\FunWebProducts.DataControl (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{25560540-9571-4D7B-9389-0F166788785A} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\CLSID\{3DC201FB-E9C9-499C-A11F-23C360D7C3F8} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\TypeLib\{E47CAEE0-DEEA-464A-9326-3F2801535A4D} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\Interface\{3E1656ED-F60E-4597-B6AA-B6A58E171495} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\FunWebProducts.HTMLMenu.2 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\FunWebProducts.HTMLMenu (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{3DC201FB-E9C9-499C-A11F-23C360D7C3F8} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\CLSID\{3E720452-B472-4954-B7AA-33069EB53906} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\TypeLib\{3E720450-B472-4954-B7AA-33069EB53906} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\Interface\{3E720451-B472-4954-B7AA-33069EB53906} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\MyWebSearch.HTMLPanel.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\MyWebSearch.HTMLPanel (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{3E720452-B472-4954-B7AA-33069EB53906} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\CLSID\{53CED2D0-5E9A-4761-9005-648404E6F7E5} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\MyWebSearchToolBar.ToolbarPlugin.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\MyWebSearchToolBar.ToolbarPlugin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\CLSID\{63D0ED2C-B45B-4458-8B3B-60C69BBBD83C} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\TypeLib\{8E6F1830-9607-4440-8530-13BE7C4B1D14} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\Interface\{63D0ED2B-B45B-4458-8B3B-60C69BBBD83C} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\FunWebProducts.PopSwatterSettingsControl.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\FunWebProducts.PopSwatterSettingsControl (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{63D0ED2C-B45B-4458-8B3B-60C69BBBD83C} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\CLSID\{7473D292-B7BB-4f24-AE82-7E2CE94BB6A9} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\TypeLib\{7473D290-B7BB-4F24-AE82-7E2CE94BB6A9} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\Interface\{7473D291-B7BB-4F24-AE82-7E2CE94BB6A9} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\CLSID\{7473D294-B7BB-4f24-AE82-7E2CE94BB6A9} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\MyWebSearch.PseudoTransparentPlugin.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\MyWebSearch.PseudoTransparentPlugin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{7473D294-B7BB-4F24-AE82-7E2CE94BB6A9} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\CLSID\{7473D296-B7BB-4f24-AE82-7E2CE94BB6A9} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\CLSID\{84DA4FDF-A1CF-4195-8688-3E961F505983} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\CLSID\{8E6F1832-9607-4440-8530-13BE7C4B1D14} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\FunWebProducts.PopSwatterBarButton.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\FunWebProducts.PopSwatterBarButton (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\CLSID\{938AA51A-996C-4884-98CE-80DD16A5C9DA} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\TypeLib\{29D67D3C-509A-4544-903F-C8C1B8236554} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\Interface\{2E3537FC-CF2F-4F56-AF54-5A6A3DD375CC} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\CLSID\{98D9753D-D73B-42D5-8C85-4469CDA897AB} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\FunWebProducts.HTMLMenu.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{98D9753D-D73B-42D5-8C85-4469CDA897AB} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\CLSID\{9FF05104-B030-46FC-94B8-81276E4E27DF} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\ScreenSaverControl.ScreenSaverInstaller.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\ScreenSaverControl.ScreenSaverInstaller (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{9FF05104-B030-46FC-94B8-81276E4E27DF} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\CLSID\{A4730EBE-43A6-443e-9776-36915D323AD3} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\CLSID\{A9571378-68A1-443d-B082-284F960C6D17} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\CLSID\{ADB01E81-3C79-4272-A0F1-7B2BE7A782DC} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\MyWebSearch.OutlookAddin.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\MyWebSearch.OutlookAddin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\CLSID\{B813095C-81C0-4E40-AA14-67520372B987} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\FunWebProducts.KillerObjManager.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\FunWebProducts.KillerObjManager (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\CLSID\{C9D7BE3E-141A-4C85-8CD6-32461F3DF2C7} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\FunWebProducts.HistoryKillerScheduler.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\FunWebProducts.HistoryKillerScheduler (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\CLSID\{CFF4CE82-3AA2-451F-9B77-7165605FB835} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\FunWebProducts.HistorySwatterControlBar.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\FunWebProducts.HistorySwatterControlBar (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\CLSID\{D9FFFB27-D62A-4D64-8CEC-1FF006528805} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\TypeLib\{0D26BC71-A633-4E71-AD31-EADC3A1B6A3A} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\Interface\{E342AF55-B78A-4CD0-A2BB-DA7F52D9D25E} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\CLSID\{E79DFBCA-5697-4fbd-94E5-5B2A9C7C1612} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\TypeLib\{E79DFBC0-5697-4FBD-94E5-5B2A9C7C1612} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\Interface\{72EE7F04-15BD-4845-A005-D6711144D86A} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\MyWebSearch.ChatSessionPlugin.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\MyWebSearch.ChatSessionPlugin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{E79DFBCA-5697-4FBD-94E5-5B2A9C7C1612} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\Typelib\{D518921A-4A03-425E-9873-B9A71756821E} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\Interface\{CF54BE1C-9359-4395-8533-1657CF209CFE} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\Typelib\{F42228FB-E84E-479E-B922-FBBD096E792C} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\Interface\{6E74766C-4D93-4CC0-96D1-47B8E07FF9CA} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCU\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{56256A51-B582-467e-B8D4-7786EDA79AE0} (Trojan.Vundo) -> Quarantined and deleted successfully.
    HKLM\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{56256A51-B582-467e-B8D4-7786EDA79AE0} (Trojan.Vundo) -> Quarantined and deleted successfully.
    HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{1D4DB7D2-6EC9-47A3-BD87-1E41684E07BB} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{1D4DB7D2-6EC9-47A3-BD87-1E41684E07BB} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKLM\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{59C7FC09-1C83-4648-B3E6-003D2BBC7481} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKLM\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{68AF847F-6E91-45dd-9B68-D6A12C30E5D7} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKLM\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{9170B96C-28D4-4626-8358-27E6CAEEF907} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKLM\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{D1A71FA0-FF48-48dd-9B6D-7A13A3E42127} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKLM\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{DDB1968E-EAD6-40fd-8DAE-FF14757F60C7} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKLM\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{F138D901-86F0-4383-99B6-9CDD406036DA} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\MyWebSearch.MultipleButton (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\MyWebSearch.MultipleButton.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\MyWebSearch.ThirdPartyInstaller (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\MyWebSearch.ThirdPartyInstaller.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\MyWebSearch.UrlAlertButton (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\MyWebSearch.UrlAlertButton.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCU\SOFTWARE\MyWebSearch (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKLM\SOFTWARE\FocusInteractive (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKLM\SOFTWARE\Fun Web Products (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKLM\SOFTWARE\MyWebSearch (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKLM\SOFTWARE\Microsoft\Internet Explorer\Low Rights\RunDll32Policy\f3ScrCtr.dll (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKLM\SOFTWARE\Microsoft\Multimedia\WMPlayer\Schemes\f3pss (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKLM\SOFTWARE\Microsoft\Office\Outlook\Addins\MyWebSearch.OutlookAddin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKLM\SOFTWARE\Microsoft\Office\Word\Addins\MyWebSearch.OutlookAddin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\CLSID\{819FFE22-35C7-4925-8CDA-4E0E2DB94302} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\TypeLib\{819FFE20-35C7-4925-8CDA-4E0E2DB94302} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\Interface\{819FFE21-35C7-4925-8CDA-4E0E2DB94302} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\CLSID\{08858AF6-42AD-4914-95D2-AC3AB0DC8E28} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\TypeLib\{8FFDF636-0D87-4B33-B9E9-79A53F6E1DAE} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\Interface\{01947140-417F-46B6-8751-A3A2B8345E1A} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{08858AF6-42AD-4914-95D2-AC3AB0DC8E28} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\CLSID\{799391D3-EB86-4bac-9BD3-CBFEA58A0E15} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKCR\CLSID\{D858DAFC-9573-4811-B323-7011A3AA7E61} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    Registry Values Detected: 12
    HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run|MyWebSearch Email Plugin (Adware.MyWebSearch) -> Data: C:\PROGRA~1\MYWEBS~1\bar\1.bin\mwsoemon.exe -> Quarantined and deleted successfully.
    HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Run|MyWebSearch Email Plugin (Adware.MyWebSearch) -> Data: C:\PROGRA~1\MYWEBS~1\bar\1.bin\mwsoemon.exe -> Quarantined and deleted successfully.
    HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run|My Web Search Bar Search Scope Monitor (Adware.MyWebSearch) -> Data: "C:\PROGRA~1\MYWEBS~1\bar\1.bin\m3SrchMn.exe" /m=2 /w /h -> Quarantined and deleted successfully.
    HKCU\SOFTWARE\Microsoft\Internet Explorer\URLSearchHooks|{00A6FAF6-072E-44CF-8957-5838F569A31D} (Adware.MyWebSearch) -> Data: -> Quarantined and deleted successfully.
    HKCU\SOFTWARE\Microsoft\Internet Explorer\Toolbar\WebBrowser|{07B18EA9-A523-4961-B6BB-170DE4475CCA} (Adware.MyWebSearch) -> Data: ©Å½±#¥aI¶»
    äG\Ê -> Quarantined and deleted successfully.
    HKLM\SOFTWARE\Microsoft\Internet Explorer\Toolbar|{07B18EA9-A523-4961-B6BB-170DE4475CCA} (Adware.MyWebSearch) -> Data: -> Quarantined and deleted successfully.
    HKCU\SOFTWARE\Microsoft\Internet Explorer\Toolbar\WebBrowser\{07B18EA9-A523-4961-B6BB-170DE4475CCA} (Adware.MyWebSearch) -> Data: -> Quarantined and deleted successfully.
    HKCU\SOFTWARE\Microsoft\Internet Explorer\URLSearchHooks\{00A6FAF6-072E-44cf-8957-5838F569A31D} (Adware.MyWebSearch) -> Data: -> Quarantined and deleted successfully.
    HKLM\SOFTWARE\Microsoft\Internet Explorer\Toolbar\{07B18EA9-A523-4961-B6BB-170DE4475CCA} (Adware.MyWebSearch) -> Data: -> Quarantined and deleted successfully.
    HKCU\SOFTWARE\Microsoft\Internet Explorer\MenuExt\&Search| (Adware.Hotbar) -> Data: http://edits.mywebsearch.com/toolba...si=2459&a=M4xPDThKWL.Mjqy5unfujw&n=2012010318 -> Quarantined and deleted successfully.
    HKLM\SOFTWARE\Microsoft\Windows Media\WMSDK\Sources|f3PopularScreensavers (Adware.MyWebSearch) -> Data: C:\Program Files\MyWebSearch\bar\1.bin\F3SCRCTR.DLL -> Quarantined and deleted successfully.
    HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\User Agent\Post Platform|FunWebProducts (Adware.MyWebSearch) -> Data: -> Quarantined and deleted successfully.
    Registry Data Items Detected: 0
    Folders Detected: 24
    C:\Program Files\FunWebProducts (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\FunWebProducts\Installr (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\FunWebProducts\Installr\1.bin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\FunWebProducts\Installr\1.bin\chrome (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\FunWebProducts\ScreenSaver (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\FunWebProducts\ScreenSaver\Images (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\FunWebProducts\Shared (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\FunWebProducts\Shared\Cache (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch (Adware.MyWebSearch) -> Delete on reboot.
    C:\Program Files\MyWebSearch\bar (Adware.MyWebSearch) -> Delete on reboot.
    C:\Program Files\MyWebSearch\bar\1.bin (Adware.MyWebSearch) -> Delete on reboot.
    C:\Program Files\MyWebSearch\bar\1.bin\chrome (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\1.bin\ThirdPartyInstallers (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Avatar (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Cache (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Game (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\History (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\icons (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\IE9Mesg (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Message (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Message\COMMON (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Notifier (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Overlay (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Settings (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    Files Detected: 126
    C:\WINDOWS\system32\f3PSSavr.scr (PUP.FunWebProducts) -> No action taken.
    C:\Program Files\MyWebSearch\bar\1.bin\MWSOESTB.DLL (Adware.MyWebSearch) -> Delete on reboot.
    C:\Program Files\MyWebSearch\bar\1.bin\MWSOEMON.EXE (Adware.MyWebSearch) -> Delete on reboot.
    C:\Program Files\MyWebSearch\bar\1.bin\M3SRCHMN.EXE (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\1.bin\MWSSVC.EXE (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\1.bin\MWSSRCAS.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\1.bin\MWSBAR.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\1.bin\F3HISTSW.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\1.bin\F3DTACTL.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\1.bin\F3HTMLMU.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\1.bin\M3HTML.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\1.bin\F3POPSWT.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\1.bin\M3SKIN.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\1.bin\F3CJPEG.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\1.bin\F3SCRCTR.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\1.bin\M3OUTLCN.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\1.bin\F3HTTPCT.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\1.bin\M3MSG.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\1.bin\F3REPROX.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\1.bin\MWSOEPLG.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\WINDOWS\system32\f3PSSavr.scr (Trojan.Agent) -> Quarantined and deleted successfully.
    C:\Program Files\FunWebProducts\Shared\Cache\CursorManiaBtn.html (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\FunWebProducts\Shared\Cache\SmileyCentralBtn.html (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\FunWebProducts\Shared\Cache\WebfettiBtn.html (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\1.bin\F3SPACER.WMV (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\1.bin\CHROME.MANIFEST (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\1.bin\F3BKGERR.JPG (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\1.bin\F3HKSTUB.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\1.bin\F3IMSTUB.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\1.bin\F3PSSAVR.SCR (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\1.bin\F3REGHK.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\1.bin\F3RESTUB.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\1.bin\F3SCHMON.EXE (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\1.bin\F3WALLPP.DAT (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\1.bin\F3WPHOOK.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\1.bin\FWPBUDDY.PNG (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\1.bin\INSTALL.RDF (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\1.bin\M3AUXSTB.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\1.bin\M3DLGHK.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\1.bin\M3HIGHIN.EXE (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\1.bin\M3IDLE.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\1.bin\M3IEOVR.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\1.bin\M3IMPIPE.EXE (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\1.bin\M3MEDINT.EXE (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\1.bin\M3PLUGIN.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\1.bin\M3SKPLAY.EXE (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\1.bin\M3SLSRCH.EXE (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\1.bin\M3TPINST.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\1.bin\MWSMLBTN.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\1.bin\MWSUABTN.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\1.bin\NPMYWEBS.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\1.bin\chrome\M3FFXTBR.JAR (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Avatar\COMMON.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Cache\0191CB8E (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Cache\0191CF28 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Cache\0191EBF7.bin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Cache\0191ECB3.bin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Cache\0191FDCA.bin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Cache\0192005A.bin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Cache\0192023E.bin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Cache\030EDE3E.bmp (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Cache\030EDF58.bin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Cache\030EE023.bin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Cache\files.ini (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Game\CHECKERS.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Game\CHESS.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Game\REVERSI.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\History\search3 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\icons\CM.ICO (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\icons\MFC.ICO (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\icons\PSS.ICO (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\icons\SMILEY.ICO (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\icons\WB.ICO (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\icons\ZWINKY.ICO (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\IE9Mesg\COMMON.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Message\COMMON.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Message\COMMON\8_step1.gif (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Message\COMMON\autoup.gif (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Message\COMMON\autoup.htm (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Message\COMMON\bkez.jpg (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Message\COMMON\bkgr.jpg (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Message\COMMON\bkgs.jpg (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Message\COMMON\bklf.jpg (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Message\COMMON\bkrg.jpg (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Message\COMMON\bkwebfet.jpg (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Message\COMMON\bkzc.jpg (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Message\COMMON\bkzl.jpg (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Message\COMMON\bkzn.jpg (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Message\COMMON\bkzq.jpg (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Message\COMMON\bkzr.jpg (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Message\COMMON\bkzu.jpg (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Message\COMMON\bkzv.jpg (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Message\COMMON\bkzw.jpg (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Message\COMMON\bkzwinky.jpg (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Message\COMMON\blubtn2d.png (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Message\COMMON\blubtn2r.png (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Message\COMMON\blubtn3d.png (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Message\COMMON\blubtn3r.png (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Message\COMMON\center.htm (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Message\COMMON\index.htm (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Message\COMMON\mid_dots.gif (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Message\COMMON\protect.htm (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Message\COMMON\rebut4.htm (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Message\COMMON\rebut4b.htm (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Message\COMMON\rebut4c.htm (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Message\COMMON\shield.png (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Message\COMMON\shocked.gif (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Message\COMMON\stop.gif (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Message\COMMON\systray.htm (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Message\COMMON\systrayp.htm (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Message\COMMON\tp_grad.gif (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Message\COMMON\warn.gif (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Notifier\COMMON.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Notifier\DOG.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Notifier\FISH.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Notifier\KUNGFU.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Notifier\LIFEGARD.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Notifier\MAID.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Notifier\MAILBOX.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Notifier\OPERA.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Notifier\ROBOT.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Notifier\SEDUCT.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Notifier\SURFER.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Overlay\COMMON.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Settings\prevcfg2.htm (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    C:\Program Files\MyWebSearch\bar\Settings\s_pid.dat (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    (end)
    SVEN,
  2. 2012/01/14
    SVEN
    GMER 1.0.15.15641 - http://www.gmer.net
    Rootkit scan 2012-01-14 11:39:22
    Windows 5.1.2600 Service Pack 3 Harddisk0\DR0 -> \Device\Ide\IdeDeviceP0T0L0-4 WDC_WD400BB-00GFA0 rev.09.01B09
    Running: o215t285.exe; Driver: C:\DOCUME~1\SVENAL~1\LOCALS~1\Temp\uwdiiaow.sys
    ---- Kernel code sections - GMER 1.0.15 ----
    ? C:\Documents and Settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{D10862DB-164B-4EBE-B29A-E9BAF01F0AD7}\MpKsl79b2df12.sys The system cannot find the file specified. !
    ? C:\Documents and Settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{D10862DB-164B-4EBE-B29A-E9BAF01F0AD7}\MpKsl46fa41df.sys The system cannot find the file specified. !
    ? C:\Documents and Settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{D10862DB-164B-4EBE-B29A-E9BAF01F0AD7}\MpKsl41a884fe.sys The system cannot find the file specified. !
    ? C:\Documents and Settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{D10862DB-164B-4EBE-B29A-E9BAF01F0AD7}\MpKsl092cca26.sys The system cannot find the file specified. !
    ? C:\Documents and Settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{D10862DB-164B-4EBE-B29A-E9BAF01F0AD7}\MpKsl084d3047.sys The system cannot find the file specified. !
    ? C:\DOCUME~1\SVENAL~1\LOCALS~1\Temp\aswMBR.sys The system cannot find the file specified. !
    ? C:\DOCUME~1\SVENAL~1\LOCALS~1\Temp\mbr.sys The system cannot find the file specified. !
    ---- User IAT/EAT - GMER 1.0.15 ----
    IAT C:\WINDOWS\Explorer.EXE[1708] @ C:\WINDOWS\system32\kernel32.dll [ntdll.dll!NtCreateFile] [023A2F20] C:\WINDOWS\TEMP\logishrd\LVPrcInj01.dll (Camera Helper Library./Logitech Inc.)
    IAT C:\WINDOWS\Explorer.EXE[1708] @ C:\WINDOWS\system32\kernel32.dll [ntdll.dll!NtDeviceIoControlFile] [023A2C90] C:\WINDOWS\TEMP\logishrd\LVPrcInj01.dll (Camera Helper Library./Logitech Inc.)
    IAT C:\WINDOWS\Explorer.EXE[1708] @ C:\WINDOWS\system32\kernel32.dll [ntdll.dll!NtClose] [023A2CF0] C:\WINDOWS\TEMP\logishrd\LVPrcInj01.dll (Camera Helper Library./Logitech Inc.)
    IAT C:\WINDOWS\Explorer.EXE[1708] @ C:\WINDOWS\system32\kernel32.dll [ntdll.dll!NtDuplicateObject] [023A2CC0] C:\WINDOWS\TEMP\logishrd\LVPrcInj01.dll (Camera Helper Library./Logitech Inc.)
    IAT C:\Program Files\Logitech\Logitech WebCam Software\LWS.exe[1904] @ C:\WINDOWS\system32\kernel32.dll [ntdll.dll!NtCreateFile] [010D2F20] C:\WINDOWS\TEMP\logishrd\LVPrcInj01.dll (Camera Helper Library./Logitech Inc.)
    IAT C:\Program Files\Logitech\Logitech WebCam Software\LWS.exe[1904] @ C:\WINDOWS\system32\kernel32.dll [ntdll.dll!NtDeviceIoControlFile] [010D2C90] C:\WINDOWS\TEMP\logishrd\LVPrcInj01.dll (Camera Helper Library./Logitech Inc.)
    IAT C:\Program Files\Logitech\Logitech WebCam Software\LWS.exe[1904] @ C:\WINDOWS\system32\kernel32.dll [ntdll.dll!NtClose] [010D2CF0] C:\WINDOWS\TEMP\logishrd\LVPrcInj01.dll (Camera Helper Library./Logitech Inc.)
    IAT C:\Program Files\Logitech\Logitech WebCam Software\LWS.exe[1904] @ C:\WINDOWS\system32\kernel32.dll [ntdll.dll!NtDuplicateObject] [010D2CC0] C:\WINDOWS\TEMP\logishrd\LVPrcInj01.dll (Camera Helper Library./Logitech Inc.)
    IAT C:\Program Files\Messenger\msmsgs.exe[1960] @ C:\WINDOWS\system32\kernel32.dll [ntdll.dll!NtCreateFile] [00FE2F20] C:\WINDOWS\TEMP\logishrd\LVPrcInj01.dll (Camera Helper Library./Logitech Inc.)
    IAT C:\Program Files\Messenger\msmsgs.exe[1960] @ C:\WINDOWS\system32\kernel32.dll [ntdll.dll!NtDeviceIoControlFile] [00FE2C90] C:\WINDOWS\TEMP\logishrd\LVPrcInj01.dll (Camera Helper Library./Logitech Inc.)
    IAT C:\Program Files\Messenger\msmsgs.exe[1960] @ C:\WINDOWS\system32\kernel32.dll [ntdll.dll!NtClose] [00FE2CF0] C:\WINDOWS\TEMP\logishrd\LVPrcInj01.dll (Camera Helper Library./Logitech Inc.)
    IAT C:\Program Files\Messenger\msmsgs.exe[1960] @ C:\WINDOWS\system32\kernel32.dll [ntdll.dll!NtDuplicateObject] [00FE2CC0] C:\WINDOWS\TEMP\logishrd\LVPrcInj01.dll (Camera Helper Library./Logitech Inc.)
    ---- Devices - GMER 1.0.15 ----
    AttachedDevice \Driver\Ftdisk \Device\HarddiskVolume1 BTOWSVF.sys (BTOWS TimeFreeze/BTOWS.com)
    AttachedDevice \Driver\Ftdisk \Device\HarddiskVolume2 BTOWSVF.sys (BTOWS TimeFreeze/BTOWS.com)
    AttachedDevice \Driver\Ftdisk \Device\HarddiskVolume3 BTOWSVF.sys (BTOWS TimeFreeze/BTOWS.com)
    AttachedDevice \Driver\Ftdisk \Device\HarddiskVolume4 BTOWSVF.sys (BTOWS TimeFreeze/BTOWS.com)
    AttachedDevice \FileSystem\Fastfat \Fat fltmgr.sys (Microsoft Filesystem Filter Manager/Microsoft Corporation)
    ---- EOF - GMER 1.0.15 ----
    SVEN,
    SVEN
    DDS (Ver_2011-08-26.01) - NTFSx86
    Internet Explorer: 8.0.6001.18702
    Run by Sven Albrecht at 9:49:55 on 2012-01-14
    Microsoft Windows XP Home Edition 5.1.2600.3.1252.1.1033.18.1023.555 [GMT -8:00]
    AV: Microsoft Security Essentials *Enabled/Updated* {EDB4FA23-53B8-4AFA-8C5D-99752CCA7095}
    C:\WINDOWS\system32\Ati2evxx.exe
    C:\WINDOWS\system32\svchost -k DcomLaunch
    svchost.exe
    C:\Program Files\Microsoft Security Client\Antimalware\MsMpEng.exe
    C:\WINDOWS\System32\svchost.exe -k netsvcs
    svchost.exe
    svchost.exe
    C:\WINDOWS\system32\LEXBCES.EXE
    C:\WINDOWS\system32\LEXPPS.EXE
    svchost.exe
    C:\PROGRA~1\SSS\SIMPLESCREENSHOT.EXE
    C:\Program Files\Microsoft Security Client\msseces.exe
    C:\Program Files\Common Files\Java\Java Update\jusched.exe
    C:\Program Files\Microsoft Office\Office10\msoffice.exe
    C:\WINDOWS\System32\svchost.exe -k HTTPFilter
    C:\Program Files\Common Files\LogiShrd\LVMVFM\LVPrcSrv.exe
    C:\Program Files\Common Files\Logishrd\LQCVFX\COCIManager.exe
    C:\WINDOWS\system32\svchost.exe -k imgsvc
    C:\WINDOWS\system32\MsPMSPSv.exe
    uStart Page = hxxp://www.windowsbbs.com/
    uInternet Connection Wizard,ShellNext = iexplore
    BHO: Adobe PDF Link Helper: {18df081c-e8ad-4283-a596-fa578c2ebdc3} - c:\program files\common files\adobe\acrobat\activex\AcroIEHelperShim.dll
    BHO: MediaBar: {28387537-e3f9-4ed7-860c-11e69af4a8a0} - MediaBar
    BHO: {474597c5-ab09-49d6-a4d5-2e8d7341384e} - UrlHelper Class
    BHO: Skype Browser Helper: {ae805869-2e5c-4ed4-8f7b-f1f7851a4497} - c:\program files\skype\toolbars\internet explorer\skypeieplugin.dll
    BHO: Java(tm) Plug-In 2 SSV Helper: {dbc80044-a445-435b-bc74-9c25c1c588a9} - c:\program files\java\jre6\bin\jp2ssv.dll
    BHO: JQSIEStartDetectorImpl Class: {e7e6f031-17ce-4c07-bc86-eabfe594f69c} - c:\program files\java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll
    TB: MediaBar: {28387537-e3f9-4ed7-860c-11e69af4a8a0} -
    uRun: [ctfmon.exe] c:\windows\system32\ctfmon.exe
    uRun: [MSMSGS] "c:\program files\messenger\msmsgs.exe" /background
    uRun: [ToolwizCareFree] "c:\program files\toolwizcarefree\ToolwizCares.exe" -autorun
    mRun: [NeroFilterCheck] c:\windows\system32\NeroCheck.exe
    mRun: [SimpleScreenshot] c:\progra~1\sss\SIMPLESCREENSHOT.EXE
    mRun: [Cmaudio] RunDll32 cmicnfg.cpl,CMICtrlWnd
    mRun: [MSC] "c:\program files\microsoft security client\msseces.exe" -hide -runkey
    mRun: [LogitechQuickCamRibbon] "c:\program files\logitech\logitech webcam software\LWS.exe" /hide
    mRun: [SunJavaUpdateSched] "c:\program files\common files\java\java update\jusched.exe "
    dRunOnce: [RunNarrator] Narrator.exe
    StartupFolder: c:\docume~1\alluse~1\startm~1\programs\startup\micros~1.lnk - c:\program files\microsoft office\office10\OSA.EXE
    IE: &ieSpell Options - c:\program files\iespell\iespell.dll/SPELLOPTION.HTM
    IE: &Search
    IE: Check &Spelling - c:\program files\iespell\iespell.dll/SPELLCHECK.HTM
    IE: E&xport to Microsoft Excel - c:\progra~1\micros~3\office10\EXCEL.EXE/3000
    IE: Lookup on Merriam Webster - file://c:\program files\iespell\Merriam Webster.HTM
    IE: Lookup on Wikipedia - file://c:\program files\iespell\wikipedia.HTM
    IE: {0E17D5B7-9F5D-4fee-9DF6-CA6EE38B68A8} - res://c:\program files\iespell\iespell.dll/SPELLCHECK.HTM
    IE: {1606D6F9-9D3B-4aea-A025-ED5B2FD488E7} - res://c:\program files\iespell\iespell.dll/SPELLOPTION.HTM
    IE: {e2e2dd38-d088-4134-82b7-f2ba38496583} - %windir%\Network Diagnostic\xpnetdiag.exe
    IE: {FA9B9510-9FCB-4ca0-818C-5D0987B47C4D} - c:\program files\pokerstars.net\PokerStarsUpdate.exe
    IE: {FB5F1910-F110-11d2-BB9E-00C04F795683} - c:\program files\messenger\msmsgs.exe
    IE: {898EA8C8-E7FF-479B-8935-AEC46303B9E5} - {898EA8C8-E7FF-479B-8935-AEC46303B9E5} - c:\program files\skype\toolbars\internet explorer\skypeieplugin.dll
    Trusted Zone: clonewarsadventures.com
    Trusted Zone: freerealms.com
    Trusted Zone: soe.com
    Trusted Zone: sony.com
    DPF: {000F1EA4-5E08-4564-A29B-29076F63A37A} - hxxp://launch.soe.com/plugin/web/SOEWebInstaller.cab
    DPF: {6E32070A-766D-4EE6-879C-DC1FA91D2FC3} - hxxp://www.update.microsoft.com/microsoftupdate/v6/V5Controls/en/x86/client/muweb_site.cab?1271466570453
    DPF: {7530BFB8-7293-4D34-9923-61A11451AFC5} - hxxp://download.eset.com/special/eos/OnlineScanner.cab
    DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} - hxxp://java.sun.com/update/1.6.0/jinstall-1_6_0_29-windows-i586.cab
    DPF: {BEA7310D-06C4-4339-A784-DC3804819809} - hxxp://www.cvsphoto.com/upload/activex/v3_0_0_7/PhotoCenter_ActiveX_Control.cab
    DPF: {CAFEEFAC-0016-0000-0029-ABCDEFFEDCBA} - hxxp://java.sun.com/update/1.6.0/jinstall-1_6_0_29-windows-i586.cab
    DPF: {CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} - hxxp://java.sun.com/update/1.6.0/jinstall-1_6_0_29-windows-i586.cab
    DPF: {D27CDB6E-AE6D-11CF-96B8-444553540000} - hxxp://fpdownload2.macromedia.com/get/shockwave/cabs/flash/swflash.cab
    DPF: {E2883E8F-472F-4FB0-9522-AC9BF37916A7} - hxxp://platformdl.adobe.com/NOS/getPlusPlus/1.6/gp.cab
    TCP: DhcpNameServer = 192.168.1.1
    TCP: Interfaces\{2D059D5C-CF29-4C6A-9175-92727DF0AF38} : DhcpNameServer = 192.168.1.1
    Handler: skype-ie-addon-data - {91774881-D725-4E58-B298-07617B9B86A8} - c:\program files\skype\toolbars\internet explorer\skypeieplugin.dll
    Notify: AtiExtEvent - Ati2evxx.dll
    AppInit_DLLs: c:\progra~1\imesha~1\mediabar\datamngr\datamngr.dll c:\progra~1\imesha~1\mediabar\datamngr\IEBHO.dll
    SSODL: WPDShServiceObj - {AAA288BA-9A4C-45B0-95D7-94D524869DB5} - c:\windows\system32\WPDShServiceObj.dll
    R0 BTOWSVF;BTOWSVF;c:\windows\system32\drivers\BTOWSVF.sys [2012-1-7 41856]
    R0 KSafeDISK;KSafeDISK;c:\windows\system32\drivers\KSafeDISK.sys [2012-1-7 46592]
    R1 BTOWSFF;BTOWSFF;c:\windows\system32\drivers\BTOWSFF.sys [2012-1-7 24832]
    R1 MpFilter;Microsoft Malware Protection Driver;c:\windows\system32\drivers\MpFilter.sys [2010-10-24 165648]
    R1 MpKsl084d3047;MpKsl084d3047;c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{d10862db-164b-4ebe-b29a-e9baf01f0ad7}\MpKsl084d3047.sys [2012-1-12 29904]
    R1 MpKsl092cca26;MpKsl092cca26;c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{d10862db-164b-4ebe-b29a-e9baf01f0ad7}\MpKsl092cca26.sys [2012-1-13 29904]
    R1 MpKsl41a884fe;MpKsl41a884fe;c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{d10862db-164b-4ebe-b29a-e9baf01f0ad7}\MpKsl41a884fe.sys [2012-1-12 29904]
    R1 MpKsl46fa41df;MpKsl46fa41df;c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{d10862db-164b-4ebe-b29a-e9baf01f0ad7}\MpKsl46fa41df.sys [2012-1-12 29904]
    R1 MpKsl66a5b29c;MpKsl66a5b29c;c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{d10862db-164b-4ebe-b29a-e9baf01f0ad7}\MpKsl66a5b29c.sys [2012-1-14 29904]
    R1 MpKsl79b2df12;MpKsl79b2df12;c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{d10862db-164b-4ebe-b29a-e9baf01f0ad7}\MpKsl79b2df12.sys [2012-1-12 29904]
    R2 nxsIO32;NextSensor Kernel I/O Driver;c:\windows\system32\drivers\nxsIO32.sys [2011-7-11 2208]
    R3 dvdfab;dvdfab;c:\windows\system32\drivers\dvdfab.sys [2011-3-19 82816]
    S1 MpKsl0da5cdad;MpKsl0da5cdad;\??\c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{19a3822c-aa13-4ce0-9f7f-4e58bd6b7c2d}\mpksl0da5cdad.sys --> c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{19a3822c-aa13-4ce0-9f7f-4e58bd6b7c2d}\MpKsl0da5cdad.sys [?]
    S1 MpKsl1d9a279e;MpKsl1d9a279e;\??\c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{19a3822c-aa13-4ce0-9f7f-4e58bd6b7c2d}\mpksl1d9a279e.sys --> c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{19a3822c-aa13-4ce0-9f7f-4e58bd6b7c2d}\MpKsl1d9a279e.sys [?]
    S1 MpKsl6a75b4d1;MpKsl6a75b4d1;c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{d10862db-164b-4ebe-b29a-e9baf01f0ad7}\MpKsl6a75b4d1.sys [2012-1-12 29904]
    S1 MpKsl7da4a7ac;MpKsl7da4a7ac;\??\c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{19a3822c-aa13-4ce0-9f7f-4e58bd6b7c2d}\mpksl7da4a7ac.sys --> c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{19a3822c-aa13-4ce0-9f7f-4e58bd6b7c2d}\MpKsl7da4a7ac.sys [?]
    S1 MpKsl7db78654;MpKsl7db78654;\??\c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{52e7c91f-94a5-4db8-be7b-ce59a53ed850}\mpksl7db78654.sys --> c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{52e7c91f-94a5-4db8-be7b-ce59a53ed850}\MpKsl7db78654.sys [?]
    S1 MpKsla018b693;MpKsla018b693;c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{d10862db-164b-4ebe-b29a-e9baf01f0ad7}\MpKsla018b693.sys [2012-1-12 29904]
    S1 MpKslbb685873;MpKslbb685873;c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{d10862db-164b-4ebe-b29a-e9baf01f0ad7}\MpKslbb685873.sys [2012-1-12 29904]
    S1 MpKsld70019f1;MpKsld70019f1;\??\c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{f30f5648-297e-4995-a3c7-43e3382e3a16}\mpksld70019f1.sys --> c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{f30f5648-297e-4995-a3c7-43e3382e3a16}\MpKsld70019f1.sys [?]
    S1 MpKsle10af837;MpKsle10af837;\??\c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{19a3822c-aa13-4ce0-9f7f-4e58bd6b7c2d}\mpksle10af837.sys --> c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{19a3822c-aa13-4ce0-9f7f-4e58bd6b7c2d}\MpKsle10af837.sys [?]
    S1 MpKslfc56a8e9;MpKslfc56a8e9;\??\c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{19a3822c-aa13-4ce0-9f7f-4e58bd6b7c2d}\mpkslfc56a8e9.sys --> c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{19a3822c-aa13-4ce0-9f7f-4e58bd6b7c2d}\MpKslfc56a8e9.sys [?]
    S2 clr_optimization_v4.0.30319_32;Microsoft .NET Framework NGEN v4.0.30319_X86;c:\windows\microsoft.net\framework\v4.0.30319\mscorsvw.exe [2010-3-18 130384]
    S2 Freemake Improver;Freemake Improver;c:\documents and settings\all users\application data\freemake\freemakeutilsservice\FreemakeUtilsService.exe [2011-11-24 74752]
    S3 cpuz132;cpuz132;\??\c:\docume~1\svenal~1\locals~1\temp\cpuz132\cpuz132_x32.sys --> c:\docume~1\svenal~1\locals~1\temp\cpuz132\cpuz132_x32.sys [?]
    S3 scsiscan;SCSI Scanner Driver;c:\windows\system32\drivers\scsiscan.sys [2010-4-16 11520]
    S3 Vsp;Vsp;\??\c:\windows\system32\drivers\vsp.sys --> c:\windows\system32\drivers\Vsp.sys [?]
    S3 WinRM;Windows Remote Management (WS-Management);c:\windows\system32\svchost.exe -k WINRM [2004-8-3 14336]
    S3 WPFFontCache_v0400;Windows Presentation Foundation Font Cache 4.0.0.0;c:\windows\microsoft.net\framework\v4.0.30319\wpf\WPFFontCache_v0400.exe [2010-3-18 753504]
    2012-01-14 17:44:59 29904 ----a-w- c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{d10862db-164b-4ebe-b29a-e9baf01f0ad7}\MpKsl66a5b29c.sys
    2012-01-14 02:40:46 29904 ----a-w- c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{d10862db-164b-4ebe-b29a-e9baf01f0ad7}\MpKsl092cca26.sys
    2012-01-13 04:03:06 29904 ----a-w- c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{d10862db-164b-4ebe-b29a-e9baf01f0ad7}\MpKsl084d3047.sys
    2012-01-13 04:00:01 29904 ----a-w- c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{d10862db-164b-4ebe-b29a-e9baf01f0ad7}\MpKslce80e283.sys
    2012-01-13 03:57:42 29904 ----a-w- c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{d10862db-164b-4ebe-b29a-e9baf01f0ad7}\MpKslbb685873.sys
    2012-01-13 03:56:53 29904 ----a-w- c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{d10862db-164b-4ebe-b29a-e9baf01f0ad7}\MpKsl46fa41df.sys
    2012-01-13 03:52:24 29904 ----a-w- c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{d10862db-164b-4ebe-b29a-e9baf01f0ad7}\MpKsl79b2df12.sys
    2012-01-13 03:49:32 29904 ----a-w- c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{d10862db-164b-4ebe-b29a-e9baf01f0ad7}\MpKsla018b693.sys
    2012-01-13 03:46:50 29904 ----a-w- c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{d10862db-164b-4ebe-b29a-e9baf01f0ad7}\MpKsl6a75b4d1.sys
    2012-01-13 03:41:25 29904 ----a-w- c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{d10862db-164b-4ebe-b29a-e9baf01f0ad7}\MpKsl41a884fe.sys
    2012-01-13 03:41:21 56200 ----a-w- c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{d10862db-164b-4ebe-b29a-e9baf01f0ad7}\offreg.dll
    2012-01-13 03:41:04 6823496 ----a-w- c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{d10862db-164b-4ebe-b29a-e9baf01f0ad7}\mpengine.dll
    2012-01-12 04:13:58 -------- d-----w- C:\symbols
    2012-01-11 04:30:45 -------- d-----w- c:\program files\WhoCrashed
    2012-01-08 05:32:53 46592 ----a-w- c:\windows\system32\drivers\KSafeDISK.sys
    2012-01-08 05:32:53 24832 ----a-w- c:\windows\system32\drivers\BTOWSFF.sys
    2012-01-08 05:32:53 -------- d--h--w- C:\Toolwiz
    2012-01-08 05:32:52 41856 ----a-w- c:\windows\system32\drivers\BTOWSVF.sys
    2012-01-08 05:32:37 -------- d-----w- c:\documents and settings\sven albrecht\local settings\application data\ToolwizCareFree
    2012-01-01 22:28:48 6823496 ----a-w- c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\backup\mpengine.dll
    2011-12-18 18:01:45 -------- d-----w- c:\program files\ToolwizCareFree
    2011-12-10 23:24:06 20464 ----a-w- c:\windows\system32\drivers\mbam.sys
    2011-11-25 21:57:19 293376 ----a-w- c:\windows\system32\winsrv.dll
    2011-11-23 13:25:32 1859584 ----a-w- c:\windows\system32\win32k.sys
    2011-11-18 12:35:08 60416 ----a-w- c:\windows\system32\packager.exe
    2011-11-16 01:38:23 414368 ----a-w- c:\windows\system32\FlashPlayerCPLApp.cpl
    2011-11-04 19:20:51 916992 ----a-w- c:\windows\system32\wininet.dll
    2011-11-04 19:20:51 43520 ----a-w- c:\windows\system32\licmgr10.dll
    2011-11-04 19:20:51 1469440 ------w- c:\windows\system32\inetcpl.cpl
    2011-11-04 11:23:59 385024 ------w- c:\windows\system32\html.iec
    2011-11-03 15:28:36 386048 ----a-w- c:\windows\system32\qdvd.dll
    2011-11-03 15:28:36 1292288 ----a-w- c:\windows\system32\quartz.dll
    2011-11-01 16:07:10 1288704 ----a-w- c:\windows\system32\ole32.dll
    2011-10-28 05:31:48 33280 ----a-w- c:\windows\system32\csrsrv.dll
    2011-10-25 13:33:08 2192768 ----a-w- c:\windows\system32\ntoskrnl.exe
    2011-10-25 12:52:03 2069376 ----a-w- c:\windows\system32\ntkrnlpa.exe
    2011-10-18 11:13:22 186880 ----a-w- c:\windows\system32\encdec.dll
    ============= FINISH: 9:50:41.54 ===============
    SVEN,
    SVEN
    UNLESS SPECIFICALLY INSTRUCTED, DO NOT POST THIS LOG.
    IF REQUESTED, ZIP IT UP & ATTACH IT
    Boot Device: \Device\HarddiskVolume1
    Install Date: 4/16/2010 2:58:50 PM
    System Uptime: 1/14/2012 9:43:24 AM (0 hours ago)
    Motherboard: soyocomputer | | K7VM333
    Processor: AMD Athlon(tm) XP 2000+ | Socket-A | 1666/133mhz
    ==== Disk Partitions =========================
    A: is Removable
    C: is FIXED (NTFS) - 35 GiB total, 14.506 GiB free.
    D: is FIXED (NTFS) - 37 GiB total, 18.723 GiB free.
    E: is FIXED (NTFS) - 2 GiB total, 1.184 GiB free.
    F: is FIXED (NTFS) - 37 GiB total, 22.607 GiB free.
    G: is CDROM ()
    H: is CDROM ()
    ==== Disabled Device Manager Items =============
    ==== System Restore Points ===================
    RP561: 10/30/2011 9:12:45 AM - Software Distribution Service 3.0
    RP562: 10/30/2011 7:12:28 PM - Software Distribution Service 3.0
    RP563: 10/31/2011 7:21:44 PM - System Checkpoint
    RP564: 11/1/2011 5:57:22 PM - Software Distribution Service 3.0
    RP565: 11/2/2011 8:05:00 PM - Software Distribution Service 3.0
    RP566: 11/3/2011 8:17:36 PM - System Checkpoint
    RP567: 11/4/2011 5:50:11 PM - Software Distribution Service 3.0
    RP568: 11/5/2011 6:13:56 PM - System Checkpoint
    RP569: 11/6/2011 7:57:16 AM - Software Distribution Service 3.0
    RP570: 11/6/2011 6:38:30 PM - Software Distribution Service 3.0
    RP571: 11/7/2011 6:52:05 PM - System Checkpoint
    RP572: 11/8/2011 5:03:57 PM - Software Distribution Service 3.0
    RP573: 11/9/2011 8:18:36 PM - Software Distribution Service 3.0
    RP574: 11/9/2011 8:32:50 PM - Software Distribution Service 3.0
    RP575: 11/10/2011 6:09:11 PM - Software Distribution Service 3.0
    RP576: 11/11/2011 8:57:08 AM - Software Distribution Service 3.0
    RP577: 11/12/2011 9:25:52 AM - System Checkpoint
    RP578: 11/15/2011 5:48:49 PM - Software Distribution Service 3.0
    RP579: 11/18/2011 5:27:12 PM - Software Distribution Service 3.0
    RP580: 11/19/2011 7:35:08 PM - Software Distribution Service 3.0
    RP581: 11/20/2011 6:57:28 PM - Software Distribution Service 3.0
    RP582: 11/21/2011 1:14:27 PM - Installed Compatibility Pack for the 2007 Office system
    RP583: 11/22/2011 11:37:21 AM - Software Distribution Service 3.0
    RP584: 11/22/2011 1:56:28 PM - Software Distribution Service 3.0
    RP585: 11/23/2011 11:47:11 AM - Software Distribution Service 3.0
    RP586: 11/24/2011 11:52:56 AM - System Checkpoint
    RP587: 11/25/2011 9:43:36 AM - Software Distribution Service 3.0
    RP588: 11/26/2011 11:30:17 AM - Software Distribution Service 3.0
    RP589: 11/27/2011 12:18:36 PM - System Checkpoint
    RP590: 11/27/2011 6:51:51 PM - Software Distribution Service 3.0
    RP591: 12/2/2011 8:20:01 AM - Software Distribution Service 3.0
    RP592: 12/3/2011 10:48:38 AM - Software Distribution Service 3.0
    RP593: 12/4/2011 10:51:22 AM - System Checkpoint
    RP594: 12/4/2011 5:37:26 PM - Software Distribution Service 3.0
    RP595: 12/5/2011 5:53:03 PM - System Checkpoint
    RP596: 12/6/2011 5:56:36 PM - Software Distribution Service 3.0
    RP597: 12/7/2011 8:04:08 PM - Software Distribution Service 3.0
    RP598: 12/8/2011 8:50:04 PM - System Checkpoint
    RP599: 12/9/2011 3:12:04 PM - Software Distribution Service 3.0
    RP600: 12/10/2011 4:36:09 PM - System Checkpoint
    RP601: 12/11/2011 10:03:03 AM - Software Distribution Service 3.0
    RP602: 12/11/2011 7:13:35 PM - Software Distribution Service 3.0
    RP603: 12/12/2011 7:36:04 PM - System Checkpoint
    RP604: 12/13/2011 5:37:42 PM - Software Distribution Service 3.0
    RP605: 12/13/2011 5:49:25 PM - Software Distribution Service 3.0
    RP606: 12/14/2011 8:11:03 PM - Software Distribution Service 3.0
    RP607: 12/15/2011 9:42:33 PM - System Checkpoint
    RP608: 12/16/2011 6:50:04 PM - Software Distribution Service 3.0
    RP609: 12/17/2011 7:15:33 PM - System Checkpoint
    RP610: 12/18/2011 9:19:25 AM - Software Distribution Service 3.0
    RP611: 12/18/2011 7:04:52 PM - Software Distribution Service 3.0
    RP612: 12/19/2011 7:39:00 PM - System Checkpoint
    RP613: 12/20/2011 10:11:10 AM - Software Distribution Service 3.0
    RP614: 12/21/2011 3:26:57 PM - Software Distribution Service 3.0
    RP615: 12/22/2011 4:00:22 PM - System Checkpoint
    RP616: 12/23/2011 9:14:51 AM - Software Distribution Service 3.0
    RP617: 12/24/2011 10:20:41 AM - Software Distribution Service 3.0
    RP618: 12/25/2011 10:46:36 AM - System Checkpoint
    RP619: 12/25/2011 6:34:35 PM - Software Distribution Service 3.0
    RP620: 12/28/2011 2:56:52 PM - Software Distribution Service 3.0
    RP621: 12/29/2011 3:32:11 PM - System Checkpoint
    RP622: 12/30/2011 8:18:58 AM - Software Distribution Service 3.0
    RP623: 12/31/2011 9:45:46 AM - Software Distribution Service 3.0
    RP624: 1/1/2012 9:53:20 AM - System Checkpoint
    RP625: 1/1/2012 2:28:05 PM - Software Distribution Service 3.0
    RP626: 1/2/2012 3:19:09 PM - System Checkpoint
    RP627: 1/3/2012 8:06:34 AM - Software Distribution Service 3.0
    RP628: 1/4/2012 8:42:53 AM - Software Distribution Service 3.0
    RP629: 1/5/2012 5:26:04 PM - Software Distribution Service 3.0
    RP630: 1/6/2012 5:31:40 PM - System Checkpoint
    RP631: 1/7/2012 9:36:42 AM - Software Distribution Service 3.0
    RP632: 1/7/2012 10:41:50 PM - Clean Registry Errors
    RP633: 1/7/2012 10:43:57 PM - Clean Registry Errors
    RP634: 1/7/2012 10:44:48 PM - Clean Registry Errors
    RP635: 1/8/2012 6:53:06 PM - Software Distribution Service 3.0
    RP636: 1/9/2012 7:02:00 PM - System Checkpoint
    RP637: 1/9/2012 9:58:26 PM - Software Distribution Service 3.0
    RP638: 1/10/2012 9:00:16 PM - Software Distribution Service 3.0
    RP639: 1/10/2012 9:26:46 PM - Software Distribution Service 3.0
    RP640: 1/11/2012 5:31:29 PM - Software Distribution Service 3.0
    RP641: 1/11/2012 10:31:25 PM - Removed Debugging Tools for Windows (x86)
    RP642: 1/12/2012 6:55:08 PM - Software Distribution Service 3.0
    RP643: 1/14/2012 9:46:42 AM - Unsigned driver install
    ==== Installed Programs ======================
    Acrobat.com
    Adobe AIR
    Adobe Flash Player 11 ActiveX
    Adobe Reader 9.3
    AnswerWorks 5.0 English Runtime
    Any Video Converter 3.2.3
    Asterisk Key 10.0
    ATI Display Driver
    Audacity 1.3.13 (Unicode)
    Bejeweled 2 Deluxe
    C-Media WDM Audio Driver
    Click'N Design 3D for AfterBurner(tm)
    CompuPic
    Conexant SoftK56 Modem(M)
    Dell Photo Printer 720
    DesignPro 5.0 Media Edition
    doPDF 6.2 printer
    DVD Decrypter (Remove Only)
    DVD Shrink 3.2
    DVDFab 6.0.2.0 (June 24, 2009)
    DVDFab Decrypter 3.0.8.0
    DVDFab Passkey 8.0.2.6 (17/03/2011)
    ESET Online Scanner v3
    File Uploader
    Freemake Video Converter version 3.0.1
    Hotfix for Microsoft .NET Framework 3.5 SP1 (KB953595)
    Hotfix for Microsoft .NET Framework 3.5 SP1 (KB958484)
    Hotfix for Windows Media Format 11 SDK (KB929399)
    Hotfix for Windows Media Player 11 (KB939683)
    Hotfix for Windows XP (KB2158563)
    Hotfix for Windows XP (KB2443685)
    Hotfix for Windows XP (KB2570791)
    Hotfix for Windows XP (KB2633952)
    Hotfix for Windows XP (KB952287)
    Hotfix for Windows XP (KB954550-v5)
    Hotfix for Windows XP (KB961118)
    Hotfix for Windows XP (KB979306)
    Hotfix for Windows XP (KB981793)
    ieSpell
    ImgBurn (Remove Only)
    Invaders95
    Java Auto Updater
    Java(TM) 6 Update 29
    LAME v3.98.3 for Audacity
    Logitech Vid HD
    Logitech Webcam Software
    Logitech Webcam Software Driver Package
    Magic ISO Maker v5.5 (build 0281)
    Magical Jelly Bean KeyFinder
    Malwarebytes Anti-Malware version 1.60.0.1800
    MediaBar
    Microsoft .NET Framework 1.1
    Microsoft .NET Framework 1.1 Security Update (KB2656353)
    Microsoft .NET Framework 1.1 Security Update (KB979906)
    Microsoft .NET Framework 2.0 Service Pack 2
    Microsoft .NET Framework 3.0 Service Pack 2
    Microsoft .NET Framework 4 Client Profile
    Microsoft Application Error Reporting
    Microsoft Compression Client Pack 1.0 for Windows XP
    Microsoft Office XP Professional with FrontPage
    Microsoft Silverlight
    Microsoft User-Mode Driver Framework Feature Pack 1.0
    Microsoft Visual C++ 2005 Redistributable
    Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.4148
    Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.6161
    Microsoft Visual C++ 2010 x86 Redistributable - 10.0.30319
    Microsoft Word 2002
    MSXML 4.0 SP2 (KB954430)
    MSXML 4.0 SP2 (KB973688)
    Nero 6 Ultra Edition
    Nero Media Player
    NeroMIX
    NeroVision Express 3
    Nikon Message Center
    Photocopier Version 2.26
    Picture Control Utility
    PokerStars.net
    PrintFile
    PSP Video 9 4.04
    Quicken 2008
    Security Update for CAPICOM (KB931906)
    Security Update for Microsoft .NET Framework 3.5 SP1 (KB2657424)
    Security Update for Microsoft .NET Framework 4 Client Profile (KB2446708)
    Security Update for Microsoft .NET Framework 4 Client Profile (KB2478663)
    Security Update for Microsoft .NET Framework 4 Client Profile (KB2518870)
    Security Update for Microsoft .NET Framework 4 Client Profile (KB2539636)
    Security Update for Microsoft .NET Framework 4 Client Profile (KB2572078)
    Security Update for Microsoft .NET Framework 4 Client Profile (KB2656351)
    Security Update for Microsoft Windows (KB2564958)
    Security Update for Windows Internet Explorer 8 (KB2183461)
    Security Update for Windows Internet Explorer 8 (KB2360131)
    Security Update for Windows Internet Explorer 8 (KB2416400)
    Security Update for Windows Internet Explorer 8 (KB2482017)
    Security Update for Windows Internet Explorer 8 (KB2497640)
    Security Update for Windows Internet Explorer 8 (KB2510531)
    Security Update for Windows Internet Explorer 8 (KB2530548)
    Security Update for Windows Internet Explorer 8 (KB2544521)
    Security Update for Windows Internet Explorer 8 (KB2559049)
    Security Update for Windows Internet Explorer 8 (KB2586448)
    Security Update for Windows Internet Explorer 8 (KB2618444)
    Security Update for Windows Internet Explorer 8 (KB971961)
    Security Update for Windows Internet Explorer 8 (KB981332)
    Security Update for Windows Internet Explorer 8 (KB982381)
    Security Update for Windows Media Player (KB2378111)
    Security Update for Windows Media Player (KB952069)
    Security Update for Windows Media Player (KB954155)
    Security Update for Windows Media Player (KB968816)
    Security Update for Windows Media Player (KB973540)
    Security Update for Windows Media Player (KB975558)
    Security Update for Windows Media Player (KB978695)
    Security Update for Windows Media Player (KB979402)
    Security Update for Windows Media Player 11 (KB954154)
    Security Update for Windows XP (KB2079403)
    Security Update for Windows XP (KB2115168)
    Security Update for Windows XP (KB2121546)
    Security Update for Windows XP (KB2160329)
    Security Update for Windows XP (KB2229593)
    Security Update for Windows XP (KB2259922)
    Security Update for Windows XP (KB2279986)
    Security Update for Windows XP (KB2286198)
    Security Update for Windows XP (KB2296011)
    Security Update for Windows XP (KB2296199)
    Security Update for Windows XP (KB2347290)
    Security Update for Windows XP (KB2360937)
    Security Update for Windows XP (KB2387149)
    Security Update for Windows XP (KB2393802)
    Security Update for Windows XP (KB2412687)
    Security Update for Windows XP (KB2419632)
    Security Update for Windows XP (KB2423089)
    Security Update for Windows XP (KB2436673)
    Security Update for Windows XP (KB2440591)
    Security Update for Windows XP (KB2443105)
    Security Update for Windows XP (KB2476490)
    Security Update for Windows XP (KB2476687)
    Security Update for Windows XP (KB2478960)
    Security Update for Windows XP (KB2478971)
    Security Update for Windows XP (KB2479628)
    Security Update for Windows XP (KB2479943)
    Security Update for Windows XP (KB2481109)
    Security Update for Windows XP (KB2483185)
    Security Update for Windows XP (KB2485376)
    Security Update for Windows XP (KB2485663)
    Security Update for Windows XP (KB2503658)
    Security Update for Windows XP (KB2503665)
    Security Update for Windows XP (KB2506212)
    Security Update for Windows XP (KB2506223)
    Security Update for Windows XP (KB2507618)
    Security Update for Windows XP (KB2507938)
    Security Update for Windows XP (KB2508272)
    Security Update for Windows XP (KB2508429)
    Security Update for Windows XP (KB2509553)
    Security Update for Windows XP (KB2511455)
    Security Update for Windows XP (KB2524375)
    Security Update for Windows XP (KB2535512)
    Security Update for Windows XP (KB2536276-v2)
    Security Update for Windows XP (KB2536276)
    Security Update for Windows XP (KB2544893-v2)
    Security Update for Windows XP (KB2544893)
    Security Update for Windows XP (KB2555917)
    Security Update for Windows XP (KB2562937)
    Security Update for Windows XP (KB2566454)
    Security Update for Windows XP (KB2567053)
    Security Update for Windows XP (KB2567680)
    Security Update for Windows XP (KB2570222)
    Security Update for Windows XP (KB2570947)
    Security Update for Windows XP (KB2584146)
    Security Update for Windows XP (KB2592799)
    Security Update for Windows XP (KB2598479)
    Security Update for Windows XP (KB2603381)
    Security Update for Windows XP (KB2618451)
    Security Update for Windows XP (KB2619339)
    Security Update for Windows XP (KB2620712)
    Security Update for Windows XP (KB2624667)
    Security Update for Windows XP (KB2631813)
    Security Update for Windows XP (KB2633171)
    Security Update for Windows XP (KB2639417)
    Security Update for Windows XP (KB2646524)
    Security Update for Windows XP (KB923561)
    Security Update for Windows XP (KB923789)
    Security Update for Windows XP (KB941569)
    Security Update for Windows XP (KB946648)
    Security Update for Windows XP (KB950760)
    Security Update for Windows XP (KB950762)
    Security Update for Windows XP (KB950974)
    Security Update for Windows XP (KB951066)
    Security Update for Windows XP (KB951376-v2)
    Security Update for Windows XP (KB951748)
    Security Update for Windows XP (KB952004)
    Security Update for Windows XP (KB952954)
    Security Update for Windows XP (KB955069)
    Security Update for Windows XP (KB956572)
    Security Update for Windows XP (KB956744)
    Security Update for Windows XP (KB956802)
    Security Update for Windows XP (KB956803)
    Security Update for Windows XP (KB956844)
    Security Update for Windows XP (KB958644)
    Security Update for Windows XP (KB958869)
    Security Update for Windows XP (KB959426)
    Security Update for Windows XP (KB960225)
    Security Update for Windows XP (KB960803)
    Security Update for Windows XP (KB960859)
    Security Update for Windows XP (KB961501)
    Security Update for Windows XP (KB969059)
    Security Update for Windows XP (KB969947)
    Security Update for Windows XP (KB970238)
    Security Update for Windows XP (KB970430)
    Security Update for Windows XP (KB971468)
    Security Update for Windows XP (KB971657)
    Security Update for Windows XP (KB972270)
    Security Update for Windows XP (KB973354)
    Security Update for Windows XP (KB973507)
    Security Update for Windows XP (KB973869)
    Security Update for Windows XP (KB973904)
    Security Update for Windows XP (KB974112)
    Security Update for Windows XP (KB974318)
    Security Update for Windows XP (KB974392)
    Security Update for Windows XP (KB974571)
    Security Update for Windows XP (KB975025)
    Security Update for Windows XP (KB975467)
    Security Update for Windows XP (KB975560)
    Security Update for Windows XP (KB975561)
    Security Update for Windows XP (KB975562)
    Security Update for Windows XP (KB975713)
    Security Update for Windows XP (KB977816)
    Security Update for Windows XP (KB977914)
    Security Update for Windows XP (KB978037)
    Security Update for Windows XP (KB978262)
    Security Update for Windows XP (KB978338)
    Security Update for Windows XP (KB978542)
    Security Update for Windows XP (KB978601)
    Security Update for Windows XP (KB978706)
    Security Update for Windows XP (KB979309)
    Security Update for Windows XP (KB979482)
    Security Update for Windows XP (KB979559)
    Security Update for Windows XP (KB979683)
    Security Update for Windows XP (KB979687)
    Security Update for Windows XP (KB980195)
    Security Update for Windows XP (KB980218)
    Security Update for Windows XP (KB980232)
    Security Update for Windows XP (KB980436)
    Security Update for Windows XP (KB981322)
    Security Update for Windows XP (KB981852)
    Security Update for Windows XP (KB981957)
    Security Update for Windows XP (KB981997)
    Security Update for Windows XP (KB982132)
    Security Update for Windows XP (KB982214)
    Security Update for Windows XP (KB982665)
    Security Update for Windows XP (KB982802)
    SimpleScreenshot 1.20
    Skype Toolbars
    Skype™ 5.3
    Tetrus (remove)
    Toolwiz Care
    Update for Microsoft .NET Framework 3.5 SP1 (KB963707)
    Update for Microsoft .NET Framework 4 Client Profile (KB2468871)
    Update for Microsoft .NET Framework 4 Client Profile (KB2533523)
    Update for Windows Internet Explorer 8 (KB2447568)
    Update for Windows Internet Explorer 8 (KB976662)
    Update for Windows Internet Explorer 8 (KB980182)
    Update for Windows Internet Explorer 8 (KB980302)
    Update for Windows XP (KB2141007)
    Update for Windows XP (KB2345886)
    Update for Windows XP (KB2467659)
    Update for Windows XP (KB2492386)
    Update for Windows XP (KB2541763)
    Update for Windows XP (KB2607712)
    Update for Windows XP (KB2616676)
    Update for Windows XP (KB2641690)
    Update for Windows XP (KB951978)
    Update for Windows XP (KB955759)
    Update for Windows XP (KB967715)
    Update for Windows XP (KB968389)
    Update for Windows XP (KB971029)
    Update for Windows XP (KB971737)
    Update for Windows XP (KB973687)
    Update for Windows XP (KB973815)
    Update for Windows XP (KB980182)
    VIA Audio Driver Setup Program
    VIA Rhine-Family Fast-Ethernet Adapter
    WebFldrs XP
    WhoCrashed 3.03
    Windows Backup Utility
    Windows Genuine Advantage Validation Tool (KB892130)
    Windows Management Framework Core
    Windows Media Format 11 runtime
    Windows XP Service Pack 3
    WinUHA 2.0 RC1 (2005.02.27)
    WinX Free DVD To PSP Ripper 3.0
    ==== Event Viewer Messages From Past Week ========
    1/12/2012 8:14:29 PM, error: Service Control Manager [7026] - The following boot-start or system-start driver(s) failed to load: AFD AmdK7 Fips IPSec MpFilter MRxSmb NetBIOS NetBT RasAcd Rdbss Tcpip
    1/12/2012 8:14:29 PM, error: Service Control Manager [7001] - The TCP/IP NetBIOS Helper service depends on the AFD service which failed to start because of the following error: A device attached to the system is not functioning.
    1/12/2012 8:14:29 PM, error: Service Control Manager [7001] - The IPSEC Services service depends on the IPSEC driver service which failed to start because of the following error: A device attached to the system is not functioning.
    1/12/2012 8:14:29 PM, error: Service Control Manager [7001] - The DNS Client service depends on the TCP/IP Protocol Driver service which failed to start because of the following error: A device attached to the system is not functioning.
    1/12/2012 8:14:29 PM, error: Service Control Manager [7001] - The DHCP Client service depends on the NetBios over Tcpip service which failed to start because of the following error: A device attached to the system is not functioning.
    1/12/2012 8:14:13 PM, error: DCOM [10005] - DCOM got error "%1084" attempting to start the service netman with arguments " " in order to run the server: {BA126AE5-2166-11D1-B1D0-00805FC1270E}
    1/12/2012 8:13:48 PM, error: DCOM [10005] - DCOM got error "%1084" attempting to start the service EventSystem with arguments " " in order to run the server: {1BE1F766-5536-11D1-B726-00C04FB926AF}
    1/12/2012 8:08:51 PM, error: atapi [9] - The device, \Device\Ide\IdePort0, did not respond within the timeout period.
    1/12/2012 7:57:23 PM, error: Service Control Manager [7031] - The Microsoft Antimalware Service service terminated unexpectedly. It has done this 1 time(s). The following corrective action will be taken in 15000 milliseconds: Restart the service.
    1/12/2012 7:56:57 PM, error: Microsoft Antimalware [5008] - Microsoft Antimalware engine has been terminated due to an unexpected error. Failure Type: Crash Exception code: 0xc0000005 Resource: file:C:\WINDOWS\system32\winmm.dll
    1/12/2012 7:56:57 PM, error: Microsoft Antimalware [5008] - Microsoft Antimalware engine has been terminated due to an unexpected error. Failure Type: Crash Exception code: 0xc0000005 Resource: file:C:\WINDOWS\system32\WINMM.dll
    1/12/2012 6:43:20 PM, error: WMPNetworkSvc [14344] - A new media server was not initialized because WMCreateDeviceRegistration() encountered error '0xc00d2711'. The Windows Media DRM components on your computer might be corrupted. Verify that protected files play correctly in Windows Media Player, and then restart the WMPNetworkSvc service.
    1/12/2012 6:43:11 PM, error: Service Control Manager [7009] - Timeout (30000 milliseconds) waiting for the Freemake Improver service to connect.
    1/12/2012 6:43:11 PM, error: Service Control Manager [7000] - The Freemake Improver service failed to start due to the following error: The service did not respond to the start or control request in a timely fashion.
    1/12/2012 6:41:56 PM, error: sr [1] - The System Restore filter encountered the unexpected error '0xC0000001' while processing the file '' on the volume 'HarddiskVolume1'. It has stopped monitoring the volume.
    1/11/2012 8:44:46 PM, error: scsiscan [15] -
    ==== End Of File ===========================
    SVEN,
    Please, observe following rules:
    • Read all of my instructions very carefully. Your mistakes during cleaning process may have very serious consequences, like unbootable computer.
    • If you're stuck, or you're not sure about certain step, always ask before doing anything else.
    • Please refrain from running tools or applying updates other than those I suggest.
    • Never run more than one scan at a time.
    • Keep updating me regarding your computer behavior, good, or bad.
    • The cleaning process, once started, has to be completed. Even if your computer appears to act better, it may still be infected. Once the computer is totally clean, I'll certainly let you know.
    • If you leave the topic without explanation in the middle of a cleaning process, you may not be eligible to receive any more help in malware removal forum.
    • I close my topics if you have not replied in 5 days. If you need more time, simply let me know. If I closed your topic and you need it to be reopened, simply PM me.
    Your MBAM version is bit outdated.
    Update it and re-run.
    I still need aswMBR log.
  7. 2012/01/14
    SVEN
    SVEN Well-Known Member Thread Starter
    aswMBR version 0.9.9.1297 Copyright(c) 2011 AVAST Software
    Run date: 2012-01-14 09:48:40
    09:48:40.046 OS Version: Windows 5.1.2600 Service Pack 3
    09:48:40.046 Number of processors: 1 586 0x801
    09:48:40.046 ComputerName: SVEN-ALBRECHT UserName: Sven Albrecht
    09:48:40.484 Initialize success
    09:49:00.609 Disk 0 (boot) \Device\Harddisk0\DR0 -> \Device\Ide\IdeDeviceP0T0L0-4
    09:49:00.625 Disk 0 Vendor: WDC_WD400BB-00GFA0 09.01B09 Size: 38166MB BusType: 3
    09:49:00.625 Disk 1 \Device\Harddisk1\DR1 -> \Device\Ide\IdeDeviceP0T1L0-c
    09:49:00.625 Disk 1 Vendor: ST380020A 3.39 Size: 76319MB BusType: 3
    09:49:00.640 Disk 0 MBR read successfully
    09:49:00.656 Disk 0 MBR scan
    09:49:00.656 Disk 0 Windows XP default MBR code
    09:49:00.656 Disk 0 Partition 1 80 (A) 07 HPFS/NTFS NTFS 35997 MB offset 63
    09:49:00.656 Disk 0 Partition - 00 0F Extended LBA 2165 MB offset 73722285
    09:49:00.687 Disk 0 Partition 2 00 07 HPFS/NTFS NTFS 2164 MB offset 73722348
    09:49:00.687 Disk 0 scanning sectors +78156225
    09:49:00.750 Disk 0 scanning C:\WINDOWS\system32\drivers
    09:49:09.609 Service scanning
    09:49:10.312 Service MpKsl66a5b29c C:\Documents and Settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{D10862DB-164B-4EBE-B29A-E9BAF01F0AD7}\MpKsl66a5b29c.sys **LOCKED** 32
    09:49:11.531 Modules scanning
    09:49:14.859 Module: C:\WINDOWS\System32\drivers\dxgthk.sys **SUSPICIOUS**
    09:49:15.781 Module: C:\WINDOWS\System32\DRIVERS\nxsIO32.sys **SUSPICIOUS**
    09:49:16.671 Module: C:\WINDOWS\system32\ntdll.dll **SUSPICIOUS**
    09:49:16.671 Disk 0 trace - called modules:
    09:49:16.687 ntoskrnl.exe CLASSPNP.SYS disk.sys ACPI.sys hal.dll atapi.sys viaide.sys PCIIDEX.SYS
    09:49:16.703 1 nt!IofCallDriver -> \Device\Harddisk0\DR0[0x867ccab8]
    09:49:16.703 3 CLASSPNP.SYS[f787ffd7] -> nt!IofCallDriver -> \Device\00000067[0x867db3b8]
    09:49:16.703 5 ACPI.sys[f77e6620] -> nt!IofCallDriver -> \Device\Ide\IdeDeviceP0T0L0-4[0x86781d98]
    09:49:16.718 Scan finished successfully
    09:49:41.312 Disk 0 MBR has been saved successfully to "C:\Documents and Settings\Sven Albrecht\Desktop\MBR.dat "
    09:49:41.328 The log file has been saved successfully to "C:\Documents and Settings\Sven Albrecht\Desktop\aswMBR.txt "
    SVEN,
    #6
  8. 2012/01/14
    SVEN
    Hi Broni
    Looking at the above post of the Mbam log, the version is Database version: v2012.01.12.
    That is when I did the checkup. There is a .05 after the date, that can confuse you.
    Regardless, I will post a new log, but it most likely will be clear since it fixed all of the items in that log.
    Sven
    SVEN,
    #7
  9. 2012/01/14
    SVEN
    As I predicted, all clear:
    Malwarebytes Anti-Malware 1.60.0.1800
    www.malwarebytes.org
    Database version: v2012.01.14.04
    Windows XP Service Pack 3 x86 NTFS
    Internet Explorer 8.0.6001.18702
    Sven Albrecht :: SVEN-ALBRECHT [administrator]
    1/14/2012 2:06:42 PM
    mbam-log-2012-01-14 (14-06-42).txt
    Scan type: Quick scan
    Scan options enabled: Memory | Startup | Registry | File System | Heuristics/Extra | Heuristics/Shuriken | PUP | PUM
    Scan options disabled: P2P
    Objects scanned: 179452
    Time elapsed: 7 minute(s), 8 second(s)
    Memory Processes Detected: 0
    (No malicious items detected)
    Memory Modules Detected: 0
    Registry Keys Detected: 0
    Registry Values Detected: 0
    Registry Data Items Detected: 0
    Folders Detected: 0
    Files Detected: 0
    (end)
    SVEN,
    #8
  10. 2012/01/14
    SVEN
    My system has been up and running foraprox. 5 hours without any problems.
    I think it was the heat, or better no cooling possible because of dust bunnies.
    Sven
    SVEN,
    #9
  11. 2012/01/14
    I still can see some possible infection.
    [color= "Blue"]**Note: In the event you already have Combofix, this is a new version that I need you to download. It is important that it is saved directly to your desktop**[/color]
    2. Close any open browsers.
      • Click on [color= "Red"]this link[/color] to see a list of programs that should be disabled. The list is not all inclusive. If yours is not listed and you don't know how to disable it, please ask.
      NOTE1. If Combofix asks you to install Recovery Console, please allow it.
      • Close any open browsers.
      • [color= "Red"]WARNING:[/color] Combofix will disconnect your machine from the Internet as soon as it starts
    6. Please post the "C:\ComboFix.txt"
    **Note 1: Do not mouseclick combofix's window while it's running. That may cause it to stall
    **Note 2 for AVG and CA Internet Security users: ComboFix will not run until AVG/CA Internet Security is uninstalled as a protective measure against the anti-virus. This is because AVG/CA Internet Security "falsely" detects ComboFix (or its embedded files) as a threat and may remove them resulting in the tool not working correctly which in turn can cause "unpredictable results ". Since AVG/CA Internet Security cannot be effectively disabled before running ComboFix, the author recommends you to uninstall AVG/CA Internet Security first.
    Use AppRemover to uninstall it: http://www.appremover.com/
    We can reinstall it when we're done with CF.
    **Note 3: If you receive an error "Illegal operation attempted on a registery key that has been marked for deletion ", restart computer to fix the issue.
    **Note 4: Some infections may take some significant time to be cured. As long as your computer clock is running Combofix is still working. Be patient.
    NOTE.
    If, for some reason, Combofix refuses to run, try one of the following:
    1. Run Combofix from Safe Mode (How to...)
    2. Delete Combofix file, download fresh one, but rename combofix.exe to yourname.exe BEFORE saving it to your desktop.
    Do NOT run it yet.
    Please download and run the below tool named Rkill (courtesy of BleepingComputer.com) which may help allow other programs to run.
    There are 4 different versions. If one of them won't run then download and try to run the other one.
    Vista and Win7 users need to right click Rkill and choose Run as Administrator
    You only need to get one of these to run, not all of them. You may get warnings from your antivirus about this tool, ignore them or shutdown your antivirus.
    Rkill.com
    Rkill.scr
    Rkill.exe
    • Double-click on the Rkill desktop icon to run the tool.
    • If using Vista or Windows 7 right-click on it and choose Run As Administrator.
    • A black DOS box will briefly flash and then disappear. This is normal and indicates the tool ran successfully.
    • If not, delete the file, then download and use the one provided in Link 2.
    • If it does not work, repeat the process and attempt to use one of the remaining links until the tool runs.
    • Do not reboot until instructed.
    • If the tool does not run from any of the links provided, please let me know.
    Once you've gotten one of them to run, immediately run your_name.exe by double clicking on it.
    If normal mode still doesn't work, run BOTH tools from safe mode.
    In case #2, please post BOTH logs, rKill and Combofix.
  12. 2012/01/14
    SVEN
    Hi Broni
    here are the 2 logs:
    ComboFix 12-01-13.05 - Sven Albrecht 01/14/2012 18:57:08.2.1 - x86
    Microsoft Windows XP Home Edition 5.1.2600.3.1252.1.1033.18.1023.623 [GMT -8:00]
    Running from: c:\documents and settings\Sven Albrecht\Desktop\ComboFix.exe
    AV: Microsoft Security Essentials *Disabled/Updated* {EDB4FA23-53B8-4AFA-8C5D-99752CCA7095}
    c:\documents and settings\Sven Albrecht\Application Data\inst.exe
    c:\documents and settings\Sven Albrecht\WINDOWS
    c:\program files\sss
    c:\program files\sss\licence.txt
    c:\program files\sss\ReadMe.txt
    c:\program files\sss\SimpleScreenshot.exe
    c:\windows\TEMP\logishrd\LVPrcInj01.dll
    ((((((((((((((((((((((((((((((((((((((( Drivers/Services )))))))))))))))))))))))))))))))))))))))))))))))))
    -------\Legacy_MYWEBSEARCHSERVICE
    -------\Legacy_NPF
    ((((((((((((((((((((((((( Files Created from 2011-12-15 to 2012-01-15 )))))))))))))))))))))))))))))))
    2012-01-15 03:14 . 2012-01-15 03:14 56200 ----a-w- c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{406E2DF1-180F-4B67-B84C-E567B4C31E53}\offreg.dll
    2012-01-14 17:57 . 2011-11-21 10:47 6823496 ----a-w- c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{406E2DF1-180F-4B67-B84C-E567B4C31E53}\mpengine.dll
    2012-01-13 04:13 . 2012-01-13 04:14 -------- d-----w- c:\documents and settings\Administrator
    2012-01-12 04:13 . 2012-01-12 04:18 -------- d-----w- C:\symbols
    2012-01-11 04:30 . 2012-01-12 04:57 -------- d-----w- c:\program files\WhoCrashed
    2012-01-08 05:32 . 2012-01-08 05:32 46592 ----a-w- c:\windows\system32\drivers\KSafeDISK.sys
    2012-01-08 05:32 . 2012-01-08 05:32 24832 ----a-w- c:\windows\system32\drivers\BTOWSFF.sys
    2012-01-08 05:32 . 2012-01-08 05:32 -------- d-----w- C:\Toolwiz
    2012-01-08 05:32 . 2012-01-08 05:32 41856 ----a-w- c:\windows\system32\drivers\BTOWSVF.sys
    2012-01-08 05:32 . 2012-01-08 06:41 -------- d-----w- c:\documents and settings\Sven Albrecht\Local Settings\Application Data\ToolwizCareFree
    2012-01-01 22:28 . 2011-11-21 10:47 6823496 ----a-w- c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\Backup\mpengine.dll
    2011-12-18 18:01 . 2012-01-08 05:32 -------- d-----w- c:\program files\ToolwizCareFree
    2011-12-10 23:24 . 2010-12-26 00:11 20464 ----a-w- c:\windows\system32\drivers\mbam.sys
    2011-11-25 21:57 . 2004-08-04 07:56 293376 ----a-w- c:\windows\system32\winsrv.dll
    2011-11-23 13:25 . 2004-08-04 06:17 1859584 ----a-w- c:\windows\system32\win32k.sys
    2011-11-18 12:35 . 2004-08-04 07:56 60416 ----a-w- c:\windows\system32\packager.exe
    2011-11-16 01:38 . 2011-05-14 15:43 414368 ----a-w- c:\windows\system32\FlashPlayerCPLApp.cpl
    2011-11-04 19:20 . 2004-08-04 07:56 1469440 ------w- c:\windows\system32\inetcpl.cpl
    2011-11-04 19:20 . 2004-08-04 07:56 916992 ----a-w- c:\windows\system32\wininet.dll
    2011-11-04 19:20 . 2004-08-04 07:56 43520 ----a-w- c:\windows\system32\licmgr10.dll
    2011-11-04 11:23 . 2004-08-04 05:59 385024 ------w- c:\windows\system32\html.iec
    2011-11-03 15:28 . 2004-08-04 07:56 386048 ----a-w- c:\windows\system32\qdvd.dll
    2011-11-03 15:28 . 2004-08-04 07:56 1292288 ----a-w- c:\windows\system32\quartz.dll
    2011-11-01 16:07 . 2004-08-04 07:56 1288704 ----a-w- c:\windows\system32\ole32.dll
    2011-10-28 05:31 . 2004-08-04 07:56 33280 ----a-w- c:\windows\system32\csrsrv.dll
    2011-10-25 13:33 . 2004-08-04 06:20 2192768 ----a-w- c:\windows\system32\ntoskrnl.exe
    2011-10-25 12:52 . 2004-08-03 22:59 2069376 ----a-w- c:\windows\system32\ntkrnlpa.exe
    2011-10-18 11:13 . 2004-08-04 07:56 186880 ----a-w- c:\windows\system32\encdec.dll
    ------- Sigcheck -------
    Note: Unsigned files aren't necessarily malware.
    [-] 2008-04-13 . 9F3A2F5AA6875C72BF062C712CFA2674 . 96512 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\atapi.sys
    [-] 2008-04-13 . 9F3A2F5AA6875C72BF062C712CFA2674 . 96512 . . [5.1.2600.5512] . . c:\windows\system32\drivers\atapi.sys
    [-] 2008-04-13 . B153AFFAC761E7F5FCFA822B9C4E97BC . 14336 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\asyncmac.sys
    [-] 2008-04-13 . B153AFFAC761E7F5FCFA822B9C4E97BC . 14336 . . [5.1.2600.5512] . . c:\windows\system32\drivers\asyncmac.sys
    [-] 2003-03-31 . DA1F27D85E0D1525F6621372E7B685E9 . 4224 . . [5.1.2600.0] . . c:\windows\system32\dllcache\beep.sys
    [-] 2003-03-31 . DA1F27D85E0D1525F6621372E7B685E9 . 4224 . . [5.1.2600.0] . . c:\windows\system32\drivers\beep.sys
    [-] 2008-04-13 . 463C1EC80CD17420A542B7F36A36F128 . 24576 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\kbdclass.sys
    [-] 2008-04-13 . 463C1EC80CD17420A542B7F36A36F128 . 24576 . . [5.1.2600.5512] . . c:\windows\system32\drivers\kbdclass.sys
    [-] 2008-04-13 . 1DF7F42665C94B825322FAE71721130D . 182656 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\ndis.sys
    [-] 2008-04-13 . 1DF7F42665C94B825322FAE71721130D . 182656 . . [5.1.2600.5512] . . c:\windows\system32\drivers\ndis.sys
    [-] 2008-04-13 . 78A08DD6A8D65E697C18E1DB01C5CDCA . 574976 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\ntfs.sys
    [-] 2008-04-13 . 78A08DD6A8D65E697C18E1DB01C5CDCA . 574976 . . [5.1.2600.5512] . . c:\windows\system32\drivers\ntfs.sys
    [-] 2003-03-31 . 73C1E1F395918BC2C6DD67AF7591A3AD . 2944 . . [5.1.2600.0] . . c:\windows\system32\dllcache\null.sys
    [-] 2003-03-31 . 73C1E1F395918BC2C6DD67AF7591A3AD . 2944 . . [5.1.2600.0] . . c:\windows\system32\drivers\null.sys
    [-] 2008-06-20 . 9AEFA14BD6B182D61E3119FA5F436D3D . 361600 . . [5.1.2600.5625] . . c:\windows\system32\dllcache\tcpip.sys
    [-] 2008-06-20 . 9AEFA14BD6B182D61E3119FA5F436D3D . 361600 . . [5.1.2600.5625] . . c:\windows\system32\drivers\tcpip.sys
    [-] 2008-04-13 . 93EA8D04EC73A85DB02EB8805988F733 . 361344 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\tcpip.sys
    [-] 2008-04-14 . A06CE3399D16DB864F55FAEB1F1927A9 . 77824 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\browser.dll
    [-] 2008-04-14 . A06CE3399D16DB864F55FAEB1F1927A9 . 77824 . . [5.1.2600.5512] . . c:\windows\system32\browser.dll
    [-] 2008-04-14 . BF2466B3E18E970D8A976FB95FC1CA85 . 13312 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\lsass.exe
    [-] 2008-04-14 . BF2466B3E18E970D8A976FB95FC1CA85 . 13312 . . [5.1.2600.5512] . . c:\windows\system32\lsass.exe
    [-] 2008-04-14 . 13E67B55B3ABD7BF3FE7AAE5A0F9A9DE . 198144 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\netman.dll
    [-] 2008-04-14 . 13E67B55B3ABD7BF3FE7AAE5A0F9A9DE . 198144 . . [5.1.2600.5512] . . c:\windows\system32\netman.dll
    [-] 2008-04-14 00:11 . 1280A158C722FA95A80FB7AEBE78FA7D . 792064 . . [2001.12.4414.700] . . c:\windows\ServicePackFiles\i386\comres.dll
    [-] 2008-04-14 00:11 . 1280A158C722FA95A80FB7AEBE78FA7D . 792064 . . [2001.12.4414.700] . . c:\windows\system32\comres.dll
    [-] 2008-04-14 . 574738F61FCA2935F5265DC4E5691314 . 409088 . . [6.7.2600.5512] . . c:\windows\ServicePackFiles\i386\qmgr.dll
    [-] 2008-04-14 . 574738F61FCA2935F5265DC4E5691314 . 409088 . . [6.7.2600.5512] . . c:\windows\system32\qmgr.dll
    [-] 2008-04-14 . 574738F61FCA2935F5265DC4E5691314 . 409088 . . [6.7.2600.5512] . . c:\windows\system32\bits\qmgr.dll
    [-] 2009-02-09 . 6B27A5C03DFB94B4245739065431322C . 401408 . . [5.1.2600.5755] . . c:\windows\system32\rpcss.dll
    [-] 2009-02-09 . 6B27A5C03DFB94B4245739065431322C . 401408 . . [5.1.2600.5755] . . c:\windows\system32\dllcache\rpcss.dll
    [-] 2008-04-14 . 2589FE6015A316C0F5D5112B4DA7B509 . 399360 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\rpcss.dll
    [-] 2009-02-06 . 65DF52F5B8B6E9BBD183505225C37315 . 110592 . . [5.1.2600.5755] . . c:\windows\system32\services.exe
    [-] 2009-02-06 . 65DF52F5B8B6E9BBD183505225C37315 . 110592 . . [5.1.2600.5755] . . c:\windows\system32\dllcache\services.exe
    [-] 2008-04-14 . 0E776ED5F7CC9F94299E70461B7B8185 . 108544 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\services.exe
    [-] 2010-08-17 . 60784F891563FB1B767F70117FC2428F . 58880 . . [5.1.2600.6024] . . c:\windows\system32\spoolsv.exe
    [-] 2010-08-17 . 60784F891563FB1B767F70117FC2428F . 58880 . . [5.1.2600.6024] . . c:\windows\system32\dllcache\spoolsv.exe
    [-] 2008-04-14 . D8E14A61ACC1D4A6CD0D38AEBAC7FA3B . 57856 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\spoolsv.exe
    [-] 2008-04-14 . ED0EF0A136DEC83DF69F04118870003E . 507904 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\winlogon.exe
    [-] 2008-04-14 . ED0EF0A136DEC83DF69F04118870003E . 507904 . . [5.1.2600.5512] . . c:\windows\system32\winlogon.exe
    [-] 2008-04-13 . 23C74D75E36E7158768DD63D92789A91 . 75264 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\ipsec.sys
    [-] 2008-04-13 . 23C74D75E36E7158768DD63D92789A91 . 75264 . . [5.1.2600.5512] . . c:\windows\system32\drivers\ipsec.sys
    [-] 2010-08-23 . 93AFB83FBC1F9443CAC722FCA63D73BF . 617472 . . [5.82] . . c:\windows\system32\comctl32.dll
    [-] 2010-08-23 . 93AFB83FBC1F9443CAC722FCA63D73BF . 617472 . . [5.82] . . c:\windows\system32\dllcache\comctl32.dll
    [-] 2010-08-23 . 736B12B725AEB2B07F0241A9F680CB10 . 1054208 . . [6.0] . . c:\windows\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.6028_x-ww_61e65202\comctl32.dll
    [-] 2008-04-14 . BD38D1EBE24A46BD3EDA059560AFBA12 . 1054208 . . [6.0] . . c:\windows\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.5512_x-ww_35d4ce83\comctl32.dll
    [-] 2008-04-14 . 06F247492BC786CE5C24A23E178C711A . 617472 . . [5.82] . . c:\windows\ServicePackFiles\i386\comctl32.dll
    [-] 2004-08-04 . 5AF68A5E44734A082442668E9C787743 . 1050624 . . [6.0] . . c:\windows\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.2180_x-ww_a84f1ff9\comctl32.dll
    [-] 2003-03-31 . AEF3D788DBF40C7C4D204EA45EB0C505 . 921088 . . [6.0] . . c:\windows\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.0.0_x-ww_1382d70a\comctl32.dll
    [-] 2008-04-14 . 3D4E199942E29207970E04315D02AD3B . 62464 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\cryptsvc.dll
    [-] 2008-04-14 . 3D4E199942E29207970E04315D02AD3B . 62464 . . [5.1.2600.5512] . . c:\windows\system32\cryptsvc.dll
    [-] 2008-07-07 20:26 . D4991D98F2DB73C60D042F1AEF79EFAE . 253952 . . [2001.12.4414.706] . . c:\windows\system32\es.dll
    [-] 2008-07-07 20:26 . D4991D98F2DB73C60D042F1AEF79EFAE . 253952 . . [2001.12.4414.706] . . c:\windows\system32\dllcache\es.dll
    [-] 2008-04-14 00:11 . 19A799805B24990867B00C120D300C3A . 246272 . . [2001.12.4414.701] . . c:\windows\ServicePackFiles\i386\es.dll
    [-] 2008-04-14 . 0DA85218E92526972A821587E6A8BF8F . 110080 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\imm32.dll
    [-] 2008-04-14 . 0DA85218E92526972A821587E6A8BF8F . 110080 . . [5.1.2600.5512] . . c:\windows\system32\imm32.dll
    [-] 2009-03-21 . B921FB870C9AC0D509B2CCABBBBE95F3 . 989696 . . [5.1.2600.5781] . . c:\windows\system32\kernel32.dll
    [-] 2009-03-21 . B921FB870C9AC0D509B2CCABBBBE95F3 . 989696 . . [5.1.2600.5781] . . c:\windows\system32\dllcache\kernel32.dll
    [-] 2008-04-14 . C24B983D211C34DA8FCC1AC38477971D . 989696 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\kernel32.dll
    [-] 2008-04-14 . 2DC5A8019E2387987905F77C664E4BE2 . 19968 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\linkinfo.dll
    [-] 2008-04-14 . 2DC5A8019E2387987905F77C664E4BE2 . 19968 . . [5.1.2600.5512] . . c:\windows\system32\linkinfo.dll
    [-] 2008-04-14 . 012DF358CEBAA23ACB26D82077820817 . 22016 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\lpk.dll
    [-] 2008-04-14 . 012DF358CEBAA23ACB26D82077820817 . 22016 . . [5.1.2600.5512] . . c:\windows\system32\lpk.dll
    [-] 2011-11-04 . DD8D655E1881B70A5259A23A6018A6C2 . 5978112 . . [8.00.6001.19170] . . c:\windows\system32\mshtml.dll
    [-] 2011-11-04 . DD8D655E1881B70A5259A23A6018A6C2 . 5978112 . . [8.00.6001.19170] . . c:\windows\system32\dllcache\mshtml.dll
    [-] 2011-11-04 . 699421E2E1313C18671A703953CAE14B . 5978624 . . [8.00.6001.23266] . . c:\windows\$hf_mig$\KB2618444-IE8\SP3QFE\mshtml.dll
    [-] 2011-10-03 . 4963CB503600FC3BCBDBFBA51FBA1FAC . 5971456 . . [8.00.6001.19154] . . c:\windows\ie8updates\KB2618444-IE8\mshtml.dll
    [-] 2011-10-03 . 1240A6B7B470BED0AA6C9FEC7AB0EA26 . 5972992 . . [8.00.6001.23250] . . c:\windows\$hf_mig$\KB2586448-IE8\SP3QFE\mshtml.dll
    [-] 2011-07-25 . 23B3C8E9F3F280180573569253CE98AB . 5969920 . . [8.00.6001.19120] . . c:\windows\ie8updates\KB2586448-IE8\mshtml.dll
    [-] 2011-05-30 . 22BA5235EA846EDA87F68A1DCC2BFCF9 . 5964800 . . [8.00.6001.19088] . . c:\windows\ie8updates\KB2559049-IE8\mshtml.dll
    [-] 2011-02-22 . C2EF2335F1B6C2BE20A67D9098F6C9A1 . 5962240 . . [8.00.6001.19046] . . c:\windows\ie8updates\KB2530548-IE8\mshtml.dll
    [-] 2010-12-20 . 1EDCEC5D649DBAC37ED9FFB5A14CEB0C . 5961216 . . [8.00.6001.19019] . . c:\windows\ie8updates\KB2497640-IE8\mshtml.dll
    [-] 2010-11-06 . D7CCA87057901C87ED8CC40DDCC7FA1B . 5959168 . . [8.00.6001.18999] . . c:\windows\ie8updates\KB2482017-IE8\mshtml.dll
    [-] 2010-09-10 . DE41132DA8E5A3CD57201C6F2175EC05 . 5957120 . . [8.00.6001.18975] . . c:\windows\ie8updates\KB2416400-IE8\mshtml.dll
    [-] 2010-06-24 . 4D7EF94795384CD2BBAAB078B7929FEA . 5951488 . . [8.00.6001.18939] . . c:\windows\ie8updates\KB2360131-IE8\mshtml.dll
    [-] 2010-05-06 . C7B7A88CC7D7ABA5C395145BF92F46F7 . 5950976 . . [8.00.6001.18928] . . c:\windows\ie8updates\KB2183461-IE8\mshtml.dll
    [-] 2010-02-25 . 7054F6ADC9B670887659F1561603B0D0 . 5944832 . . [8.00.6001.18904] . . c:\windows\ie8updates\KB982381-IE8\mshtml.dll
    [-] 2010-02-25 . 7054F6ADC9B670887659F1561603B0D0 . 5944832 . . [8.00.6001.18904] . . c:\windows\SoftwareDistribution\Download\bf853aeb396b834ced5a417bda2c636f\SP3GDR\mshtml.dll
    [-] 2010-02-25 . 974772C74DA7C7A8E7C813A9908A845F . 5946880 . . [8.00.6001.22995] . . c:\windows\SoftwareDistribution\Download\bf853aeb396b834ced5a417bda2c636f\SP3QFE\mshtml.dll
    [-] 2009-03-08 . D469A0EBA2EF5C6BEE8065B7E3196E5E . 5937152 . . [8.00.6001.18702] . . c:\windows\ie8updates\KB980182-IE8\mshtml.dll
    [-] 2008-04-14 . A706E122B398FE1AB85CB9B75D044223 . 3066880 . . [6.00.2900.5512] . . c:\windows\ServicePackFiles\i386\mshtml.dll
    [-] 2004-08-04 . 376E0843B2356CA91CEC8D9837A56FF7 . 3003392 . . [6.00.2900.2180] . . c:\windows\ie8\mshtml.dll
    [-] 2008-04-14 . D7075E95AA599EE77B7A89D39296BD3D . 343040 . . [7.0.2600.5512] . . c:\windows\WinSxS\x86_Microsoft.Windows.CPlusPlusRuntime_6595b64144ccf1df_7.0.2600.5512_x-ww_3fd60d63\msvcrt.dll
    [-] 2008-04-14 . 355EDBB4D412B01F1740C17E3F50FA00 . 343040 . . [7.0.2600.5512] . . c:\windows\ServicePackFiles\i386\msvcrt.dll
    [-] 2008-04-14 . 355EDBB4D412B01F1740C17E3F50FA00 . 343040 . . [7.0.2600.5512] . . c:\windows\system32\msvcrt.dll
    [-] 2004-08-04 . 98EC447E00229AFD88D5161A25D065DA . 343040 . . [7.0.2600.2180] . . c:\windows\WinSxS\x86_Microsoft.Windows.CPlusPlusRuntime_6595b64144ccf1df_7.0.2600.2180_x-ww_b2505ed9\msvcrt.dll
    [-] 2003-03-31 . 4200BE3808F6406DBE45A7B88DAE5035 . 322560 . . [7.0.2600.0] . . c:\windows\WinSxS\x86_Microsoft.Windows.CPlusPlusRuntime_6595b64144ccf1df_7.0.0.0_x-ww_2726e76a\msvcrt.dll
    [-] 2008-06-20 . 943337D786A56729263071623BBB9DE5 . 245248 . . [5.1.2600.5625] . . c:\windows\system32\mswsock.dll
    [-] 2008-06-20 . 943337D786A56729263071623BBB9DE5 . 245248 . . [5.1.2600.5625] . . c:\windows\system32\dllcache\mswsock.dll
    [-] 2008-04-14 . B4138E99236F0F57D4CF49BAE98A0746 . 245248 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\mswsock.dll
    [-] 2008-04-14 . 1B7F071C51B77C272875C3A23E1E4550 . 407040 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\netlogon.dll
    [-] 2008-04-14 . 1B7F071C51B77C272875C3A23E1E4550 . 407040 . . [5.1.2600.5512] . . c:\windows\system32\netlogon.dll
    [-] 2008-04-14 . 50A166237A0FA771261275A405646CC0 . 17408 . . [6.00.2900.5512] . . c:\windows\ServicePackFiles\i386\powrprof.dll
    [-] 2008-04-14 . 50A166237A0FA771261275A405646CC0 . 17408 . . [6.00.2900.5512] . . c:\windows\system32\powrprof.dll
    [-] 2008-04-14 . A86BB5E61BF3E39B62AB4C7E7085A084 . 181248 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\scecli.dll
    [-] 2008-04-14 . A86BB5E61BF3E39B62AB4C7E7085A084 . 181248 . . [5.1.2600.5512] . . c:\windows\system32\scecli.dll
    [-] 2008-04-14 . 96E1C926F22EE1BFBAE82901A35F6BF3 . 5120 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\sfc.dll
    [-] 2008-04-14 . 96E1C926F22EE1BFBAE82901A35F6BF3 . 5120 . . [5.1.2600.5512] . . c:\windows\system32\sfc.dll
    [-] 2008-04-14 . 27C6D03BCDB8CFEB96B716F3D8BE3E18 . 14336 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\svchost.exe
    [-] 2008-04-14 . 27C6D03BCDB8CFEB96B716F3D8BE3E18 . 14336 . . [5.1.2600.5512] . . c:\windows\system32\svchost.exe
    [-] 2008-04-14 . 3CB78C17BB664637787C9A1C98F79C38 . 249856 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\tapisrv.dll
    [-] 2008-04-14 . 3CB78C17BB664637787C9A1C98F79C38 . 249856 . . [5.1.2600.5512] . . c:\windows\system32\tapisrv.dll
    [-] 2008-04-14 . B26B135FF1B9F60C9388B4A7D16F600B . 578560 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\user32.dll
    [-] 2008-04-14 . B26B135FF1B9F60C9388B4A7D16F600B . 578560 . . [5.1.2600.5512] . . c:\windows\system32\user32.dll
    [-] 2008-04-14 . A93AEE1928A9D7CE3E16D24EC7380F89 . 26112 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\userinit.exe
    [-] 2008-04-14 . A93AEE1928A9D7CE3E16D24EC7380F89 . 26112 . . [5.1.2600.5512] . . c:\windows\system32\userinit.exe
    [-] 2011-11-04 . 552263502EA8C24D301A0C43FF90B3ED . 916992 . . [8.00.6001.19165] . . c:\windows\system32\wininet.dll
    [-] 2011-11-04 . 552263502EA8C24D301A0C43FF90B3ED . 916992 . . [8.00.6001.19165] . . c:\windows\system32\dllcache\wininet.dll
    [-] 2011-11-04 . 4E4716CAF514717814D07113AD0425B6 . 919552 . . [8.00.6001.23261] . . c:\windows\$hf_mig$\KB2618444-IE8\SP3QFE\wininet.dll
    [-] 2011-08-22 . 1A377838B4B468E37C3EEB5BAA24F925 . 916480 . . [8.00.6001.19131] . . c:\windows\ie8updates\KB2618444-IE8\wininet.dll
    [-] 2011-08-22 . 19630AEBBFAEB06984CAB91848270AAF . 919552 . . [8.00.6001.23227] . . c:\windows\$hf_mig$\KB2586448-IE8\SP3QFE\wininet.dll
    [-] 2011-06-23 . AF4EDDC6C0446FCE5681B5DED52B8F0E . 916480 . . [8.00.6001.19098] . . c:\windows\ie8updates\KB2586448-IE8\wininet.dll
    [-] 2011-04-25 . CC951C2212A200475A587A440E0AA804 . 916480 . . [8.00.6001.19072] . . c:\windows\ie8updates\KB2559049-IE8\wininet.dll
    [-] 2011-02-22 . F192D49EEFE297FA858B2C774BA2291D . 916480 . . [8.00.6001.19044] . . c:\windows\ie8updates\KB2530548-IE8\wininet.dll
    [-] 2010-12-20 . 88014D62B5E3CDB0AC67948D86C926C8 . 916480 . . [8.00.6001.19019] . . c:\windows\ie8updates\KB2497640-IE8\wininet.dll
    [-] 2010-11-06 . 306A2B05EA9846278113964DC6E2C940 . 916480 . . [8.00.6001.18992] . . c:\windows\ie8updates\KB2482017-IE8\wininet.dll
    [-] 2010-09-10 . 36FE8ABC59AAFBE20CBE54BC372F9429 . 916480 . . [8.00.6001.18968] . . c:\windows\ie8updates\KB2416400-IE8\wininet.dll
    [-] 2010-06-24 . D3DEB6B2B424AC93DE3801EAEB21A9A5 . 916480 . . [8.00.6001.18939] . . c:\windows\ie8updates\KB2360131-IE8\wininet.dll
    [-] 2010-05-06 . 2D9C7B010409372C34F725DA5CCED083 . 916480 . . [8.00.6001.18923] . . c:\windows\ie8updates\KB2183461-IE8\wininet.dll
    [-] 2010-02-25 . 7A42CFED96CDA7F2FB1A26D1F9F65775 . 916480 . . [8.00.6001.18904] . . c:\windows\ie8updates\KB982381-IE8\wininet.dll
    [-] 2010-02-25 . 7A42CFED96CDA7F2FB1A26D1F9F65775 . 916480 . . [8.00.6001.18904] . . c:\windows\SoftwareDistribution\Download\bf853aeb396b834ced5a417bda2c636f\SP3GDR\wininet.dll
    [-] 2010-02-25 . 4458D59F2B0369F4D3B137541D284041 . 919040 . . [8.00.6001.22995] . . c:\windows\SoftwareDistribution\Download\bf853aeb396b834ced5a417bda2c636f\SP3QFE\wininet.dll
    [-] 2009-03-08 . 6CE32F7778061CCC5814D5E0F282D369 . 914944 . . [8.00.6001.18702] . . c:\windows\ie8updates\KB980182-IE8\wininet.dll
    [-] 2008-04-14 . 7A4F775ABB2F1C97DEF3E73AFA2FAEDD . 666112 . . [6.00.2900.5512] . . c:\windows\ServicePackFiles\i386\wininet.dll
    [-] 2004-08-04 . C0823FC5469663BA63E7DB88F9919D70 . 656384 . . [6.00.2900.2180] . . c:\windows\ie8\wininet.dll
    [-] 2008-04-14 . 2CCC474EB85CEAA3E1FA1726580A3E5A . 82432 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\ws2_32.dll
    [-] 2008-04-14 . 2CCC474EB85CEAA3E1FA1726580A3E5A . 82432 . . [5.1.2600.5512] . . c:\windows\system32\ws2_32.dll
    [-] 2008-04-14 . 9789E95E1D88EEB4B922BF3EA7779C28 . 19968 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\ws2help.dll
    [-] 2008-04-14 . 9789E95E1D88EEB4B922BF3EA7779C28 . 19968 . . [5.1.2600.5512] . . c:\windows\system32\ws2help.dll
    [-] 2008-04-14 . 12896823FB95BFB3DC9B46BCAEDC9923 . 1033728 . . [6.00.2900.5512] . . c:\windows\explorer.exe
    [-] 2008-04-14 . 12896823FB95BFB3DC9B46BCAEDC9923 . 1033728 . . [6.00.2900.5512] . . c:\windows\ServicePackFiles\i386\explorer.exe
    [-] 2008-04-14 . 058710B720282CA82B909912D3EF28DB . 146432 . . [5.1.2600.5512] . . c:\windows\regedit.exe
    [-] 2008-04-14 . 058710B720282CA82B909912D3EF28DB . 146432 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\regedit.exe
    [-] 2011-11-01 . 6BAD1BED9872E62049E487FB91AE2F3A . 1288704 . . [5.1.2600.6168] . . c:\windows\system32\ole32.dll
    [-] 2011-11-01 . 6BAD1BED9872E62049E487FB91AE2F3A . 1288704 . . [5.1.2600.6168] . . c:\windows\system32\dllcache\ole32.dll
    [-] 2011-11-01 . 7D9DDE1AB4B00DDB173F5A16E9206517 . 1289216 . . [5.1.2600.6168] . . c:\windows\$hf_mig$\KB2624667\SP3QFE\ole32.dll
    [-] 2010-07-16 . 7A6A7900B5E322763430BA6FD9A31224 . 1288192 . . [5.1.2600.6010] . . c:\windows\$NtUninstallKB2624667$\ole32.dll
    [-] 2008-04-14 . ECCE74BC6168375016450A86A164D976 . 1287168 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\ole32.dll
    [-] 2010-04-16 . 9E03DC5AB51CFD0190541CE2038D819D . 406016 . . [1.0420.2600.5969] . . c:\windows\system32\usp10.dll
    [-] 2010-04-16 . 9E03DC5AB51CFD0190541CE2038D819D . 406016 . . [1.0420.2600.5969] . . c:\windows\system32\dllcache\usp10.dll
    [-] 2008-04-14 . 7D7D8501F3CB45D0408CDEFA08CDAEFF . 406016 . . [1.0420.2600.5512] . . c:\windows\ServicePackFiles\i386\usp10.dll
    [-] 2008-04-14 . 9B9F1C38D559047B8AC0DBA2D5FEBDE9 . 4096 . . [5.3.2600.5512] . . c:\windows\system32\ksuser.dll
    [-] 2008-04-14 . 9B9F1C38D559047B8AC0DBA2D5FEBDE9 . 4096 . . [5.3.2600.5512] . . c:\windows\system32\dllcache\ksuser.dll
    [-] 2008-04-14 . 9B9F1C38D559047B8AC0DBA2D5FEBDE9 . 4096 . . [5.3.2600.5512] . . c:\windows\system32\ReinstallBackups\0007\DriverFiles\i386\ksuser.dll
    [-] 2008-04-14 . 9B9F1C38D559047B8AC0DBA2D5FEBDE9 . 4096 . . [5.3.2600.5512] . . c:\windows\system32\ReinstallBackups\0008\DriverFiles\i386\ksuser.dll
    [-] 2008-04-14 . 9B9F1C38D559047B8AC0DBA2D5FEBDE9 . 4096 . . [5.3.2600.5512] . . c:\windows\ServicePackFiles\i386\ksuser.dll
    [-] 2008-04-14 . 5F1D5F88303D4A4DBC8E5F97BA967CC3 . 15360 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\ctfmon.exe
    [-] 2008-04-14 . 5F1D5F88303D4A4DBC8E5F97BA967CC3 . 15360 . . [5.1.2600.5512] . . c:\windows\system32\ctfmon.exe
    [-] 2009-07-27 . 99BC0B50F511924348BE19C7C7313BBF . 135168 . . [6.00.2900.5853] . . c:\windows\system32\shsvcs.dll
    [-] 2009-07-27 . 99BC0B50F511924348BE19C7C7313BBF . 135168 . . [6.00.2900.5853] . . c:\windows\system32\dllcache\shsvcs.dll
    [-] 2008-04-14 . 1926899BF9FFE2602B63074971700412 . 135168 . . [6.00.2900.5512] . . c:\windows\ServicePackFiles\i386\shsvcs.dll
    [-] 2008-04-14 . 3805DF0AC4296A34BA4BF93B346CC378 . 171008 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\srsvc.dll
    [-] 2008-04-14 . 3805DF0AC4296A34BA4BF93B346CC378 . 171008 . . [5.1.2600.5512] . . c:\windows\system32\srsvc.dll
    [-] 2008-04-14 . F92E1076C42FCD6DB3D72D8CFE9816D5 . 13824 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\wscntfy.exe
    [-] 2008-04-14 . F92E1076C42FCD6DB3D72D8CFE9816D5 . 13824 . . [5.1.2600.5512] . . c:\windows\system32\wscntfy.exe
    [-] 2008-04-14 . 295D21F14C335B53CB8154E5B1F892B9 . 129024 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\xmlprov.dll
    [-] 2008-04-14 . 295D21F14C335B53CB8154E5B1F892B9 . 129024 . . [5.1.2600.5512] . . c:\windows\system32\xmlprov.dll
    [-] 2008-04-14 . 6D4FEB43EE538FC5428CC7F0565AA656 . 56320 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\eventlog.dll
    [-] 2008-04-14 . 6D4FEB43EE538FC5428CC7F0565AA656 . 56320 . . [5.1.2600.5512] . . c:\windows\system32\eventlog.dll
    [-] 2008-04-14 . 9DD07AF82244867CA36681EA2D29CE79 . 1614848 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\sfcfiles.dll
    [-] 2008-04-14 . 9DD07AF82244867CA36681EA2D29CE79 . 1614848 . . [5.1.2600.5512] . . c:\windows\system32\sfcfiles.dll
    [-] 2008-04-14 . 5B19B557B0C188210A56A6B699D90B8F . 59904 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\regsvc.dll
    [-] 2008-04-14 . 5B19B557B0C188210A56A6B699D90B8F . 59904 . . [5.1.2600.5512] . . c:\windows\system32\regsvc.dll
    [-] 2008-04-14 . 0A9A7365A1CA4319AA7C1D6CD8E4EAFA . 192512 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\schedsvc.dll
    [-] 2008-04-14 . 0A9A7365A1CA4319AA7C1D6CD8E4EAFA . 192512 . . [5.1.2600.5512] . . c:\windows\system32\schedsvc.dll
    [-] 2008-04-14 . 0A5679B3714EDAB99E357057EE88FCA6 . 71680 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\ssdpsrv.dll
    [-] 2008-04-14 . 0A5679B3714EDAB99E357057EE88FCA6 . 71680 . . [5.1.2600.5512] . . c:\windows\system32\ssdpsrv.dll
    [-] 2008-04-14 . FF3477C03BE7201C294C35F684B3479F . 295424 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\termsrv.dll
    [-] 2008-04-14 . FF3477C03BE7201C294C35F684B3479F . 295424 . . [5.1.2600.5512] . . c:\windows\system32\termsrv.dll
    [-] 2008-04-14 . 3CB32D3B8CBE79899D63280BB7A83CD9 . 344064 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\hnetcfg.dll
    [-] 2008-04-14 . 3CB32D3B8CBE79899D63280BB7A83CD9 . 344064 . . [5.1.2600.5512] . . c:\windows\system32\hnetcfg.dll
    [-] 2003-03-31 . 9859C0F6936E723E4892D7141B1327D5 . 11648 . . [5.1.2600.0] . . c:\windows\system32\drivers\acpiec.sys
    [-] 2008-04-13 16:39 . 8BED39E3C35D6A489438B8141717A557 . 142592 . . [5.1.2601.3142] . . c:\windows\ServicePackFiles\i386\aec.sys
    [-] 2008-04-13 16:39 . 8BED39E3C35D6A489438B8141717A557 . 142592 . . [5.1.2601.3142] . . c:\windows\system32\drivers\aec.sys
    [-] 2008-04-13 . 08FD04AA961BDC77FB983F328334E3D7 . 42368 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\agp440.sys
    [-] 2008-04-13 . 08FD04AA961BDC77FB983F328334E3D7 . 42368 . . [5.1.2600.5512] . . c:\windows\system32\drivers\agp440.sys
    [-] 2008-04-13 . 3BB22519A194418D5FEC05D800A19AD0 . 36608 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\ip6fw.sys
    [-] 2008-04-13 . 3BB22519A194418D5FEC05D800A19AD0 . 36608 . . [5.1.2600.5512] . . c:\windows\system32\drivers\ip6fw.sys
    [-] 2010-09-18 06:53 . E76A5C202E68AF5A322D16B5A78F48B9 . 953856 . . [4.1.6151] . . c:\windows\system32\mfc40u.dll
    [-] 2010-09-18 06:53 . E76A5C202E68AF5A322D16B5A78F48B9 . 953856 . . [4.1.6151] . . c:\windows\system32\dllcache\mfc40u.dll
    [-] 2008-04-14 00:11 . CDDD4416B2B4C7295FE3FDB6DDE57E4E . 927504 . . [4.1.0.61] . . c:\windows\ServicePackFiles\i386\mfc40u.dll
    [-] 2008-04-14 . 986B1FF5814366D71E0AC5755C88F2D3 . 33792 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\msgsvc.dll
    [-] 2008-04-14 . 986B1FF5814366D71E0AC5755C88F2D3 . 33792 . . [5.1.2600.5512] . . c:\windows\system32\msgsvc.dll
    [-] 2006-10-19 04:47 . C51B4A5C05A5475708E3C81C7765B71D . 27136 . . [11.0.5721.5145] . . c:\windows\system32\mspmsnsv.dll
    [-] 2006-10-19 04:47 . C51B4A5C05A5475708E3C81C7765B71D . 27136 . . [11.0.5721.5145] . . c:\windows\system32\dllcache\mspmsnsv.dll
    [-] 2011-10-25 . DB19FFF0C805664CB95062C027B11FE9 . 2069376 . . [5.1.2600.6165] . . c:\windows\$hf_mig$\KB2633171\SP3QFE\ntkrnlpa.exe
    [-] 2011-10-25 . CE1A2FEDBD001ECDC5AD1975AFAD040A . 2069376 . . [5.1.2600.6165] . . c:\windows\Driver Cache\i386\ntkrnlpa.exe
    [-] 2011-10-25 . CE1A2FEDBD001ECDC5AD1975AFAD040A . 2069376 . . [5.1.2600.6165] . . c:\windows\system32\ntkrnlpa.exe
    [-] 2011-10-25 . CE1A2FEDBD001ECDC5AD1975AFAD040A . 2069376 . . [5.1.2600.6165] . . c:\windows\system32\dllcache\ntkrnlpa.exe
    [-] 2010-12-09 . 84FF488E249DBD2050EB39EA81C6F5C2 . 2069376 . . [5.1.2600.6055] . . c:\windows\$NtUninstallKB2633171$\ntkrnlpa.exe
    [-] 2008-04-13 . 109F8E3E3C82E337BB71B6BC9B895D61 . 2065792 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\ntkrnlpa.exe
    [-] 2008-04-14 00:12 . 156F64A3345BD23C600655FB4D10BC08 . 435200 . . [5.1.2400.5512] . . c:\windows\ServicePackFiles\i386\ntmssvc.dll
    [-] 2008-04-14 00:12 . 156F64A3345BD23C600655FB4D10BC08 . 435200 . . [5.1.2400.5512] . . c:\windows\system32\ntmssvc.dll
    [-] 2008-04-14 . 1EBAFEB9A3FBDC41B8D9C7F0F687AD91 . 185856 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\upnphost.dll
    [-] 2008-04-14 . 1EBAFEB9A3FBDC41B8D9C7F0F687AD91 . 185856 . . [5.1.2600.5512] . . c:\windows\system32\upnphost.dll
    [-] 2008-04-14 . 4D83ED8BDDEC431FC8AD907B47CFB6E3 . 367616 . . [5.3.2600.5512] . . c:\windows\ServicePackFiles\i386\dsound.dll
    [-] 2008-04-14 . 4D83ED8BDDEC431FC8AD907B47CFB6E3 . 367616 . . [5.3.2600.5512] . . c:\windows\system32\dsound.dll
    [-] 2008-04-14 . 0607CBC6FA20114CB491EFE4B2F9EFAD . 1689088 . . [5.03.2600.5512] . . c:\windows\ServicePackFiles\i386\d3d9.dll
    [-] 2008-04-14 . 0607CBC6FA20114CB491EFE4B2F9EFAD . 1689088 . . [5.03.2600.5512] . . c:\windows\system32\d3d9.dll
    [-] 2008-04-14 . A340CD71EB535A3DD751B5F28723E50C . 279552 . . [5.03.2600.5512] . . c:\windows\ServicePackFiles\i386\ddraw.dll
    [-] 2008-04-14 . A340CD71EB535A3DD751B5F28723E50C . 279552 . . [5.03.2600.5512] . . c:\windows\system32\ddraw.dll
    [-] 2008-04-14 00:12 . 5652F6CE1D9E9D8068B9D29BC21B5409 . 84992 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\olepro32.dll
    [-] 2008-04-14 00:12 . 5652F6CE1D9E9D8068B9D29BC21B5409 . 84992 . . [5.1.2600.5512] . . c:\windows\system32\olepro32.dll
    [-] 2008-04-14 . DBE2B62353660ECCA0D75EA307A717E9 . 39936 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\perfctrs.dll
    [-] 2008-04-14 . DBE2B62353660ECCA0D75EA307A717E9 . 39936 . . [5.1.2600.5512] . . c:\windows\system32\perfctrs.dll
    [-] 2008-04-14 . C7CE131408739B0B3A318BE2D0032719 . 18944 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\version.dll
    [-] 2008-04-14 . C7CE131408739B0B3A318BE2D0032719 . 18944 . . [5.1.2600.5512] . . c:\windows\system32\version.dll
    [-] 2011-10-25 . F512C662874D7545E5BD8005E6800A44 . 2192768 . . [5.1.2600.6165] . . c:\windows\$hf_mig$\KB2633171\SP3QFE\ntoskrnl.exe
    [-] 2011-10-25 . 892CDDFF7EF96951B9B0B50974070E47 . 2192768 . . [5.1.2600.6165] . . c:\windows\Driver Cache\i386\ntoskrnl.exe
    [-] 2011-10-25 . 892CDDFF7EF96951B9B0B50974070E47 . 2192768 . . [5.1.2600.6165] . . c:\windows\system32\ntoskrnl.exe
    [-] 2011-10-25 . 892CDDFF7EF96951B9B0B50974070E47 . 2192768 . . [5.1.2600.6165] . . c:\windows\system32\dllcache\ntoskrnl.exe
    [-] 2010-12-09 . 64C1ADF6DF629F340C5A439FE0EF8ED1 . 2192768 . . [5.1.2600.6055] . . c:\windows\$NtUninstallKB2633171$\ntoskrnl.exe
    [-] 2008-04-13 . 0C89243C7C3EE199B96FCC16990E0679 . 2188928 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\ntoskrnl.exe
    [-] 2008-04-14 . 54AF4B1D5459500EF0937F6D33B1914F . 175104 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\w32time.dll
    [-] 2008-04-14 . 54AF4B1D5459500EF0937F6D33B1914F . 175104 . . [5.1.2600.5512] . . c:\windows\system32\w32time.dll
    [-] 2008-04-14 . 8BAD69CBAC032D4BBACFCE0306174C30 . 333824 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\wiaservc.dll
    [-] 2008-04-14 . 8BAD69CBAC032D4BBACFCE0306174C30 . 333824 . . [5.1.2600.5512] . . c:\windows\system32\wiaservc.dll
    [-] 2008-04-14 . 5C12660A97822F6E61576943B49AAAD6 . 18944 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\midimap.dll
    [-] 2008-04-14 . 5C12660A97822F6E61576943B49AAAD6 . 18944 . . [5.1.2600.5512] . . c:\windows\system32\midimap.dll
    [-] 2008-04-14 . 6F9BEF24C578D5D6740E080BEDD6A448 . 7680 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\rasadhlp.dll
    [-] 2008-04-14 . 6F9BEF24C578D5D6740E080BEDD6A448 . 7680 . . [5.1.2600.5512] . . c:\windows\system32\rasadhlp.dll
    "ToolwizCareFree "= "c:\program files\ToolwizCareFree\ToolwizCares.exe" [2012-01-08 5043992]
    "NeroFilterCheck "= "c:\windows\system32\NeroCheck.exe" [2001-07-09 155648]
    "MSC "= "c:\program files\Microsoft Security Client\msseces.exe" [2011-06-15 997920]
    "LogitechQuickCamRibbon "= "c:\program files\Logitech\Logitech WebCam Software\LWS.exe" [2009-10-14 2793304]
    "SunJavaUpdateSched "= "c:\program files\Common Files\Java\Java Update\jusched.exe" [2011-06-09 254696]
    [HKEY_USERS\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\RunOnce]
    "RunNarrator "= "Narrator.exe" [2008-04-14 53760]
    c:\documents and settings\All Users\Start Menu\Programs\Startup\
    Microsoft Office.lnk - c:\program files\Microsoft Office\Office10\OSA.EXE [2001-2-13 83360]
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\MsMpSvc]
    @= "Service "
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\DVDFab Passkey]
    2011-03-18 01:08 1007608 ----a-w- c:\program files\DVDFab Passkey\DVDFabPasskey.exe
    "%windir%\\Network Diagnostic\\xpnetdiag.exe "=
    "c:\\WINDOWS\\system32\\mmc.exe "=
    "c:\\Documents and Settings\\Sven Albrecht\\My Documents\\Downloads\\Ghost\\Ghost32.Exe "=
    "c:\\Program Files\\Ahead\\Nero ShowTime\\ShowTime.exe "=
    "c:\\Program Files\\Skype\\Phone\\Skype.exe "=
    "c:\\Program Files\\Logitech\\Vid HD\\Vid.exe "=
    [HKLM\~\services\sharedaccess\parameters\firewallpolicy\standardprofile\GloballyOpenPorts\List]
    "5985:TCP "= 5985:TCP:*:Disabled:Windows Remote Management
    R0 BTOWSVF;BTOWSVF;c:\windows\system32\drivers\BTOWSVF.sys [1/7/2012 9:32 PM 41856]
    R0 KSafeDISK;KSafeDISK;c:\windows\system32\drivers\KSafeDISK.sys [1/7/2012 9:32 PM 46592]
    R1 BTOWSFF;BTOWSFF;c:\windows\system32\drivers\BTOWSFF.sys [1/7/2012 9:32 PM 24832]
    R2 nxsIO32;NextSensor Kernel I/O Driver;c:\windows\system32\drivers\nxsIO32.sys [7/11/2011 7:19 PM 2208]
    R3 dvdfab;dvdfab;c:\windows\system32\drivers\dvdfab.sys [3/19/2011 6:15 PM 82816]
    R3 pcouffin;VSO Software pcouffin;c:\windows\system32\drivers\pcouffin.sys [4/17/2010 7:44 AM 47360]
    S1 MpKsl084d3047;MpKsl084d3047;\??\c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{D10862DB-164B-4EBE-B29A-E9BAF01F0AD7}\MpKsl084d3047.sys --> c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{D10862DB-164B-4EBE-B29A-E9BAF01F0AD7}\MpKsl084d3047.sys [?]
    S1 MpKsl092cca26;MpKsl092cca26;\??\c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{D10862DB-164B-4EBE-B29A-E9BAF01F0AD7}\MpKsl092cca26.sys --> c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{D10862DB-164B-4EBE-B29A-E9BAF01F0AD7}\MpKsl092cca26.sys [?]
    S1 MpKsl0da5cdad;MpKsl0da5cdad;\??\c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{19A3822C-AA13-4CE0-9F7F-4E58BD6B7C2D}\MpKsl0da5cdad.sys --> c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{19A3822C-AA13-4CE0-9F7F-4E58BD6B7C2D}\MpKsl0da5cdad.sys [?]
    S1 MpKsl1d9a279e;MpKsl1d9a279e;\??\c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{19A3822C-AA13-4CE0-9F7F-4E58BD6B7C2D}\MpKsl1d9a279e.sys --> c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{19A3822C-AA13-4CE0-9F7F-4E58BD6B7C2D}\MpKsl1d9a279e.sys [?]
    S1 MpKsl41a884fe;MpKsl41a884fe;\??\c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{D10862DB-164B-4EBE-B29A-E9BAF01F0AD7}\MpKsl41a884fe.sys --> c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{D10862DB-164B-4EBE-B29A-E9BAF01F0AD7}\MpKsl41a884fe.sys [?]
    S1 MpKsl46fa41df;MpKsl46fa41df;\??\c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{D10862DB-164B-4EBE-B29A-E9BAF01F0AD7}\MpKsl46fa41df.sys --> c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{D10862DB-164B-4EBE-B29A-E9BAF01F0AD7}\MpKsl46fa41df.sys [?]
    S1 MpKsl6a75b4d1;MpKsl6a75b4d1;\??\c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{D10862DB-164B-4EBE-B29A-E9BAF01F0AD7}\MpKsl6a75b4d1.sys --> c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{D10862DB-164B-4EBE-B29A-E9BAF01F0AD7}\MpKsl6a75b4d1.sys [?]
    S1 MpKsl79b2df12;MpKsl79b2df12;\??\c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{D10862DB-164B-4EBE-B29A-E9BAF01F0AD7}\MpKsl79b2df12.sys --> c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{D10862DB-164B-4EBE-B29A-E9BAF01F0AD7}\MpKsl79b2df12.sys [?]
    S1 MpKsl7da4a7ac;MpKsl7da4a7ac;\??\c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{19A3822C-AA13-4CE0-9F7F-4E58BD6B7C2D}\MpKsl7da4a7ac.sys --> c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{19A3822C-AA13-4CE0-9F7F-4E58BD6B7C2D}\MpKsl7da4a7ac.sys [?]
    S1 MpKsl7db78654;MpKsl7db78654;\??\c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{52E7C91F-94A5-4DB8-BE7B-CE59A53ED850}\MpKsl7db78654.sys --> c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{52E7C91F-94A5-4DB8-BE7B-CE59A53ED850}\MpKsl7db78654.sys [?]
    S1 MpKsl897a50c1;MpKsl897a50c1;\??\c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{406E2DF1-180F-4B67-B84C-E567B4C31E53}\MpKsl897a50c1.sys --> c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{406E2DF1-180F-4B67-B84C-E567B4C31E53}\MpKsl897a50c1.sys [?]
    S1 MpKsla018b693;MpKsla018b693;\??\c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{D10862DB-164B-4EBE-B29A-E9BAF01F0AD7}\MpKsla018b693.sys --> c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{D10862DB-164B-4EBE-B29A-E9BAF01F0AD7}\MpKsla018b693.sys [?]
    S1 MpKslbb685873;MpKslbb685873;\??\c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{D10862DB-164B-4EBE-B29A-E9BAF01F0AD7}\MpKslbb685873.sys --> c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{D10862DB-164B-4EBE-B29A-E9BAF01F0AD7}\MpKslbb685873.sys [?]
    S1 MpKsld70019f1;MpKsld70019f1;\??\c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{F30F5648-297E-4995-A3C7-43E3382E3A16}\MpKsld70019f1.sys --> c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{F30F5648-297E-4995-A3C7-43E3382E3A16}\MpKsld70019f1.sys [?]
    S1 MpKsle10af837;MpKsle10af837;\??\c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{19A3822C-AA13-4CE0-9F7F-4E58BD6B7C2D}\MpKsle10af837.sys --> c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{19A3822C-AA13-4CE0-9F7F-4E58BD6B7C2D}\MpKsle10af837.sys [?]
    S1 MpKslfc56a8e9;MpKslfc56a8e9;\??\c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{19A3822C-AA13-4CE0-9F7F-4E58BD6B7C2D}\MpKslfc56a8e9.sys --> c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{19A3822C-AA13-4CE0-9F7F-4E58BD6B7C2D}\MpKslfc56a8e9.sys [?]
    S2 clr_optimization_v4.0.30319_32;Microsoft .NET Framework NGEN v4.0.30319_X86;c:\windows\Microsoft.NET\Framework\v4.0.30319\mscorsvw.exe [3/18/2010 12:16 PM 130384]
    S2 Freemake Improver;Freemake Improver;c:\documents and settings\All Users\Application Data\Freemake\FreemakeUtilsService\FreemakeUtilsService.exe [11/24/2011 4:38 PM 74752]
    S3 scsiscan;SCSI Scanner Driver;c:\windows\system32\drivers\scsiscan.sys [4/16/2010 5:47 PM 11520]
    S3 Vsp;Vsp;\??\c:\windows\system32\drivers\Vsp.sys --> c:\windows\system32\drivers\Vsp.sys [?]
    S3 WinRM;Windows Remote Management (WS-Management);c:\windows\system32\svchost.exe -k WINRM [8/3/2004 11:56 PM 14336]
    S3 WPFFontCache_v0400;Windows Presentation Foundation Font Cache 4.0.0.0;c:\windows\Microsoft.NET\Framework\v4.0.30319\WPF\WPFFontCache_v0400.exe [3/18/2010 12:16 PM 753504]
    [HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\svchost]
    WINRM REG_MULTI_SZ WINRM
    2012-01-15 c:\windows\Tasks\User_Feed_Synchronization-{3E754F6A-E80F-4D39-AE7B-CBD977D2FB14}.job
    - c:\windows\system32\msfeedssync.exe [2009-03-08 11:31]
    uStart Page = hxxp://www.windowsbbs.com/
    uInternet Connection Wizard,ShellNext = iexplore
    IE: &ieSpell Options - c:\program files\ieSpell\iespell.dll/SPELLOPTION.HTM
    IE: Check &Spelling - c:\program files\ieSpell\iespell.dll/SPELLCHECK.HTM
    IE: E&xport to Microsoft Excel - c:\progra~1\MICROS~3\Office10\EXCEL.EXE/3000
    IE: Lookup on Merriam Webster - file://c:\program files\ieSpell\Merriam Webster.HTM
    IE: Lookup on Wikipedia - file://c:\program files\ieSpell\wikipedia.HTM
    Trusted Zone: clonewarsadventures.com
    Trusted Zone: freerealms.com
    Trusted Zone: soe.com
    Trusted Zone: sony.com
    TCP: DhcpNameServer = 192.168.1.1
    BHO-{28387537-e3f9-4ed7-860c-11e69af4a8a0} - (no file)
    BHO-{474597C5-AB09-49d6-A4D5-2E8D7341384E} - (no file)
    Toolbar-{28387537-e3f9-4ed7-860c-11e69af4a8a0} - (no file)
    Toolbar-10 - (no file)
    HKLM-Run-SimpleScreenshot - c:\progra~1\SSS\SIMPLESCREENSHOT.EXE
    HKLM-Run-Cmaudio - cmicnfg.cpl
    Rootkit scan 2012-01-14 19:15
    Windows 5.1.2600 Service Pack 3 NTFS
    scanning hidden processes ...
    scanning hidden files ...
    scan completed successfully
    hidden files: 0
    [HKEY_USERS\S-1-5-21-606747145-1500820517-682003330-1004\Software\Microsoft\SystemCertificates\AddressBook*]
    @Allowed: (Read) (RestrictedCode)
    - - - - - - - > 'winlogon.exe'(620)
    c:\windows\system32\Ati2evxx.dll
    - - - - - - - > 'explorer.exe'(6100)
    c:\windows\system32\WININET.dll
    c:\windows\system32\ieframe.dll
    c:\windows\system32\webcheck.dll
    c:\windows\system32\WPDShServiceObj.dll
    c:\windows\system32\PortableDeviceTypes.dll
    c:\windows\system32\PortableDeviceApi.dll
    ------------------------ Other Running Processes ------------------------
    c:\windows\system32\Ati2evxx.exe
    c:\program files\Microsoft Security Client\Antimalware\MsMpEng.exe
    c:\windows\system32\LEXBCES.EXE
    c:\windows\system32\LEXPPS.EXE
    c:\program files\Java\jre6\bin\jqs.exe
    c:\windows\system32\MsPMSPSv.exe
    c:\program files\Windows Media Player\WMPNetwk.exe
    c:\program files\Microsoft Office\Office10\msoffice.exe
    c:\program files\Common Files\Logishrd\LQCVFX\COCIManager.exe
    Completion time: 2012-01-14 19:25:26 - machine was rebooted
    ComboFix-quarantined-files.txt 2012-01-15 03:25
    Pre-Run: 16,191,479,808 bytes free
    Post-Run: 16,305,049,600 bytes free
    - - End Of File - - 89900B30954889DFE9ED102F09A46B39
    This log file is located at C:\rkill.log.
    Please post this only if requested to by the person helping you.
    Otherwise you can close this log when you wish.
    Rkill was run on 01/14/2012 at 19:28:28.
    Operating System: Microsoft Windows XP
    Processes terminated by Rkill or while it was running:
    Rkill completed on 01/14/2012 at 19:28:33.
  13. 2012/01/15
    Looks good now.
    Download OTL to your Desktop.
    • Double click on the icon to run it. Make sure all other windows are closed and to let it run uninterrupted.
    • Click the Scan All Users checkbox.
    • Under the Custom Scan box paste this in:
    netsvcs
    drivers32
    %SYSTEMDRIVE%\*.*
    %systemroot%\Fonts\*.com
    %systemroot%\Fonts\*.dll
    %systemroot%\Fonts\*.ini
    %systemroot%\Fonts\*.ini2
    %systemroot%\Fonts\*.exe
    %systemroot%\system32\spool\prtprocs\w32x86\*.*
    %systemroot%\REPAIR\*.bak1
    %systemroot%\REPAIR\*.ini
    %systemroot%\*.scr
    %systemroot%\*._sy
    %APPDATA%\Adobe\Update\*.*
    %ALLUSERSPROFILE%\Favorites\*.*
    %APPDATA%\Microsoft\*.*
    %PROGRAMFILES%\*.*
    %APPDATA%\Update\*.*
    %systemroot%\*. /mp /s
    CREATERESTOREPOINT
    %systemroot%\System32\config\*.sav
    %PROGRAMFILES%\bak. /s
    %systemroot%\system32\bak. /s
    %ALLUSERSPROFILE%\Start Menu\*.lnk /x
    %systemroot%\system32\config\systemprofile\*.dat /x
    %systemroot%\*.config
    %systemroot%\system32\*.db
    %APPDATA%\Microsoft\Internet Explorer\Quick Launch\*.lnk /x
    %USERPROFILE%\Desktop\*.exe
    %PROGRAMFILES%\Common Files\*.*
    %systemroot%\*.src
    %systemroot%\install\*.*
    %systemroot%\system32\DLL\*.*
    %systemroot%\system32\HelpFiles\*.*
    %systemroot%\system32\rundll\*.*
    %systemroot%\winn32\*.*
    %systemroot%\Java\*.*
    %systemroot%\system32\test\*.*
    %systemroot%\system32\Rundll32\*.*
    %systemroot%\AppPatch\Custom\*.*
    %APPDATA%\Roaming\Microsoft\Windows\Recent\*.lnk /x
    %PROGRAMFILES%\PC-Doctor\Downloads\*.*
    %PROGRAMFILES%\Internet Explorer\*.tmp
    %PROGRAMFILES%\Internet Explorer\*.dat
    %USERPROFILE%\My Documents\*.exe
    %USERPROFILE%\*.exe
    %systemroot%\ADDINS\*.*
    %systemroot%\assembly\*.bak2
    %systemroot%\Config\*.*
    %systemroot%\REPAIR\*.bak2
    %systemroot%\SECURITY\Database\*.sdb /x
    %systemroot%\SYSTEM\*.bak2
    %systemroot%\Web\*.bak2
    %systemroot%\Driver Cache\*.*
    %PROGRAMFILES%\Mozilla Firefox\0*.exe
    %ProgramFiles%\Microsoft Common\*.*
    %ProgramFiles%\TinyProxy.
    %USERPROFILE%\Favorites\*.url /x
    %systemroot%\system32\*.bk
    %systemroot%\*.te
    %systemroot%\system32\system32\*.*
    %ALLUSERSPROFILE%\*.dat /x
    %systemroot%\system32\drivers\*.rmv
    dir /b "%systemroot%\system32\*.exe" | find /i " " /c
    dir /b "%systemroot%\*.exe" | find /i " " /c
    %PROGRAMFILES%\Microsoft\*.*
    %systemroot%\System32\Wbem\proquota.exe
    %PROGRAMFILES%\Mozilla Firefox\*.dat
    %USERPROFILE%\Cookies\*.txt /x
    %SystemRoot%\system32\fonts\*.*
    %systemroot%\system32\winlog\*.*
    %systemroot%\system32\Language\*.*
    %systemroot%\system32\Settings\*.*
    %systemroot%\system32\*.quo
    %SYSTEMROOT%\AppPatch\*.exe
    %SYSTEMROOT%\inf\*.exe
    %SYSTEMROOT%\Installer\*.exe
    %systemroot%\system32\config\*.bak2
    %systemroot%\system32\Computers\*.*
    %SystemRoot%\system32\Sound\*.*
    %SystemRoot%\system32\SpecialImg\*.*
    %SystemRoot%\system32\code\*.*
    %SystemRoot%\system32\draft\*.*
    %SystemRoot%\system32\MSSSys\*.*
    %ProgramFiles%\Javascript\*.*
    %systemroot%\pchealth\helpctr\System\*.exe /s
    %systemroot%\Web\*.exe
    %systemroot%\system32\msn\*.*
    %systemroot%\system32\*.tro
    %AppData%\Microsoft\Installer\msupdates\*.*
    %ProgramFiles%\Messenger\*.*
    %systemroot%\system32\systhem32\*.*
    %systemroot%\system\*.exe
    HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate\AU
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Auto Update\Results\Install|LastSuccessTime /rs
    /md5start
    /md5stop
    • Click the Quick Scan button. Do not change any settings unless otherwise told to do so. The scan wont take long.
    • When the scan completes, it will open two notepad windows: OTL.txt and Extras.txt. These are saved in the same location as OTL.
    • Please copy (Edit->Select All, Edit->Copy) the contents of these files, one at a time, and post them back here.
  14. 2012/01/15
    SVEN
    OTL logfile created on: 1/15/2012 9:31:38 AM - Run 1
    OTL by OldTimer - Version 3.2.31.0 Folder = C:\Documents and Settings\Sven Albrecht\Desktop
    Windows XP Home Edition Service Pack 3 (Version = 5.1.2600) - Type = NTWorkstation
    Internet Explorer (Version = 8.0.6001.18702)
    Locale: 00000409 | Country: United States | Language: ENU | Date Format: M/d/yyyy
    1023.48 Mb Total Physical Memory | 557.66 Mb Available Physical Memory | 54.49% Memory free
    2.40 Gb Paging File | 2.03 Gb Available in Paging File | 84.59% Paging File free
    Paging file location(s): C:\pagefile.sys 1536 3072 [binary data]
    %SystemDrive% = C: | %SystemRoot% = C:\WINDOWS | %ProgramFiles% = C:\Program Files
    Drive C: | 35.15 Gb Total Space | 15.19 Gb Free Space | 43.22% Space Free | Partition Type: NTFS
    Drive D: | 37.12 Gb Total Space | 37.01 Gb Free Space | 99.71% Space Free | Partition Type: NTFS
    Drive E: | 2.11 Gb Total Space | 1.18 Gb Free Space | 55.99% Space Free | Partition Type: NTFS
    Drive F: | 37.41 Gb Total Space | 22.61 Gb Free Space | 60.44% Space Free | Partition Type: NTFS
    Computer Name: SVEN-ALBRECHT | User Name: Sven Albrecht | Logged in as Administrator.
    Boot Mode: Normal | Scan Mode: All users | Quick Scan
    Company Name Whitelist: On | Skip Microsoft Files: On | No Company Name Whitelist: On | File Age = 30 Days
    PRC - [2012/01/15 09:29:40 | 000,584,192 | ---- | M] (OldTimer Tools) -- C:\Documents and Settings\Sven Albrecht\Desktop\OTL.exe
    PRC - [2011/06/15 14:16:48 | 000,997,920 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Microsoft Security Client\msseces.exe
    PRC - [2011/04/27 14:39:26 | 000,011,736 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Microsoft Security Client\Antimalware\MsMpEng.exe
    PRC - [2009/10/14 12:36:56 | 002,793,304 | ---- | M] () -- C:\Program Files\Logitech\Logitech WebCam Software\LWS.exe
    PRC - [2009/10/14 12:34:18 | 000,560,472 | ---- | M] () -- C:\Program Files\Common Files\LogiShrd\LQCVFX\COCIManager.exe
    PRC - [2009/10/07 00:47:34 | 000,154,136 | ---- | M] (Logitech Inc.) -- C:\Program Files\Common Files\LogiShrd\LVMVFM\LVPrcSrv.exe
    PRC - [2008/04/13 16:12:19 | 001,033,728 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\explorer.exe
    ========== Modules (No Company Name) ==========
    MOD - [2009/10/14 12:36:56 | 002,793,304 | ---- | M] () -- C:\Program Files\Logitech\Logitech WebCam Software\LWS.exe
    MOD - [2009/10/14 12:34:18 | 000,560,472 | ---- | M] () -- C:\Program Files\Common Files\LogiShrd\LQCVFX\COCIManager.exe
    MOD - [2003/07/29 05:27:40 | 000,078,336 | ---- | M] () -- C:\WINDOWS\system32\spool\prtprocs\w32x86\DLBCPP5C.DLL
    SRV - File not found [Disabled | Stopped] -- -- (HidServ)
    SRV - File not found [On_Demand | Stopped] -- -- (AppMgmt)
    SRV - File not found [On_Demand | Stopped] -- -- (ACDaemon)
    SRV - [2011/12/20 16:12:04 | 000,074,752 | ---- | M] (Freemake) [Auto | Stopped] -- C:\Documents and Settings\All Users\Application Data\Freemake\FreemakeUtilsService\FreemakeUtilsService.exe -- (Freemake Improver)
    SRV - [2011/04/27 14:39:26 | 000,011,736 | ---- | M] (Microsoft Corporation) [Auto | Running] -- C:\Program Files\Microsoft Security Client\Antimalware\MsMpEng.exe -- (MsMpSvc)
    SRV - [2009/10/07 00:47:34 | 000,154,136 | ---- | M] (Logitech Inc.) [Auto | Running] -- C:\Program Files\Common Files\LogiShrd\LVMVFM\LVPrcSrv.exe -- (LVPrcSrv)
    DRV - [2012/01/15 09:26:46 | 000,029,904 | ---- | M] (Microsoft Corporation) [Kernel | System | Running] -- C:\Documents and Settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{C9A46D03-ECE7-498E-B5F8-E730A63872DE}\MpKslceeb5842.sys -- (MpKslceeb5842)
    DRV - [2012/01/07 21:32:53 | 000,046,592 | ---- | M] (BTOWS.com) [Kernel | Boot | Running] -- C:\WINDOWS\system32\Drivers\KSafeDISK.sys -- (KSafeDISK)
    DRV - [2012/01/07 21:32:53 | 000,024,832 | ---- | M] (BTOWS.com) [File_System | System | Running] -- C:\WINDOWS\system32\drivers\BTOWSFF.sys -- (BTOWSFF)
    DRV - [2012/01/07 21:32:52 | 000,041,856 | ---- | M] (BTOWS.com) [Kernel | Boot | Running] -- C:\WINDOWS\system32\Drivers\BTOWSVF.sys -- (BTOWSVF)
    DRV - [2011/07/11 19:19:51 | 000,002,208 | ---- | M] () [Kernel | Auto | Running] -- C:\WINDOWS\system32\drivers\nxsIO32.sys -- (nxsIO32)
    DRV - [2011/03/16 17:49:42 | 000,082,816 | ---- | M] (Fengtao Software Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\dvdfab.sys -- (dvdfab)
    DRV - [2009/10/07 00:49:50 | 000,023,832 | R--- | M] (Logitech Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\lvuvcflt.sys -- (FilterService)
    DRV - [2009/10/07 00:49:38 | 006,756,632 | R--- | M] (Logitech Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\lvuvc.sys -- (LVUVC) Logitech Webcam 250(UVC)
    DRV - [2009/10/07 00:47:55 | 000,266,008 | R--- | M] (Logitech Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\lvrs.sys -- (LVRS)
    DRV - [2009/10/07 00:46:36 | 000,025,752 | ---- | M] () [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\LVPr2Mon.sys -- (LVPr2Mon)
    DRV - [2009/10/07 00:46:12 | 000,114,712 | R--- | M] (Logitech Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\lvpopflt.sys -- (lvpopflt)
    DRV - [2008/04/13 10:45:34 | 000,011,520 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\scsiscan.sys -- (scsiscan)
    DRV - [2006/02/21 19:46:26 | 001,505,792 | ---- | M] (ATI Technologies Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\ati2mtag.sys -- (ati2mtag)
    DRV - [2003/10/19 19:39:56 | 000,073,856 | R--- | M] (VIA Technologies, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\viaudio.sys -- (VIAudio) VIA AC'97 Audio Controller (WDM)
    DRV - [2001/07/12 13:54:20 | 000,584,304 | ---- | M] (Conexant Systems) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\HSF_CNXT.sys -- (winachsf)
    DRV - [2001/07/12 13:52:38 | 000,427,167 | ---- | M] (Conexant Systems) [Kernel | Auto | Running] -- C:\WINDOWS\system32\drivers\k56nt.sys -- (K56)
    DRV - [2001/07/12 13:52:10 | 000,310,739 | ---- | M] (Conexant Systems) [Kernel | Auto | Running] -- C:\WINDOWS\system32\drivers\fallback.sys -- (Fallback)
    DRV - [2001/07/12 13:49:32 | 000,077,426 | ---- | M] (Conexant Systems) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\basic2.sys -- (basic2)
    DRV - [2001/07/12 13:49:10 | 000,534,605 | ---- | M] (Conexant Systems) [Kernel | Auto | Running] -- C:\WINDOWS\system32\drivers\v124nt.sys -- (V124)
    DRV - [2001/07/03 17:42:30 | 000,017,776 | ---- | M] (Conexant Systems) [Kernel | Auto | Running] -- C:\WINDOWS\system32\drivers\cnxtdiag.sys -- (Cnxtdiag)
    DRV - [2001/06/14 18:37:38 | 000,127,405 | ---- | M] (Conexant Systems) [Kernel | Auto | Running] -- C:\WINDOWS\system32\drivers\fsksnt.sys -- (Fsks)
    DRV - [2001/06/14 18:36:52 | 000,216,987 | ---- | M] (Conexant Systems) [Kernel | Auto | Running] -- C:\WINDOWS\system32\drivers\faxnt.sys -- (SoftFax)
    DRV - [2001/06/14 18:35:50 | 000,056,639 | ---- | M] (Conexant Systems) [Kernel | Auto | Running] -- C:\WINDOWS\system32\drivers\tonesnt.sys -- (Tones)
    DRV - [2001/06/14 18:33:04 | 000,067,622 | ---- | M] (Conexant Systems) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\rksample.sys -- (Rksample)
    IE - HKU\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyEnable" = 0
    IE - HKU\S-1-5-18\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyEnable" = 0
    IE - HKU\S-1-5-21-606747145-1500820517-682003330-1004\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page = http://www.windowsbbs.com/
    IE - HKU\S-1-5-21-606747145-1500820517-682003330-1004\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyEnable" = 0
    FF - HKLM\Software\MozillaPlugins\@java.com/JavaPlugin: C:\Program Files\Java\jre6\bin\new_plugin\npjp2.dll (Sun Microsystems, Inc.)
    FF - HKLM\Software\MozillaPlugins\@Microsoft.com/NpCtrl,version=1.0: C:\Program Files\Microsoft Silverlight\4.0.60831.0\npctrl.dll ( Microsoft Corporation)
    FF - HKLM\Software\MozillaPlugins\@microsoft.com/WPF,version=3.5: C:\WINDOWS\Microsoft.NET\Framework\v3.5\Windows Presentation Foundation\NPWPF.dll (Microsoft Corporation)
    FF - HKLM\Software\MozillaPlugins\@soe.sony.com/installer,version=1.0.3: C:\WINDOWS\Downloaded Program Files\npsoe.dll ()
    FF - HKEY_LOCAL_MACHINE\software\mozilla\Firefox\Extensions\\fmconverter@gmail.com: C:\Program Files\Freemake\Freemake Video Converter\BrowserPlugin\Firefox\ [2011/12/20 13:39:39 | 000,000,000 | ---D | M]
    FF - HKEY_LOCAL_MACHINE\software\mozilla\Firefox\Extensions\\m3ffxtbr@mywebsearch.com: C:\Program Files\MyWebSearch\bar\1.bin
    O1 HOSTS File: ([2012/01/14 19:14:25 | 000,000,027 | ---- | M]) - C:\WINDOWS\system32\drivers\etc\hosts
    O2 - BHO: (Skype Browser Helper) - {AE805869-2E5C-4ED4-8F7B-F1F7851A4497} - C:\Program Files\Skype\Toolbars\Internet Explorer\skypeieplugin.dll (Skype Technologies S.A.)
    O4 - HKLM..\Run: [LogitechQuickCamRibbon] C:\Program Files\Logitech\Logitech WebCam Software\LWS.exe ()
    O4 - HKLM..\Run: [MSC] C:\Program Files\Microsoft Security Client\msseces.exe (Microsoft Corporation)
    O4 - HKLM..\Run: [NeroFilterCheck] C:\WINDOWS\system32\NeroCheck.exe (Ahead Software Gmbh)
    O4 - HKU\S-1-5-21-606747145-1500820517-682003330-1004..\Run: [ToolwizCareFree] C:\Program files\ToolwizCareFree\ToolwizCares.exe ()
    O4 - HKU\.DEFAULT..\RunOnce: [RunNarrator] C:\WINDOWS\System32\narrator.exe (Microsoft Corporation)
    O4 - HKU\S-1-5-18..\RunOnce: [RunNarrator] C:\WINDOWS\System32\narrator.exe (Microsoft Corporation)
    O6 - HKLM\Software\Policies\Microsoft\Internet Explorer\Restrictions present
    O7 - HKU\.DEFAULT\Software\Policies\Microsoft\Internet Explorer\Control Panel present
    O7 - HKU\.DEFAULT\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveTypeAutoRun = 323
    O7 - HKU\.DEFAULT\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveAutoRun = 67108863
    O7 - HKU\S-1-5-18\Software\Policies\Microsoft\Internet Explorer\Control Panel present
    O7 - HKU\S-1-5-18\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveTypeAutoRun = 323
    O7 - HKU\S-1-5-18\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveAutoRun = 67108863
    O7 - HKU\S-1-5-19\Software\Policies\Microsoft\Internet Explorer\Control Panel present
    O7 - HKU\S-1-5-19\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveTypeAutoRun = 145
    O7 - HKU\S-1-5-20\Software\Policies\Microsoft\Internet Explorer\Control Panel present
    O7 - HKU\S-1-5-20\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveTypeAutoRun = 145
    O7 - HKU\S-1-5-21-606747145-1500820517-682003330-1004\Software\Policies\Microsoft\Internet Explorer\Control Panel present
    O7 - HKU\S-1-5-21-606747145-1500820517-682003330-1004\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveTypeAutoRun = 323
    O7 - HKU\S-1-5-21-606747145-1500820517-682003330-1004\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NolowDiskSpaceChecks = 1
    O7 - HKU\S-1-5-21-606747145-1500820517-682003330-1004\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveAutoRun = 67108863
    O7 - HKU\S-1-5-21-606747145-1500820517-682003330-1004\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDrives = 0
    O8 - Extra context menu item: &ieSpell Options - C:\Program Files\ieSpell\iespell.dll (Red Egg Software)
    O8 - Extra context menu item: Check &Spelling - C:\Program Files\ieSpell\iespell.dll (Red Egg Software)
    O8 - Extra context menu item: Lookup on Merriam Webster - C:\Program Files\ieSpell\Merriam Webster.HTM ()
    O8 - Extra context menu item: Lookup on Wikipedia - C:\Program Files\ieSpell\wikipedia.HTM ()
    O9 - Extra Button: ieSpell - {0E17D5B7-9F5D-4fee-9DF6-CA6EE38B68A8} - C:\Program Files\ieSpell\iespell.dll (Red Egg Software)
    O9 - Extra 'Tools' menuitem : ieSpell - {0E17D5B7-9F5D-4fee-9DF6-CA6EE38B68A8} - C:\Program Files\ieSpell\iespell.dll (Red Egg Software)
    O9 - Extra 'Tools' menuitem : ieSpell Options - {1606D6F9-9D3B-4aea-A025-ED5B2FD488E7} - C:\Program Files\ieSpell\iespell.dll (Red Egg Software)
    O9 - Extra Button: Skype Plug-In - {898EA8C8-E7FF-479B-8935-AEC46303B9E5} - C:\Program Files\Skype\Toolbars\Internet Explorer\skypeieplugin.dll (Skype Technologies S.A.)
    O9 - Extra 'Tools' menuitem : Skype Plug-In - {898EA8C8-E7FF-479B-8935-AEC46303B9E5} - C:\Program Files\Skype\Toolbars\Internet Explorer\skypeieplugin.dll (Skype Technologies S.A.)
    O9 - Extra Button: PokerStars.net - {FA9B9510-9FCB-4ca0-818C-5D0987B47C4D} - C:\Program Files\PokerStars.NET\PokerStarsUpdate.exe (PokerStars)
    O15 - HKU\S-1-5-19\..Trusted Domains: clonewarsadventures.com ([]* in Trusted sites)
    O15 - HKU\S-1-5-19\..Trusted Domains: freerealms.com ([]* in Trusted sites)
    O15 - HKU\S-1-5-19\..Trusted Domains: soe.com ([]* in Trusted sites)
    O15 - HKU\S-1-5-19\..Trusted Domains: sony.com ([]* in Trusted sites)
    O15 - HKU\S-1-5-21-606747145-1500820517-682003330-1004\..Trusted Domains: clonewarsadventures.com ([]* in Trusted sites)
    O15 - HKU\S-1-5-21-606747145-1500820517-682003330-1004\..Trusted Domains: freerealms.com ([]* in Trusted sites)
    O15 - HKU\S-1-5-21-606747145-1500820517-682003330-1004\..Trusted Domains: soe.com ([]* in Trusted sites)
    O15 - HKU\S-1-5-21-606747145-1500820517-682003330-1004\..Trusted Domains: sony.com ([]* in Trusted sites)
    O16 - DPF: {000F1EA4-5E08-4564-A29B-29076F63A37A} http://launch.soe.com/plugin/web/SOEWebInstaller.cab (SOE Web Installer)
    O16 - DPF: {6E32070A-766D-4EE6-879C-DC1FA91D2FC3} http://www.update.microsoft.com/mic...ls/en/x86/client/muweb_site.cab?1271466570453 (MUWebControl Class)
    O16 - DPF: {7530BFB8-7293-4D34-9923-61A11451AFC5} http://download.eset.com/special/eos/OnlineScanner.cab (OnlineScanner Control)
    O16 - DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} http://java.sun.com/update/1.6.0/jinstall-1_6_0_29-windows-i586.cab (Java Plug-in 1.6.0_29)
    O16 - DPF: {BEA7310D-06C4-4339-A784-DC3804819809} http://www.cvsphoto.com/upload/activex/v3_0_0_7/PhotoCenter_ActiveX_Control.cab (Photo Upload Plugin Class)
    O16 - DPF: {CAFEEFAC-0016-0000-0029-ABCDEFFEDCBA} http://java.sun.com/update/1.6.0/jinstall-1_6_0_29-windows-i586.cab (Java Plug-in 1.6.0_29)
    O16 - DPF: {CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} http://java.sun.com/update/1.6.0/jinstall-1_6_0_29-windows-i586.cab (Java Plug-in 1.6.0_29)
    O16 - DPF: {D27CDB6E-AE6D-11CF-96B8-444553540000} http://fpdownload2.macromedia.com/get/shockwave/cabs/flash/swflash.cab (Shockwave Flash Object)
    O16 - DPF: {E2883E8F-472F-4FB0-9522-AC9BF37916A7} http://platformdl.adobe.com/NOS/getPlusPlus/1.6/gp.cab (Reg Error: Key error.)
    O17 - HKLM\System\CCS\Services\Tcpip\Parameters: DhcpNameServer = 192.168.1.1
    O17 - HKLM\System\CCS\Services\Tcpip\Parameters\Interfaces\{2D059D5C-CF29-4C6A-9175-92727DF0AF38}: DhcpNameServer = 192.168.1.1
    O18 - Protocol\Handler\skype-ie-addon-data {91774881-D725-4E58-B298-07617B9B86A8} - C:\Program Files\Skype\Toolbars\Internet Explorer\skypeieplugin.dll (Skype Technologies S.A.)
    O20 - HKLM Winlogon: Shell - (Explorer.exe) -C:\WINDOWS\explorer.exe (Microsoft Corporation)
    O20 - HKLM Winlogon: UserInit - (C:\WINDOWS\system32\userinit.exe) -C:\WINDOWS\system32\userinit.exe (Microsoft Corporation)
    O20 - Winlogon\Notify\AtiExtEvent: DllName - (Ati2evxx.dll) - C:\WINDOWS\System32\ati2evxx.dll (ATI Technologies Inc.)
    O24 - Desktop WallPaper: C:\Documents and Settings\Sven Albrecht\Local Settings\Application Data\Microsoft\Wallpaper1.bmp
    O24 - Desktop BackupWallPaper: C:\Documents and Settings\Sven Albrecht\Local Settings\Application Data\Microsoft\Wallpaper1.bmp
    O32 - HKLM CDRom: AutoRun - 1
    O32 - AutoRun File - [2010/04/16 13:55:36 | 000,000,000 | ---- | M] () - C:\AUTOEXEC.BAT -- [ NTFS ]
    O34 - HKLM BootExecute: (autocheck autochk *)
    O37 - HKLM\...com [@ = ComFile] -- "%1" %*
    NetSvcs: 6to4 - File not found
    NetSvcs: AppMgmt - File not found
    NetSvcs: HidServ - File not found
    NetSvcs: Ias - File not found
    NetSvcs: Iprip - File not found
    NetSvcs: Irmon - File not found
    NetSvcs: NWCWorkstation - File not found
    NetSvcs: Nwsapagent - File not found
    NetSvcs: WmdmPmSp - File not found
    Drivers32: msacm.iac2 - C:\WINDOWS\system32\iac25_32.ax (Intel Corporation)
    Drivers32: msacm.l3acm - C:\WINDOWS\system32\l3codeca.acm (Fraunhofer Institut Integrierte Schaltungen IIS)
    Drivers32: msacm.sl_anet - C:\WINDOWS\System32\sl_anet.acm (Sipro Lab Telecom Inc.)
    Drivers32: msacm.trspch - C:\WINDOWS\System32\tssoft32.acm (DSP GROUP, INC.)
    Drivers32: MSVideo - C:\WINDOWS\System32\vfwwdm32.dll (Microsoft Corporation)
    Drivers32: MSVideo8 - C:\WINDOWS\System32\vfwwdm32.dll (Microsoft Corporation)
    Drivers32: vidc.cvid - C:\WINDOWS\System32\iccvid.dll (Radius Inc.)
    Drivers32: vidc.iv31 - C:\WINDOWS\System32\ir32_32.dll ()
    Drivers32: vidc.iv32 - C:\WINDOWS\System32\ir32_32.dll ()
    Drivers32: vidc.iv41 - C:\WINDOWS\System32\ir41_32.ax (Intel Corporation)
    Drivers32: vidc.iv50 - C:\WINDOWS\System32\ir50_32.dll (Intel Corporation)
    CREATERESTOREPOINT
    Restore point Set: OTL Restore Point
    ========== Files/Folders - Created Within 30 Days ==========
    [2012/01/15 09:29:27 | 000,584,192 | ---- | C] (OldTimer Tools) -- C:\Documents and Settings\Sven Albrecht\Desktop\OTL.exe
    [2012/01/14 19:48:03 | 000,000,000 | -HSD | C] -- C:\RECYCLER
    [2012/01/14 16:25:34 | 000,000,000 | RHSD | C] -- C:\cmdcons
    [2012/01/14 16:23:40 | 000,518,144 | ---- | C] (SteelWerX) -- C:\WINDOWS\SWREG.exe
    [2012/01/14 16:23:40 | 000,406,528 | ---- | C] (SteelWerX) -- C:\WINDOWS\SWSC.exe
    [2012/01/14 16:23:40 | 000,212,480 | ---- | C] (SteelWerX) -- C:\WINDOWS\SWXCACLS.exe
    [2012/01/14 16:23:40 | 000,060,416 | ---- | C] (NirSoft) -- C:\WINDOWS\NIRCMD.exe
    [2012/01/14 16:23:30 | 000,000,000 | ---D | C] -- C:\WINDOWS\ERDNT
    [2012/01/14 16:21:50 | 000,000,000 | ---D | C] -- C:\Qoobox
    [2012/01/14 09:49:56 | 000,000,000 | R--D | C] -- C:\Documents and Settings\Sven Albrecht\Start Menu\Programs\Administrative Tools
    [2012/01/11 20:13:58 | 000,000,000 | ---D | C] -- C:\symbols
    [2012/01/10 20:32:02 | 000,000,000 | ---D | C] -- C:\Config.Msi
    [2012/01/10 20:30:49 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Start Menu\Programs\WhoCrashed
    [2012/01/10 20:30:45 | 000,000,000 | ---D | C] -- C:\Program Files\WhoCrashed
    [2012/01/07 21:32:53 | 000,046,592 | ---- | C] (BTOWS.com) -- C:\WINDOWS\System32\drivers\KSafeDISK.sys
    [2012/01/07 21:32:53 | 000,024,832 | ---- | C] (BTOWS.com) -- C:\WINDOWS\System32\drivers\BTOWSFF.sys
    [2012/01/07 21:32:53 | 000,000,000 | ---D | C] -- C:\Toolwiz
    [2012/01/07 21:32:52 | 000,041,856 | ---- | C] (BTOWS.com) -- C:\WINDOWS\System32\drivers\BTOWSVF.sys
    [2012/01/07 21:32:38 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Start Menu\Programs\ToolwizCareFree
    [2012/01/07 21:32:37 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Sven Albrecht\Local Settings\Application Data\ToolwizCareFree
    [2011/12/25 14:28:55 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Sven Albrecht\My Documents\2012
    [2011/12/18 10:01:45 | 000,000,000 | ---D | C] -- C:\Program Files\ToolwizCareFree
    [2010/04/17 07:44:23 | 000,047,360 | ---- | C] (VSO Software) -- C:\Documents and Settings\Sven Albrecht\Application Data\pcouffin.sys
    [1 C:\WINDOWS\System32\*.tmp files -> C:\WINDOWS\System32\*.tmp -> ]
    ========== Files - Modified Within 30 Days ==========
    [2012/01/15 09:29:06 | 000,000,438 | -H-- | M] () -- C:\WINDOWS\tasks\User_Feed_Synchronization-{3E754F6A-E80F-4D39-AE7B-CBD977D2FB14}.job
    [2012/01/15 09:25:33 | 000,002,048 | --S- | M] () -- C:\WINDOWS\bootstat.dat
    [2012/01/14 19:14:25 | 000,000,027 | ---- | M] () -- C:\WINDOWS\System32\drivers\etc\hosts
    [2012/01/14 16:25:39 | 000,000,327 | RHS- | M] () -- C:\boot.ini
    [2012/01/14 15:11:14 | 000,000,448 | ---- | M] () -- C:\WINDOWS\dellstat.ini
    [2012/01/14 13:59:48 | 000,000,202 | ---- | M] () -- C:\WINDOWS\NeroDigital.ini
    [2012/01/12 18:45:23 | 000,000,791 | ---- | M] () -- C:\Documents and Settings\Sven Albrecht\Application Data\Microsoft\Internet Explorer\Quick Launch\Shortcut to mbam.exe.lnk
    [2012/01/11 21:18:42 | 000,013,700 | ---- | M] () -- C:\WINDOWS\System32\wpa.dbl
    [2012/01/10 21:27:28 | 000,001,374 | ---- | M] () -- C:\WINDOWS\imsins.BAK
    [2012/01/10 21:08:12 | 000,481,532 | ---- | M] () -- C:\WINDOWS\System32\perfh009.dat
    [2012/01/10 21:08:12 | 000,079,862 | ---- | M] () -- C:\WINDOWS\System32\perfc009.dat
    [2012/01/07 21:32:53 | 000,046,592 | ---- | M] (BTOWS.com) -- C:\WINDOWS\System32\drivers\KSafeDISK.sys
    [2012/01/07 21:32:53 | 000,024,832 | ---- | M] (BTOWS.com) -- C:\WINDOWS\System32\drivers\BTOWSFF.sys
    [2012/01/07 21:32:52 | 000,041,856 | ---- | M] (BTOWS.com) -- C:\WINDOWS\System32\drivers\BTOWSVF.sys
    [2011/12/25 19:27:19 | 000,000,690 | ---- | M] () -- C:\Documents and Settings\Sven Albrecht\Application Data\Microsoft\Internet Explorer\Quick Launch\EXPENSES 2012.lnk
    [2011/12/20 18:16:18 | 000,025,600 | ---- | M] () -- C:\Documents and Settings\Sven Albrecht\Local Settings\Application Data\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
    [2011/12/20 12:41:57 | 000,000,135 | ---- | M] () -- C:\Documents and Settings\Sven Albrecht\default.pls
    [2012/01/14 16:25:39 | 000,000,211 | ---- | C] () -- C:\Boot.bak
    [2012/01/14 16:25:36 | 000,260,272 | RHS- | C] () -- C:\cmldr
    [2012/01/14 16:23:40 | 000,256,000 | ---- | C] () -- C:\WINDOWS\PEV.exe
    [2012/01/14 16:23:40 | 000,208,896 | ---- | C] () -- C:\WINDOWS\MBR.exe
    [2012/01/14 16:23:40 | 000,098,816 | ---- | C] () -- C:\WINDOWS\sed.exe
    [2012/01/14 16:23:40 | 000,080,412 | ---- | C] () -- C:\WINDOWS\grep.exe
    [2012/01/14 16:23:40 | 000,068,096 | ---- | C] () -- C:\WINDOWS\zip.exe
    [2012/01/12 18:45:23 | 000,000,791 | ---- | C] () -- C:\Documents and Settings\Sven Albrecht\Application Data\Microsoft\Internet Explorer\Quick Launch\Shortcut to mbam.exe.lnk
    [2012/01/10 21:00:25 | 000,001,374 | ---- | C] () -- C:\WINDOWS\imsins.BAK
    [2011/12/25 19:27:19 | 000,000,690 | ---- | C] () -- C:\Documents and Settings\Sven Albrecht\Application Data\Microsoft\Internet Explorer\Quick Launch\EXPENSES 2012.lnk
    [2011/07/28 18:57:38 | 000,025,600 | ---- | C] () -- C:\Documents and Settings\Sven Albrecht\Local Settings\Application Data\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
    [2011/07/26 16:35:06 | 000,082,289 | R--- | C] () -- C:\WINDOWS\System32\lvcoinst.ini
    [2011/07/11 19:19:51 | 000,002,208 | ---- | C] () -- C:\WINDOWS\System32\drivers\nxsIO32.sys
    [2011/05/14 14:45:38 | 000,000,000 | ---- | C] () -- C:\Documents and Settings\All Users\Application Data\Sampler Files
    [2011/05/13 17:34:03 | 000,000,000 | ---- | C] () -- C:\Documents and Settings\All Users\Application Data\Sci-Fi
    [2011/05/13 17:24:06 | 000,001,755 | ---- | C] () -- C:\Documents and Settings\All Users\Application Data\QTSBandwidthCache
    [2011/05/13 17:20:00 | 000,000,000 | -H-- | C] () -- C:\Documents and Settings\All Users\Application Data\PKP_DLdw.DAT
    [2011/05/13 17:20:00 | 000,000,000 | ---- | C] () -- C:\Documents and Settings\Sven Albrecht\Application Data\Screen Saver
    [2011/05/13 16:51:42 | 000,000,000 | -H-- | C] () -- C:\Documents and Settings\All Users\Application Data\PKP_DLdu.DAT
    [2011/05/13 16:51:42 | 000,000,000 | ---- | C] () -- C:\Documents and Settings\Sven Albrecht\Application Data\Sampler Instruments
    [2011/02/27 12:00:06 | 000,000,056 | -H-- | C] () -- C:\WINDOWS\System32\ezsidmv.dat
    [2010/11/08 19:15:54 | 000,233,472 | R--- | C] () -- C:\WINDOWS\System32\cmirmdrv.exe
    [2010/11/08 19:15:54 | 000,028,672 | R--- | C] () -- C:\WINDOWS\System32\cmirmdrv.dll
    [2010/11/07 21:56:47 | 000,181,536 | ---- | C] () -- C:\Documents and Settings\LocalService\Local Settings\Application Data\FontCache3.0.0.0.dat
    [2010/11/02 20:51:38 | 001,084,509 | ---- | C] () -- C:\Documents and Settings\LocalService\Local Settings\Application Data\WPFFontCache_v0400-S-1-5-21-606747145-1500820517-682003330-1004-0.dat
    [2010/11/02 20:51:37 | 000,244,270 | ---- | C] () -- C:\Documents and Settings\LocalService\Local Settings\Application Data\WPFFontCache_v0400-System.dat
    [2010/07/25 08:29:53 | 000,000,151 | ---- | C] () -- C:\WINDOWS\PhotoSnapViewer.INI
    [2010/05/01 11:15:45 | 000,000,020 | ---- | C] () -- C:\WINDOWS\SIERRA.INI
    [2010/04/18 15:05:09 | 000,000,000 | ---- | C] () -- C:\WINDOWS\invaders95.INI
    [2010/04/17 13:46:52 | 000,000,016 | ---- | C] () -- C:\WINDOWS\popcinfo.dat
    [2010/04/17 11:50:15 | 000,015,872 | ---- | C] () -- C:\WINDOWS\System32\D2Icons.Dll
    [2010/04/17 10:31:18 | 000,000,202 | ---- | C] () -- C:\WINDOWS\NeroDigital.ini
    [2010/04/17 08:13:16 | 000,000,067 | ---- | C] () -- C:\WINDOWS\prfile.ini
    [2010/04/17 07:44:23 | 000,007,887 | ---- | C] () -- C:\Documents and Settings\Sven Albrecht\Application Data\pcouffin.cat
    [2010/04/17 07:44:23 | 000,001,144 | ---- | C] () -- C:\Documents and Settings\Sven Albrecht\Application Data\pcouffin.inf
    [2010/04/17 06:59:39 | 000,338,944 | ---- | C] () -- C:\WINDOWS\System32\lffpx7.dll
    [2010/04/17 06:59:39 | 000,118,784 | ---- | C] () -- C:\WINDOWS\System32\lfkodak.dll
    [2010/04/16 20:23:30 | 000,000,748 | ---- | C] () -- C:\WINDOWS\ODBC.INI
    [2010/04/16 19:24:45 | 000,000,092 | ---- | C] () -- C:\WINDOWS\qwimp.ini
    [2010/04/16 19:22:54 | 000,000,165 | ---- | C] () -- C:\WINDOWS\QUICKEN.INI
    [2010/04/16 17:25:51 | 000,000,448 | ---- | C] () -- C:\WINDOWS\dellstat.ini
    [2010/04/16 15:40:21 | 000,032,768 | ---- | C] () -- C:\WINDOWS\System32\UnAudioNT.dll
    [2010/04/16 13:58:57 | 000,002,048 | --S- | C] () -- C:\WINDOWS\bootstat.dat
    [2010/04/16 13:50:54 | 000,021,640 | ---- | C] () -- C:\WINDOWS\System32\emptyregdb.dat
    [2010/04/16 06:41:10 | 000,004,161 | ---- | C] () -- C:\WINDOWS\ODBCINST.INI
    [2010/04/16 06:39:09 | 000,309,192 | ---- | C] () -- C:\WINDOWS\System32\FNTCACHE.DAT
    [2009/10/07 00:46:36 | 000,025,752 | ---- | C] () -- C:\WINDOWS\System32\drivers\LVPr2Mon.sys
    [2009/10/07 00:23:08 | 000,013,584 | ---- | C] () -- C:\WINDOWS\System32\drivers\iKeyLFT2.dll
    [2006/10/27 07:26:56 | 000,069,632 | ---- | C] () -- C:\WINDOWS\System32\vuins32.dll
    [2006/02/13 12:29:26 | 000,121,995 | ---- | C] () -- C:\WINDOWS\System32\atiicdxx.dat
    [2004/08/04 00:07:22 | 000,001,804 | ---- | C] () -- C:\WINDOWS\System32\dcache.bin
    [2004/08/02 13:20:40 | 000,004,569 | ---- | C] () -- C:\WINDOWS\System32\secupd.dat
    [2004/02/10 11:08:00 | 000,000,373 | ---- | C] () -- C:\WINDOWS\System32\dlbccoin.ini
    [2003/03/31 04:00:00 | 013,107,200 | ---- | C] () -- C:\WINDOWS\System32\oembios.bin
    [2003/03/31 04:00:00 | 000,673,088 | ---- | C] () -- C:\WINDOWS\System32\mlang.dat
    [2003/03/31 04:00:00 | 000,481,532 | ---- | C] () -- C:\WINDOWS\System32\perfh009.dat
    [2003/03/31 04:00:00 | 000,272,128 | ---- | C] () -- C:\WINDOWS\System32\perfi009.dat
    [2003/03/31 04:00:00 | 000,218,003 | ---- | C] () -- C:\WINDOWS\System32\dssec.dat
    [2003/03/31 04:00:00 | 000,079,862 | ---- | C] () -- C:\WINDOWS\System32\perfc009.dat
    [2003/03/31 04:00:00 | 000,046,258 | ---- | C] () -- C:\WINDOWS\System32\mib.bin
    [2003/03/31 04:00:00 | 000,028,626 | ---- | C] () -- C:\WINDOWS\System32\perfd009.dat
    [2003/03/31 04:00:00 | 000,004,461 | ---- | C] () -- C:\WINDOWS\System32\oembios.dat
    [2003/03/31 04:00:00 | 000,000,741 | ---- | C] () -- C:\WINDOWS\System32\noise.dat
    [2002/11/13 11:40:22 | 000,040,960 | ---- | C] () -- C:\WINDOWS\System32\dlbcvs.dll
    [2010/04/17 07:28:52 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Avery
    [2011/05/13 17:20:00 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\EnterNHelp
    [2011/11/24 16:39:12 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Freemake
    [2010/10/05 19:21:56 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Nitro PDF
    [2010/04/16 15:32:41 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\PC Drivers HeadQuarters
    [2011/05/13 17:20:00 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Ultima_T15
    [2011/05/14 14:28:55 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Sven Albrecht\Application Data\AnvSoft
    [2012/01/14 15:18:00 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Sven Albrecht\Application Data\Audacity
    [2010/04/18 07:55:35 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Sven Albrecht\Application Data\com.adobe.mauby.4875E02D9FB21EE389F73B8D1702B320485DF8CE.1
    [2010/10/05 19:20:54 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Sven Albrecht\Application Data\Downloaded Installations
    [2011/07/16 16:06:04 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Sven Albrecht\Application Data\EMCO
    [2011/07/05 07:17:41 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Sven Albrecht\Application Data\ieSpell
    [2011/08/13 08:51:58 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Sven Albrecht\Application Data\imeshbandmltbpi
    [2010/04/17 07:57:20 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Sven Albrecht\Application Data\ImgBurn
    [2011/07/26 16:36:33 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Sven Albrecht\Application Data\Leadertech
    [2011/08/14 09:34:44 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Sven Albrecht\Application Data\mediabarim
    [2011/05/13 17:27:28 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Sven Albrecht\Application Data\Nikon
    [2010/10/05 19:22:26 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Sven Albrecht\Application Data\Nitro PDF
    [2011/06/30 07:05:13 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Sven Albrecht\Application Data\Sony Online Entertainment
    [2010/04/17 07:44:34 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Sven Albrecht\Application Data\Vso
    [2012/01/15 09:29:06 | 000,000,438 | -H-- | M] () -- C:\WINDOWS\Tasks\User_Feed_Synchronization-{3E754F6A-E80F-4D39-AE7B-CBD977D2FB14}.job
    ========== Custom Scans ==========
    < %SYSTEMDRIVE%\*.* >
    [2010/04/16 13:55:36 | 000,000,000 | ---- | M] () -- C:\AUTOEXEC.BAT
    [2011/03/19 18:21:55 | 000,000,211 | ---- | M] () -- C:\Boot.bak
    [2004/08/03 23:00:00 | 000,260,272 | RHS- | M] () -- C:\cmldr
    [2010/04/16 13:55:36 | 000,000,000 | ---- | M] () -- C:\CONFIG.SYS
    [2010/04/16 13:55:36 | 000,000,000 | RHS- | M] () -- C:\IO.SYS
    [2010/04/16 13:55:36 | 000,000,000 | RHS- | M] () -- C:\MSDOS.SYS
    [2004/08/03 21:38:34 | 000,047,564 | RHS- | M] () -- C:\NTDETECT.COM
    [2010/04/16 16:29:43 | 000,250,048 | RHS- | M] () -- C:\ntldr
    [2012/01/15 09:25:24 | 1610,612,736 | -HS- | M] () -- C:\pagefile.sys
    < %systemroot%\Fonts\*.com >
    [2006/04/18 14:39:28 | 000,026,040 | ---- | M] () -- C:\WINDOWS\Fonts\GlobalMonospace.CompositeFont
    [2006/06/29 13:53:56 | 000,026,489 | ---- | M] () -- C:\WINDOWS\Fonts\GlobalSansSerif.CompositeFont
    [2006/04/18 14:39:28 | 000,029,779 | ---- | M] () -- C:\WINDOWS\Fonts\GlobalSerif.CompositeFont
    [2006/06/29 13:58:52 | 000,030,808 | ---- | M] () -- C:\WINDOWS\Fonts\GlobalUserInterface.CompositeFont
    < %systemroot%\Fonts\*.dll >
    < %systemroot%\Fonts\*.ini >
    [2010/04/16 13:55:03 | 000,000,067 | -HS- | M] () -- C:\WINDOWS\Fonts\desktop.ini
    < %systemroot%\Fonts\*.ini2 >
    < %systemroot%\Fonts\*.exe >
    < %systemroot%\system32\spool\prtprocs\w32x86\*.* >
    [2008/07/06 04:06:10 | 000,089,088 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\system32\spool\prtprocs\w32x86\filterpipelineprintproc.dll
    [2008/07/06 02:50:03 | 000,597,504 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\system32\spool\prtprocs\w32x86\printfilterpipelinesvc.exe
    < %systemroot%\REPAIR\*.bak1 >
    < %systemroot%\REPAIR\*.ini >
    < %systemroot%\system32\*.jpg >
    < %systemroot%\*.jpg >
    < %systemroot%\*.png >
    < %systemroot%\*.scr >
    < %systemroot%\*._sy >
    < %APPDATA%\Adobe\Update\*.* >
    < %ALLUSERSPROFILE%\Favorites\*.* >
    < %APPDATA%\Microsoft\*.* >
    < %PROGRAMFILES%\*.* >
    < %APPDATA%\Update\*.* >
    < %systemroot%\*. /mp /s >
    < %systemroot%\System32\config\*.sav >
    [2010/04/16 06:37:58 | 000,094,208 | ---- | M] () -- C:\WINDOWS\System32\config\default.sav
    [2010/04/16 06:37:58 | 000,634,880 | ---- | M] () -- C:\WINDOWS\System32\config\software.sav
    [2010/04/16 06:37:58 | 000,884,736 | ---- | M] () -- C:\WINDOWS\System32\config\system.sav
    < %PROGRAMFILES%\bak. /s >
    < %systemroot%\system32\bak. /s >
    < %ALLUSERSPROFILE%\Start Menu\*.lnk /x >
    [2010/04/16 16:35:17 | 000,000,272 | -HS- | M] () -- C:\Documents and Settings\All Users\Start Menu\desktop.ini
    < %systemroot%\system32\config\systemprofile\*.dat /x >
    < %systemroot%\*.config >
    < %systemroot%\system32\*.db >
    < %APPDATA%\Microsoft\Internet Explorer\Quick Launch\*.lnk /x >
    [2010/04/16 14:02:48 | 000,000,119 | -HS- | M] () -- C:\Documents and Settings\Sven Albrecht\Application Data\Microsoft\Internet Explorer\Quick Launch\desktop.ini
    < %USERPROFILE%\Desktop\*.exe >
    < %PROGRAMFILES%\Common Files\*.* >
    < %systemroot%\*.src >
    < %systemroot%\install\*.* >
    < %systemroot%\system32\DLL\*.* >
    < %systemroot%\system32\HelpFiles\*.* >
    < %systemroot%\system32\rundll\*.* >
    < %systemroot%\winn32\*.* >
    < %systemroot%\Java\*.* >
    < %systemroot%\system32\test\*.* >
    < %systemroot%\system32\Rundll32\*.* >
    < %systemroot%\AppPatch\Custom\*.* >
    < %APPDATA%\Roaming\Microsoft\Windows\Recent\*.lnk /x >
    < %PROGRAMFILES%\PC-Doctor\Downloads\*.* >
    < %PROGRAMFILES%\Internet Explorer\*.tmp >
    < %PROGRAMFILES%\Internet Explorer\*.dat >
    < %USERPROFILE%\My Documents\*.exe >
    < %USERPROFILE%\*.exe >
    < %systemroot%\ADDINS\*.* >
    < %systemroot%\assembly\*.bak2 >
    < %systemroot%\Config\*.* >
    < %systemroot%\REPAIR\*.bak2 >
    < %systemroot%\SECURITY\Database\*.sdb /x >
    < %systemroot%\SYSTEM\*.bak2 >
    < %systemroot%\Web\*.bak2 >
    < %systemroot%\Driver Cache\*.* >
    < %PROGRAMFILES%\Mozilla Firefox\0*.exe >
    < %ProgramFiles%\Microsoft Common\*.* >
    < %ProgramFiles%\TinyProxy. >
    < %USERPROFILE%\Favorites\*.url /x >
    [2010/04/16 14:02:48 | 000,000,122 | -HS- | M] () -- C:\Documents and Settings\Sven Albrecht\Favorites\Desktop.ini
    < %systemroot%\system32\*.bk >
    < %systemroot%\*.te >
    < %systemroot%\system32\system32\*.* >
    < %ALLUSERSPROFILE%\*.dat /x >
    < %systemroot%\system32\drivers\*.rmv >
    < dir /b "%systemroot%\system32\*.exe" | find /i " " /c >
    < dir /b "%systemroot%\*.exe" | find /i " " /c >
    < %PROGRAMFILES%\Microsoft\*.* >
    < %systemroot%\System32\Wbem\proquota.exe >
    < %PROGRAMFILES%\Mozilla Firefox\*.dat >
    < %USERPROFILE%\Cookies\*.txt /x >
    [2012/01/15 09:29:17 | 000,720,896 | ---- | M] () -- C:\Documents and Settings\Sven Albrecht\Cookies\index.dat
    < %SystemRoot%\system32\fonts\*.* >
    < %systemroot%\system32\winlog\*.* >
    < %systemroot%\system32\Language\*.* >
    < %systemroot%\system32\Settings\*.* >
    < %systemroot%\system32\*.quo >
    < %SYSTEMROOT%\AppPatch\*.exe >
    < %SYSTEMROOT%\inf\*.exe >
    [2007/06/26 21:10:26 | 000,317,440 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\inf\unregmp2.exe
    < %SYSTEMROOT%\Installer\*.exe >
    < %systemroot%\system32\config\*.bak2 >
    < %systemroot%\system32\Computers\*.* >
    < %SystemRoot%\system32\Sound\*.* >
    < %SystemRoot%\system32\SpecialImg\*.* >
    < %SystemRoot%\system32\code\*.* >
    < %SystemRoot%\system32\draft\*.* >
    < %SystemRoot%\system32\MSSSys\*.* >
    < %ProgramFiles%\Javascript\*.* >
    < %systemroot%\pchealth\helpctr\System\*.exe /s >
    < %systemroot%\Web\*.exe >
    < %systemroot%\system32\msn\*.* >
    < %systemroot%\system32\*.tro >
    < %AppData%\Microsoft\Installer\msupdates\*.* >
    < %ProgramFiles%\Messenger\*.* >
    [2008/04/13 16:11:51 | 000,033,792 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Messenger\custsat.dll
    [2003/03/31 04:00:00 | 000,004,821 | ---- | M] () -- C:\Program Files\Messenger\logowin.gif
    [2004/08/04 00:06:34 | 000,007,047 | ---- | M] () -- C:\Program Files\Messenger\lvback.gif
    [2008/05/02 06:01:49 | 000,083,968 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Messenger\msgsc.dll
    [2008/04/13 09:30:28 | 000,180,224 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Messenger\msgslang.dll
    [2008/04/13 16:12:28 | 001,695,232 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Messenger\msmsgs.exe
    [2003/03/31 04:00:00 | 000,002,882 | ---- | M] () -- C:\Program Files\Messenger\newalert.wav
    [2003/03/31 04:00:00 | 000,006,156 | ---- | M] () -- C:\Program Files\Messenger\newemail.wav
    [2003/03/31 04:00:00 | 000,006,160 | ---- | M] () -- C:\Program Files\Messenger\online.wav
    [2004/08/04 00:06:36 | 000,004,454 | ---- | M] () -- C:\Program Files\Messenger\type.wav
    [2004/08/04 00:06:36 | 000,115,981 | ---- | M] () -- C:\Program Files\Messenger\xpmsgr.chm
    < %systemroot%\system32\systhem32\*.* >
    < %systemroot%\system\*.exe >
    [2003/10/15 00:26:44 | 001,454,080 | R--- | M] (C-Media Electronics Inc.) -- C:\WINDOWS\system\SmWizard.exe
    < HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate\AU >
    < HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\ Auto Update\Results\Install|LastSuccessTime /rs >
    < End of report >
  15. 2012/01/15
    SVEN
    SVEN Well-Known Member Thread Starter
    OTL Extras logfile created on: 1/15/2012 9:31:38 AM - Run 1
    ========== Extra Registry (SafeList) ==========
    ========== File Associations ==========
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\<extension>]
    .cpl [@ = cplfile] -- rundll32.exe shell32.dll,Control_RunDLL "%1 ",%*
    ========== Shell Spawning ==========
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\<key>\shell\[command]\command]
    batfile [open] -- "%1" %*
    cmdfile [open] -- "%1" %*
    cplfile [cplopen] -- rundll32.exe shell32.dll,Control_RunDLL "%1 ",%*
    piffile [open] -- "%1" %*
    regfile [merge] -- Reg Error: Key error.
    scrfile [config] -- "%1 "
    scrfile [install] -- rundll32.exe desk.cpl,InstallScreenSaver %l
    scrfile [open] -- "%1" /S
    txtfile [edit] -- Reg Error: Key error.
    Unknown [openas] -- %SystemRoot%\system32\rundll32.exe %SystemRoot%\system32\shell32.dll,OpenAs_RunDLL %1
    Directory [find] -- %SystemRoot%\Explorer.exe (Microsoft Corporation)
    Folder [open] -- %SystemRoot%\Explorer.exe /idlist,%I,%L (Microsoft Corporation)
    Folder [explore] -- %SystemRoot%\Explorer.exe /e,/idlist,%I,%L (Microsoft Corporation)
    Drive [find] -- %SystemRoot%\Explorer.exe (Microsoft Corporation)
    ========== Security Center Settings ==========
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center]
    "FirstRunDisabled" = 1
    "UpdatesDisableNotify" = 0
    "AntiVirusDisableNotify" = 0
    "FirewallDisableNotify" = 0
    "AntiVirusOverride" = 0
    "FirewallOverride" = 0
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\AhnlabAntiVirus]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\ComputerAssociatesAntiVirus]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\KasperskyAntiVirus]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\McAfeeAntiVirus]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\McAfeeFirewall]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\PandaAntiVirus]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\PandaFirewall]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\SophosAntiVirus]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\SymantecAntiVirus]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\SymantecFirewall]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\TinyFirewall]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\TrendAntiVirus]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\TrendFirewall]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\ZoneLabsFirewall]
    ========== System Restore Settings ==========
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\SystemRestore]
    "DisableSR" = 0
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Sr]
    "Start" = 0
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SrService]
    "Start" = 2
    ========== Firewall Settings ==========
    [HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\WindowsFirewall]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\WindowsFirewall\DomainProfile]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\WindowsFirewall\StandardProfile]
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\DomainProfile]
    "EnableFirewall" = 1
    "DisableNotifications" = 0
    "DoNotAllowExceptions" = 0
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\DomainProfile\GloballyOpenPorts\List]
    "139:TCP" = 139:TCP:*:Enabled:mad:xpsp2res.dll,-22004
    "445:TCP" = 445:TCP:*:Enabled:mad:xpsp2res.dll,-22005
    "137:UDP" = 137:UDP:*:Enabled:mad:xpsp2res.dll,-22001
    "138:UDP" = 138:UDP:*:Enabled:mad:xpsp2res.dll,-22002
    "1900:UDP" = 1900:UDP:LocalSubNet:Enabled:mad:xpsp2res.dll,-22007
    "2869:TCP" = 2869:TCP:LocalSubNet:Enabled:mad:xpsp2res.dll,-22008
    "10243:TCP" = 10243:TCP:LocalSubNet:Enabled:Windows Media Player Network Sharing Service
    "10280:UDP" = 10280:UDP:LocalSubNet:Enabled:Windows Media Player Network Sharing Service
    "10281:UDP" = 10281:UDP:LocalSubNet:Enabled:Windows Media Player Network Sharing Service
    "10282:UDP" = 10282:UDP:LocalSubNet:Enabled:Windows Media Player Network Sharing Service
    "10283:UDP" = 10283:UDP:LocalSubNet:Enabled:Windows Media Player Network Sharing Service
    "10284:UDP" = 10284:UDP:LocalSubNet:Enabled:Windows Media Player Network Sharing Service
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\StandardProfile]
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\StandardProfile\GloballyOpenPorts\List]
    "139:TCP" = 139:TCP:LocalSubNet:Enabled:mad:xpsp2res.dll,-22004
    "445:TCP" = 445:TCP:LocalSubNet:Enabled:mad:xpsp2res.dll,-22005
    "137:UDP" = 137:UDP:LocalSubNet:Enabled:mad:xpsp2res.dll,-22001
    "138:UDP" = 138:UDP:LocalSubNet:Enabled:mad:xpsp2res.dll,-22002
    "5985:TCP" = 5985:TCP:*:Disabled:Windows Remote Management
    ========== Authorized Applications List ==========
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\DomainProfile\AuthorizedApplications\List]
    "C:\Program Files\iMesh Applications\iMesh\iMesh.exe" = C:\Program Files\iMesh Applications\iMesh\iMesh.exe:*:Enabled:iMesh
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\StandardProfile\AuthorizedApplications\List]
    "C:\WINDOWS\system32\mmc.exe" = C:\WINDOWS\system32\mmc.exe:*:Enabled:Microsoft Management Console -- (Microsoft Corporation)
    "C:\Documents and Settings\Sven Albrecht\My Documents\Downloads\Ghost\Ghost32.Exe" = C:\Documents and Settings\Sven Albrecht\My Documents\Downloads\Ghost\Ghost32.Exe:*:Enabled:Ghost32 Network Access -- (Symantec Corporation)
    "C:\Program Files\Ahead\Nero ShowTime\ShowTime.exe" = C:\Program Files\Ahead\Nero ShowTime\ShowTime.exe:*:Enabled:Nero ShowTime -- (Ahead software AG)
    "C:\Program Files\Logitech\Vid HD\Vid.exe" = C:\Program Files\Logitech\Vid HD\Vid.exe:*:Enabled:Logitech Vid HD -- (Logitech Inc.)
    ========== HKEY_LOCAL_MACHINE Uninstall List ==========
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall]
    "{05BFB060-4F22-4710-B0A2-2801A1B606C5}" = Microsoft Antimalware
    "{196BB40D-1578-3D01-B289-BEFC77A11A1E}" = Microsoft Visual C++ 2010 x86 Redistributable - 10.0.30319
    "{1F1C2DFC-2D24-3E06-BCB8-725134ADF989}" = Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.4148
    "{237CD223-1B9D-47E8-A76C-E478B83CCEA2}" = File Uploader
    "{26A24AE4-039D-4CA4-87B4-2F83216020FF}" = Java(TM) 6 Update 29
    "{350C97B0-3D7C-4EE8-BAA9-00BCB3D54227}" = WebFldrs XP
    "{3B0F52AC-EF5C-4831-B221-06C782E41280}" = Quicken 2008
    "{3C3901C5-3455-3E0A-A214-0B093A5070A6}" = Microsoft .NET Framework 4 Client Profile
    "{4A03706F-666A-4037-7777-5F2748764D10}" = Java Auto Updater
    "{54B6DC7D-8C5B-4DFB-BC15-C010A3326B2B}" = Microsoft Security Client
    "{710f4c1c-cc18-4c49-8cbf-51240c89a1a2}" = Microsoft Visual C++ 2005 Redistributable
    "{76EFFC7C-17A6-479D-9E47-8E658C1695AE}" = Windows Backup Utility
    "{87441A59-5E64-4096-A170-14EFE67200C3}" = Picture Control Utility
    "{89F4137D-6C26-4A84-BDB8-2E5A4BB71E00}" = Microsoft Silverlight
    "{90120000-0020-0409-0000-0000000FF1CE}" = Compatibility Pack for the 2007 Office system
    "{90280409-6000-11D3-8CFE-0050048383C9}" = Microsoft Office XP Professional with FrontPage
    "{911B0407-6000-11D3-8CFE-0050048383C9}" = Microsoft Word 2002
    "{95120000-00B9-0409-0000-0000000FF1CE}" = Microsoft Application Error Reporting
    "{9BE518E6-ECC6-35A9-88E4-87755C07200F}" = Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.6161
    "{A2BCA9F1-566C-4805-97D1-7FDC93386723}" = Adobe AIR
    "{A3051CD0-2F64-3813-A88D-B8DCCDE8F8C7}" = Microsoft .NET Framework 3.0 Service Pack 2
    "{AC76BA86-7AD7-1033-7B44-A93000000001}" = Adobe Reader 9.3
    "{B6CF2967-C81E-40C0-9815-C05774FEF120}" = Skype Toolbars
    "{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}" = Microsoft .NET Framework 2.0 Service Pack 2
    "{C27BC2A2-30DD-4014-B22E-63EB0DB572F9}" = Logitech Webcam Software
    "{CB2F7EDD-9D1F-43C1-90FC-4F52EAE172A1}" = Microsoft .NET Framework 1.1
    "{CE2CDD62-0124-36CA-84D3-9F4DCF5C5BD9}" = Microsoft .NET Framework 3.5 SP1
    "{D2FCC1AE-6311-47C5-8130-C6C66D77DD71}" = Nikon Message Center
    "{D6F879CC-59D6-4D4B-AE9B-D761E48D25ED}" = Skype™ 5.3
    "{DBCC73BA-C69A-4BF5-B4BF-F07501EE7039}" = AnswerWorks 5.0 English Runtime
    "{EDF1085A-73FF-4B3B-8726-2A403D400E48}" = DesignPro 5.0 Media Edition
    "{F8131A35-47FD-27AD-116D-0E79AF5DE5EE}" = Acrobat.com
    "Adobe AIR" = Adobe AIR
    "Adobe Flash Player ActiveX" = Adobe Flash Player 11 ActiveX
    "Any Video Converter_is1" = Any Video Converter 3.2.3
    "asterisk key" = Asterisk Key 10.0
    "ATI Display Driver" = ATI Display Driver
    "Audacity 1.3 Beta (Unicode)_is1" = Audacity 1.3.13 (Unicode)
    "Bejeweled 2 Deluxe_is1" = Bejeweled 2 Deluxe
    "Click'N Design 3D for AfterBurner(tm)" = Click'N Design 3D for AfterBurner(tm)
    "C-Media Audio Driver" = C-Media WDM Audio Driver
    "CNXT_MODEM_PCI_VEN_14F1&DEV_2F00&SUBSYS_8D8B155D" = Conexant SoftK56 Modem(M)
    "com.adobe.mauby.4875E02D9FB21EE389F73B8D1702B320485DF8CE.1" = Acrobat.com
    "CompuPic" = CompuPic
    "Dell Photo Printer 720" = Dell Photo Printer 720
    "doPDF 6 printer_is1" = doPDF 6.2 printer
    "DVD Decrypter" = DVD Decrypter (Remove Only)
    "DVD Shrink_is1" = DVD Shrink 3.2
    "DVDFab 6_is1" = DVDFab 6.0.2.0 (June 24, 2009)
    "DVDFab Decrypter_is1" = DVDFab Decrypter 3.0.8.0
    "DVDFab Passkey 8_is1" = DVDFab Passkey 8.0.2.6 (17/03/2011)
    "ESET Online Scanner" = ESET Online Scanner v3
    "Freemake Video Converter_is1" = Freemake Video Converter version 3.0.1
    "ie8" = Windows Internet Explorer 8
    "ieSpell" = ieSpell
    "iMesh 1 MediaBar" = MediaBar
    "ImgBurn" = ImgBurn (Remove Only)
    "InstallShield_{EDF1085A-73FF-4B3B-8726-2A403D400E48}" = DesignPro 5.0 Media Edition
    "Invaders95" = Invaders95
    "KeyFinder_is1" = Magical Jelly Bean KeyFinder
    "LAME for Audacity_is1" = LAME v3.98.3 for Audacity
    "Logitech Vid" = Logitech Vid HD
    "lvdrivers_12.10" = Logitech Webcam Software Driver Package
    "Magic ISO Maker v5.5 (build 0281)" = Magic ISO Maker v5.5 (build 0281)
    "Malwarebytes' Anti-Malware_is1" = Malwarebytes Anti-Malware version 1.60.0.1800
    "Microsoft .NET Framework 1.1 (1033)" = Microsoft .NET Framework 1.1
    "Microsoft .NET Framework 3.5 SP1" = Microsoft .NET Framework 3.5 SP1
    "Microsoft .NET Framework 4 Client Profile" = Microsoft .NET Framework 4 Client Profile
    "Microsoft Security Client" = Microsoft Security Essentials
    "MSCompPackV1" = Microsoft Compression Client Pack 1.0 for Windows XP
    "Nero - Burning Rom!UninstallKey" = Nero 6 Ultra Edition
    "NeroVision!UninstallKey" = NeroVision Express 3
    "NMIX!UninstallKey" = NeroMIX
    "NMPUninstallKey" = Nero Media Player
    "Photocopier_is1" = Photocopier Version 2.26
    "PokerStars.net" = PokerStars.net
    "PrintFile" = PrintFile
    "PSP Video 9" = PSP Video 9 4.04
    "SimpleScreenshot" = SimpleScreenshot 1.20
    "Tetrus" = Tetrus (remove)
    "ToolwizCareFree" = Toolwiz Care
    "VIA Audio Driver Setup Program" = VIA Audio Driver Setup Program
    "VN_VUIns_Rhine_VIA" = VIA Rhine-Family Fast-Ethernet Adapter
    "WhoCrashed_is1" = WhoCrashed 3.03
    "Windows Media Format Runtime" = Windows Media Format 11 runtime
    "Windows Media Player" = Windows Media Player 11
    "Windows XP Service Pack" = Windows XP Service Pack 3
    "WinUHA_is1" = WinUHA 2.0 RC1 (2005.02.27)
    "WinX Free DVD To PSP Ripper_is1" = WinX Free DVD To PSP Ripper 3.0
    "WMFDist11" = Windows Media Format 11 runtime
    "wmp11" = Windows Media Player 11
    "Wudf01000" = Microsoft User-Mode Driver Framework Feature Pack 1.0
    ========== Last 10 Event Log Errors ==========
    [ Application Events ]
    Error - 12/22/2011 6:37:29 PM | Computer Name = SVEN-ALBRECHT | Source = Application Hang | ID = 1002
    Description = Hanging application iexplore.exe, version 8.0.6001.18702, hang module
    hungapp, version 0.0.0.0, hang address 0x00000000.
    Error - 12/24/2011 6:38:11 PM | Computer Name = SVEN-ALBRECHT | Source = Application Hang | ID = 1002
    Description = Hanging application FURY3.EXE, version 1.1.0.1, hang module hungapp,
    Error - 12/24/2011 6:38:17 PM | Computer Name = SVEN-ALBRECHT | Source = Application Hang | ID = 1001
    Description = Fault bucket 05746912.
    Error - 12/25/2011 12:18:18 AM | Computer Name = SVEN-ALBRECHT | Source = .NET Runtime 4.0 Error Reporting | ID = 1000
    Description = Faulting application freemakevc.exe, version 3.0.1.0, stamp 4ef07b72,
    faulting module avcodec-52.dll, version 0.0.0.0, stamp 4d3e7883, debug? 0, fault
    address 0x006abcf7.
    Error - 12/25/2011 12:23:20 AM | Computer Name = SVEN-ALBRECHT | Source = .NET Runtime | ID = 1026
    Description = Application: FreemakeVC.exe Framework Version: v4.0.30319 Description:
    The process was terminated due to an unhandled exception. Exception Info: exception
    code c0000005, exception address 6B3EBCF7
    Error - 12/31/2011 1:46:29 PM | Computer Name = SVEN-ALBRECHT | Source = Application Hang | ID = 1002
    Description = Hanging application qw.exe, version 17.1.9.2, hang module hungapp,
    Error - 1/8/2012 12:35:51 AM | Computer Name = SVEN-ALBRECHT | Source = NTBackup | ID = 8001
    Description = End Backup of 'C:' 'Warnings or errors were encountered.' Verify:
    On Mode: Replace Type: Normal Consult the backup report for more details.
    Error - 1/8/2012 12:35:53 AM | Computer Name = SVEN-ALBRECHT | Source = NTBackup | ID = 8019
    Description = End Operation: Warnings or errors were encountered. Consult the backup
    Error - 1/11/2012 1:26:12 AM | Computer Name = SVEN-ALBRECHT | Source = .NET Runtime Optimization Service | ID = 1103
    Description = .NET Runtime Optimization Service (clr_optimization_v2.0.50727_32)
    - Tried to start a service that wasn't the latest version of CLR Optimization service.
    Will shutdown
    [ System Events ]
    Error - 1/14/2012 11:16:14 PM | Computer Name = SVEN-ALBRECHT | Source = WMPNetworkSvc | ID = 866312
    Description = A new media server was not initialized because WMCreateDeviceRegistration()
    encountered error '0xc00d2711'. The Windows Media DRM components on your computer
    might be corrupted. Verify that protected files play correctly in Windows Media
    Player, and then restart the WMPNetworkSvc service.
    Error - 1/15/2012 12:54:56 AM | Computer Name = SVEN-ALBRECHT | Source = Service Control Manager | ID = 7009
    Description = Timeout (30000 milliseconds) waiting for the Freemake Improver service
    to connect.
    Error - 1/15/2012 12:54:56 AM | Computer Name = SVEN-ALBRECHT | Source = Service Control Manager | ID = 7000
    Description = The Freemake Improver service failed to start due to the following
    error: %%1053
    Error - 1/15/2012 12:55:07 AM | Computer Name = SVEN-ALBRECHT | Source = WMPNetworkSvc | ID = 866312
    Error - 1/15/2012 1:26:55 PM | Computer Name = SVEN-ALBRECHT | Source = Service Control Manager | ID = 7009
    to connect.
    Error - 1/15/2012 1:26:55 PM | Computer Name = SVEN-ALBRECHT | Source = Service Control Manager | ID = 7000
    error: %%1053
    Error - 1/15/2012 1:27:07 PM | Computer Name = SVEN-ALBRECHT | Source = WMPNetworkSvc | ID = 866312
    < End of report >
  16. 2012/01/15
    Run OTL
      :OTL
      :Commands
      [purity]
      [emptytemp]
      [emptyjava]
      [emptyflash]
      [Reboot]
    1. Update your Java version here: http://www.java.com/en/download/installed.jsp
    2. Now, we need to remove old Java version and its remnants...
    Download JavaRa to your desktop and unzip it to its own folder
    • Accept any prompts.
    • Do NOT post JavaRa log.
    Last scans...
    1. Download Security Check from HERE, and save it to your Desktop.
    • Double-click SecurityCheck.exe
    • Follow the onscreen instructions inside of the black box.
    • A Notepad document should open automatically called checkup.txt; please post the contents of that document.
      NOTE SecurityCheck may produce some false warning(s), so leave the results reading to me.
    2. Please download Farbar Service Scanner and run it on the computer with the issue.
    • Make sure the following options are checked:
      • Internet Services
      • Windows Firewall
      • System Restore
      • Security Center
      • Windows Update
    • Press "Scan ".
    • It will create a log (FSS.txt) in the same directory the tool is run.
    • Please copy and paste the log to your reply.
    3. Download Temp File Cleaner (TFC)
    • Double click on TFC.exe to run the program.
    • Click on Start button to begin cleaning process.
    • TFC will close all running programs, and it may ask you to restart computer.
    4. Please run a free online scan with the ESET Online Scanner
    • Disable your antivirus program
    • Tick the box next to YES, I accept the Terms of Use
    • Click Start
    • Accept any security warnings from your browser.
    • Check Scan archives
    • Click Start
    • ESET will then download updates for itself, install itself, and begin scanning your computer. Please be patient as this can take some time.
    • When the scan completes, click on List of found threats
    • Click on Export to text file , and save the file to your desktop using a unique name, such as ESETScan. Include the contents of this report in your next reply.
    • NOTE. If Eset won't find any threats, it won't produce any log.
  17. 2012/01/15
    SVEN
    All processes killed
    ========== OTL ==========
    Registry key HKEY_USERS\S-1-5-19\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\ZoneMap\Domains\clonewarsadventures.com\ deleted successfully.
    Registry key HKEY_USERS\S-1-5-19\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\ZoneMap\Domains\freerealms.com\ deleted successfully.
    Registry key HKEY_USERS\S-1-5-19\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\ZoneMap\Domains\soe.com\ deleted successfully.
    Registry key HKEY_USERS\S-1-5-19\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\ZoneMap\Domains\sony.com\ deleted successfully.
    Registry key HKEY_USERS\S-1-5-21-606747145-1500820517-682003330-1004\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\ZoneMap\Domains\clonewarsadventures.com\ deleted successfully.
    Registry key HKEY_USERS\S-1-5-21-606747145-1500820517-682003330-1004\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\ZoneMap\Domains\freerealms.com\ deleted successfully.
    Registry key HKEY_USERS\S-1-5-21-606747145-1500820517-682003330-1004\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\ZoneMap\Domains\soe.com\ deleted successfully.
    Registry key HKEY_USERS\S-1-5-21-606747145-1500820517-682003330-1004\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\ZoneMap\Domains\sony.com\ deleted successfully.
    Starting removal of ActiveX control {E2883E8F-472F-4FB0-9522-AC9BF37916A7}
    C:\WINDOWS\Downloaded Program Files\gp.inf not found.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{E2883E8F-472F-4FB0-9522-AC9BF37916A7}\ deleted successfully.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{E2883E8F-472F-4FB0-9522-AC9BF37916A7}\ not found.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Active Setup\Installed Components\{E2883E8F-472F-4FB0-9522-AC9BF37916A7}\ not found.
    [EMPTYTEMP]
    User: Administrator
    ->Flash cache emptied: 41620 bytes
    User: All Users
    User: Default User
    ->Temporary Internet Files folder emptied: 67 bytes
    User: LocalService
    ->Temp folder emptied: 66016 bytes
    ->Temporary Internet Files folder emptied: 32902 bytes
    User: NetworkService
    ->Temp folder emptied: 7400 bytes
    User: Sven Albrecht
    ->Temp folder emptied: 21315679 bytes
    ->Temporary Internet Files folder emptied: 34106659 bytes
    ->Java cache emptied: 14005408 bytes
    ->Flash cache emptied: 4973 bytes
    %systemroot%\System32 .tmp files removed: 2577 bytes
    Windows Temp folder emptied: 114902 bytes
    %systemroot%\system32\config\systemprofile\Local Settings\Temporary Internet Files folder emptied: 33170 bytes
    RecycleBin emptied: 0 bytes
    Total Files Cleaned = 67.00 mb
    [EMPTYJAVA]
    User: Administrator
    User: All Users
    User: Default User
    User: LocalService
    User: Sven Albrecht
    ->Java cache emptied: 0 bytes
    Total Java Files Cleaned = 0.00 mb
    [EMPTYFLASH]
    User: Administrator
    User: All Users
    User: Default User
    User: LocalService
    User: Sven Albrecht
    OTL by OldTimer - Version 3.2.31.0 log created on 01152012_112920
    File\Folder C:\Documents and Settings\Sven Albrecht\Local Settings\Temp\Perflib_Perfdata_94.dat not found!
    File\Folder C:\WINDOWS\temp\logishrd\LVPrcInj01.dll not found!
  18. 2012/01/15
    SVEN
    Results of screen317's Security Check version 0.99.24
    Windows XP Service Pack 3 x86
    Internet Explorer 8
    Antivirus/Firewall Check:
    Windows Firewall Enabled!
    Anti-malware/Other Utilities Check:
    Java(TM) 6 Update 30
    Process Check:
    objlist.exe by Laurent
    Windows Defender MSMpEng.exe
    Microsoft Security Essentials msseces.exe
    Microsoft Security Client Antimalware MsMpEng.exe
    ``````````End of Log````````````
  19. 2012/01/15
    SVEN
    Ran by Sven Albrecht (administrator) on 15-01-2012 at 11:43:19
    Microsoft Windows XP Home Edition Service Pack 3 (X86)
    Boot Mode: Normal
    Internet Services:
    Connection Status:
    Localhost is accessible.
    LAN connected.
    Google IP is accessible.
    Yahoo IP is accessible.
    Windows Firewall:
    Firewall Disabled Policy:
    System Restore:
    System Restore Disabled Policy:
    Security Center:
    Windows Update:
    File Check:
    C:\WINDOWS\system32\dhcpcsvc.dll => MD5 is legit
    C:\WINDOWS\system32\Drivers\afd.sys => MD5 is legit
    C:\WINDOWS\system32\Drivers\netbt.sys => MD5 is legit
    C:\WINDOWS\system32\Drivers\tcpip.sys => MD5 is legit
    C:\WINDOWS\system32\Drivers\ipsec.sys => MD5 is legit
    C:\WINDOWS\system32\dnsrslvr.dll => MD5 is legit
    C:\WINDOWS\system32\ipnathlp.dll => MD5 is legit
    C:\WINDOWS\system32\netman.dll => MD5 is legit
    C:\WINDOWS\system32\wbem\WMIsvc.dll => MD5 is legit
    C:\WINDOWS\system32\srsvc.dll => MD5 is legit
    C:\WINDOWS\system32\Drivers\sr.sys => MD5 is legit
    C:\WINDOWS\system32\wscsvc.dll => MD5 is legit
    C:\WINDOWS\system32\wuauserv.dll => MD5 is legit
    C:\WINDOWS\system32\qmgr.dll => MD5 is legit
    C:\WINDOWS\system32\es.dll => MD5 is legit
    C:\WINDOWS\system32\cryptsvc.dll => MD5 is legit
    C:\WINDOWS\system32\svchost.exe => MD5 is legit
    C:\WINDOWS\system32\rpcss.dll => MD5 is legit
    C:\WINDOWS\system32\services.exe => MD5 is legit
    Extra List:
    Gpc(3) IPSec(5) NetBT(6) PSched(7) Tcpip(4)
    0x0700000005000000010000000200000003000000040000000600000007000000
    IpSec Tag value is correct.
    **** End of log ****
  20. 2012/01/15
    SVEN
    Hi Broni
    I am running ESET now. After a few seconds I got a pop up:
    Jusched.exe "“ Application error
    The instruction at "0x7e4287f1" referenced at" 0x00000000â€,
    The memory could not be "writtenâ€
    Click OK to terminate the program
    Click cancel to debug the program
    I did nothing and just let it sit there. ESET kept on going.
    Does this have anything to do with my BSOD?
    Sven
  21. 2012/01/15
