system 32
Discussion in 'Windows XP' started by melanie, 2006/01/30.
  1. 2006/01/30
    melanie
    melanie Inactive Thread Starter
    When I first log on to the internet I have a system 32 screen come up. Is this
    something to do with windows? If so how can i fix it?
    Thanks Melanie
  2. 2006/01/30
    Zander
    Zander Geek Member Alumni
    Do you mean that the system32 folder opens in your web browser? If so, check to see if it's set to be your home page. If you can't get to the internet options through the tools menu in IE because of this, right click on the IE icon on the desktop and choose properties. You'll find a place on the general tab where you can change it if needed.
    Flatiron2
    Flatiron2 Well-Known Member
    If your not comfortable in the registry here's an automated fix.
    Try #260 right side of page.
    System32 Folder Opens Upon Boot
    http://www.kellys-korner-xp.com/xp_tweaks.htm
    To use the VBS Files:
    Download .vbs file and save it to your hard drive
    (you may want to right click and use Save Target As).
    Double click the vbs file. You will be prompted when the script is done.
