system 32 security issue. corrupt, missing, or damaged.
Discussion in 'Windows XP' started by krisc09, 2009/08/01.
  1. 2009/08/01
    krisc09
    krisc09 Inactive Thread Starter
    I turn my computer on and the first thing that comes up is options to start in safe mode,safe mode with networking,command prompt, last known etc.. You get the picture. I start in safe mode, it shows the windows logo and then will click, turn off and restart itself over and over and over.
    Then if I press F8 and go to the recovery console, anything I press to do, the same thing will occur.:mad:
  2. 2009/08/01
    Hi krisc09. Welcome to Windowsbbs! :)
    Try following these steps:
    1. Since you tried Safe Mode and Last Known Good Configuration without success then boot from a Windows XP CD.
    2. When you boot from the CD do you see an option that says Press R to boot into the recovery console? If you see that option press R.
    3. Once you boot into the recovery console it will ask you which Windows installation you wish to log into.
    4. Press 1 and hit enter.
    5. Next type the administrator password. If you don't have a password then leave it blank otherwise type it in and hit enter.
    6. Next type the following commands and hit enter after each one.
    fixboot
    fixmbr
    chkdsk /r
    You may be asked to confirm an action after typing in the commands. Type Y to confirm the action if you are asked. After check disk has finished checking your harddrive type exit to quit setup. Hopefully the computer will now boot.
    7. If the system still doesn't boot then power off the machine, open the case up and take out the harddrive. If you have another computer hook up the harddrive as a slave drive where you can copy all the important data off the slaved drive onto another harddrive.
    8. If you would rather not hook up the harddrive as a slave drive then try Performing a Repair Installation of Windows XP.
    Let me know if you can get the computer to boot after performing the above steps. :)
