SysAi.exe, winupd.exe, WToolsA.exe, WToolsS.exe, WSup.exe Problem HJT Log Included
Discussion in 'Security and Privacy' started by jack86, 2004/07/13.
  1. 2004/07/13
    jack86
    jack86 Inactive Thread Starter
    hey. out of nowhere the following processes showed up on my task manager and their processes won't terminate:
    winupd.exe
    SysAi.exe
    WToolsA.exe
    WSup.exe
    WToolsS.exe
    i'm running XP Pro. any help would be appreciated. Thanks...Jack
    my HJT log:
    Logfile of HijackThis v1.98.0
    Scan saved at 10:38:16 PM, on 7/13/2004
    Platform: Windows XP (WinNT 5.01.2600)
    MSIE: Internet Explorer v6.00 (6.00.2600.0000)
    C:\Program Files\Common Files\WinTools\WSup.exe
    C:\WINDOWS\System32\taskmgr.exe
    C:\Program Files\Common Files\WinTools\WToolsA.exe
    C:\Program Files\Common Files\WinTools\WToolsS.exe
    C:\Documents and Settings\Jack.HOME-BMPIGKLO85\Desktop\HijackThis.exe
    C:\Program Files\SysAI\SysAI.exe
    R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Bar = http://www.websearch.com/ie.aspx?tb_id=50093
    R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://aimhome.netscape.com/aimhome.adp
    R1 - HKLM\Software\Microsoft\Internet Explorer\Main,SearchAssistant = http://www.websearch.com/ie.aspx?tb_id=50093
    R1 - HKLM\Software\Microsoft\Internet Explorer\Main,CustomizeSearch = res://C:\PROGRA~1\Toolbar\toolbar.dll/sa
    R0 - HKLM\Software\Microsoft\Internet Explorer\Search,SearchAssistant = http://www.websearch.com/ie.aspx?tb_id=50093
    R0 - HKLM\Software\Microsoft\Internet Explorer\Search,CustomizeSearch = res://C:\PROGRA~1\Toolbar\toolbar.dll/sa
    R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName =
    R3 - URLSearchHook: (no name) - {8952A998-1E7E-4716-B23D-3DBE03910972} - C:\PROGRA~1\Toolbar\toolbar.dll
    O2 - BHO: (no name) - SOFTWARE - (no file)
    O2 - BHO: CSIECore Class - {00000000-0000-0000-0000-000000000221} - C:\Program Files\ClearSearch\CSIE.DLL
    O2 - BHO: NavErrRedir Class - {00D6A7E7-4A97-456f-848A-3B75BF7554D7} - C:\PROGRA~1\PERFEC~1\BHO\PERFEC~2.DLL
    O2 - BHO: (no name) - {87766247-311C-43B4-8499-3D5FEC94A183} - C:\PROGRA~1\COMMON~1\WinTools\WToolsB.dll
    O2 - BHO: (no name) - {8952A998-1E7E-4716-B23D-3DBE03910972} - C:\PROGRA~1\Toolbar\toolbar.dll
    O2 - BHO: Band Class - {C5183ABC-EB6E-4E05-B8C9-500A16B6CF94} - C:\Program Files\SEP\sep.dll
    O3 - Toolbar: &Radio - {8E718888-423F-11D2-876E-00A0C9082467} - C:\WINDOWS\System32\msdxm.ocx
    O3 - Toolbar: Band Class - {C5183ABC-EB6E-4E05-B8C9-500A16B6CF94} - C:\Program Files\SEP\sep.dll
    O3 - Toolbar: &Search Toolbar - {339BB23F-A864-48C0-A59F-29EA915965EC} - C:\PROGRA~1\Toolbar\toolbar.dll
    O4 - HKLM\..\Run: [MSConfig] C:\WINDOWS\PCHealth\HelpCtr\Binaries\MSConfig.exe /auto
    O4 - HKLM\..\Run: [WinTools] C:\Program Files\Common Files\WinTools\WToolsA.exe
    O9 - Extra button: (no name) - {120E090D-9136-4b78-8258-F0B44B4BD2AC} - C:\WINDOWS\System32\ms.exe
    O9 - Extra 'Tools' menuitem: MaxSpeed - {120E090D-9136-4b78-8258-F0B44B4BD2AC} - C:\WINDOWS\System32\ms.exe
    O9 - Extra button: AIM - {AC9E2541-2814-11d5-BC6D-00B0D0A1DE45} - C:\PROGRA~1\AIM\aim.exe
    O9 - Extra button: Related - {c95fe080-8f5d-11d2-a20b-00aa003c157a} - C:\WINDOWS\web\related.htm
    O9 - Extra 'Tools' menuitem: Show &Related Links - {c95fe080-8f5d-11d2-a20b-00aa003c157a} - C:\WINDOWS\web\related.htm
    O12 - Plugin for .pdf: C:\Program Files\Internet Explorer\PLUGINS\nppdf32.dll
    O16 - DPF: {74D05D43-3236-11D4-BDCD-00C04F9A3B61} (HouseCall Control) - http://a840.g.akamai.net/7/840/537/2004061001/housecall.trendmicro.com/housecall/xscan53.cab
    O16 - DPF: {E6A3C1E2-F792-483E-9133-596215172BE9} (AcceptLang Class) - http://runonce.msn.com/setacceptlang.cab
    O16 - DPF: {FF65677A-8977-48CA-916A-DFF81B037DF3} (WMService Class) - http://download.overpro.com/WildApp.cab
    O17 - HKLM\System\CCS\Services\Tcpip\..\{65918E47-BE68-44E6-B5AE-ED25EA078B43}: NameServer = 151.202.0.85 151.203.0.85
    O18 - Protocol: tpro - {FF76A5DA-6158-4439-99FF-EDC1B3FE100C} - C:\PROGRA~1\Toolbar\toolbar.dll
  2. 2004/07/13
    Paul
    Paul Inactive
    Welcome to the BBS jack86, :)
    You have a combination of Viri and spyware. Update your AV programme and do a full system scan.
    Download and install Spybot and Ad-aware. Run the update for both before using, and run each one, after the other deleting all they find.
    For more info put these .exe files in a search engine and you'll find a lot of info on them.
    See my sig for downloads of these programmes. If you have no AV then suggest AVG 6.0 free edition, also below. Update it on line after install as well.
    Good luck. ;)
    Paul,
    noahdfear
    noahdfear Inactive
    You also need to visit Windows Update. Install all criticals offered. Then post a new HJT log and we'll help you finish cleaning up.
