svchost.exe problem...help needed~!
Discussion in 'Windows XP' started by ezragoh7, 2007/12/21.
  1. 2007/12/21
    ezragoh7
    ezragoh7 Inactive Thread Starter
    Hi Admins and helpers!
    The svchost.exe is running high like 80 - 100% most of the time and i totally do not know what to do about...so i am asking helps from u peeps..
  2. 2007/12/21
    sparrow
    sparrow Inactive
    Hi ezragoh7!
    Welcome to the forum.
    Several things need checking.
    First, what is the make and model number of the computer? How much memory (RAM) is there? What security have you (firewall, antivirus, antispyware, etc.)
    Meanwhile, go to msconfig (just type it into a run window - start/run) and disable all, reboot, and see the result. If by chance, the cpu is back to normal, add the items back one at a time to find the culprit.
    Orherwise, re-enable them, except for any you don't need running in the background using valuable CPU cycles. Then download and run the kaspersky online scan and let us know if it finds anything.
    Also download and install winpatrol.exe.
    ezragoh7
    Hi
    What do u mean by make? =X
    I am using Intel Inside Pentium 4 and i have 608MB of RAM.
    Windows Firewall & AVG.
    i ran kasper online scanner the other day..and it is perfectly clean, no virus found etc.
  6. 2007/12/25
    krypticChewie
    krypticChewie Inactive
    Perhaps it's a Windows Update problem. I used to get this issue on my laptop and I found an article on it on Microsoft's site. I downloaded the hotfix and it worked. But I think now that fix is in the normal windows update. Run windows update and see if you still get the problem.
