Sun JRE Security Issue
Discussion in 'Firefox, Thunderbird & SeaMonkey' started by Ramona, 2002/11/22.
  1. 2002/11/22
    Ramona
    Ramona Geek Member Alumni Thread Starter
    Netscape Security News - Sun JRE (Java Runtime Environment) Issue
    Sun Microsystems, Inc. Security Bulletin
    Bulletin Number: #00220
    Date: November 19, 2002
    Cross-Ref: http://www.cert.org/advisories/CA-2002-07.html
    Title: Double Free bug in zlib compression library
    CERT has reported a bug in the zlib compression library
    Sun's implementations of the Java(TM) Runtime Environment
    include zlib and are affected. This bug may allow malicious code
    to corrupt memory and possibly crash the Java Runtime Environment.
    The full and custom installations of Netscape 7 for Linux
    and the full and custom installations of Netscape 6 for Linux and
    Windows are affected since they include an affected version of the
    Java Runtime Environment. The default Java runtime environment of
    Netscape 7 for Windows is not affected. The default Java runtime
    environment of Netscape(TM) Communicator version 4.x is also
    not affected.
  2. 2002/11/23
    Alice
    Alice Banned
    Just wanted to add,
    That would be "Java 2 Runtime Environment, SE v1.4.0_01" from what I've gathered from the Netscape 7 release notes and elsewhere....
    So, if you see that, or higher, in Control Panel Add/Remove programs, you're OK.
