Resolved "sufficent rights to modify settings"
Discussion in 'Windows XP' started by frayedknotarts, 2009/10/28.
  1. 2009/10/28
    frayedknotarts Lifetime Subscription
    frayedknotarts Well-Known Member Thread Starter
    Unsure as to where this should go:
    WinXP-SP3 installed.
    Wanted to install a new CA AV program so uninstalled old one and installed new one. In the middle of this I got a window that said "could not set some or all of your changed options: please check if you have sufficent rights to modify settings on this computer ". When I go to enable protection I get the same message.
    When I boot up, only one user option comes up (taxprep1) but no option to select for administrator or anything that would indicate that there is an administrator setting.
    I know this is confused, but so am I.
    TIA!
  2. 2009/10/28
    Thanks! I did that but to no avail as the sign on I was using WAS the administrator. I finally gave up, un-installed CA and then re-installed it and it went in like "kissing yer sister ".
    Dunno what the issue was but it probably was a failed install rather than not having "sufficient permissions ".
    Appreciated the help, tho. Now I know how to do that for future reference.
  5. 2009/10/28
    Your Welcome. I am glad you were able to get your issue resolved. :)
